Technical Convert to crab style
Discussion in 'Traditional Hot Rods' started by 65standard, Dec 20, 2024.
  1. 65standard
    65standard
    Is there a conversion kit to convert my 1947 flathead round type distributor to the crab style? The base looks the same on the 42-45 crab style as the 46-48 round style.
  2. 65standard
    65standard
    2C5675E6-596D-4FC4-95AF-0E0BE88C1FA1.jpeg EE3ED394-5052-466E-AA38-3A64FB18A3F1.jpeg 59A95A92-FD71-4B36-BC30-A539E38500FA.jpeg I think I would just need the small straps, cap and rotor to convert?
  3. Automotive Stud
    Automotive Stud
    You just need shorter clips to hold the cap on, along with the crab cap and rotor. Before the Ford parts places carried them VW bug clips are short enough to work also.
    custom_lettering and 65standard like this.
  4. alchemy
    alchemy
    Yup. Very simple.
    65standard likes this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Is there any advantage to switching to a crab style distributor? HRP
  6. banjorear
    banjorear
    Much easier wiring into the cap, shorter distance helps with fan clearance and looks older for the same performance. The later style with the "rabbit ears" is post-war up until '48. It was designed for prevent moisture issues people reported with the "crab" style.
    Simply adding rubber boots to the wires going into the cap pretty much eliminates any issues.
    chevyfordman and 65standard like this.
  7. Zax
    Zax
    I don't know about a kit, but the parts are readily available. I did it to the 59A in my 40 Ford last year
    chevyfordman likes this.
  8. theHIGHLANDER
    theHIGHLANDER
    The HAMB is so kool, you don't get shamed for having crabs. Wait, my bad, wrong crabs...o_O
    BJR likes this.
  9. chevyfordman
    chevyfordman
  10. Mac VP
    Mac VP
