Technical How many people stick weld frames?
Discussion in 'The Hokey Ass Message Board' started by Matt Dudley, Dec 13, 2024.
  1. 49ratfink
    49ratfink
    I built elevators for a few years. on one job we had an ex ironworker do all the stick welding in the big brackets that hold everything together. I have never seen such beautiful welds, I should have taken a picture.
    alanp561 likes this.
  2. ALLDONE
    ALLDONE
    mine didn't have to do that..... IMG_3307[8974].jpg IMG_3308[8975].jpg IMG_3309[8976].jpg IMG_3522[9093].jpg IMG_3523[9092].jpg IMG_3524[9091].jpg IMG_3525[9090].jpg
  3. Dave G in Gansevoort
    from Upstate NY
    Years ago when I took a welding course, the instructor asked us if we knew what the various acronyms for welder types meant. When mig was mentioned, one fellow student said “maybe it’s good “. Even the instructor laughed at that one
    clem, alanp561, X-cpe and 3 others like this.
  4. Unkl Ian
    Unkl Ian
    Surprisingly accurate, sometimes.
    X-cpe likes this.
  5. VERNOR-GREEN GARAGE
    VERNOR-GREEN GARAGE
    from Michigan
    I have a 220 volt Miller Mig it maxes at 300 amps I use it for welding frames . But I do have a good old Lincoln 225 ARC welder for heavy old stuff
  6. clem
    clem
    The Model A and ‘32 cross members are reasonable thickness, so while riveting is traditional and that is what your cross members are, not many do that, stick weld would be the answer if that is what you’re most comfortable with.
    I always thought that gas is for thinner steel, such as exhausts and sheet metal.
    arse_sidewards likes this.
