Technical ***December 2024 Banger Meet Thread - Santa, I was bad, but good at it***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 1, 2024.
  1. Gasket and some silicone should do.
    Outback likes this.
  2. Fabber McGee
    Fabber McGee
    This is the holdingest stuff I've found. I have to drive a wedge in behind my differential cover and pry like hell to get it off. I wouldn't be at all afraid to use it on a tappet cover without a gasket. Screenshot 2024-12-20 095447.png
    Outback likes this.
  3. Outback
    Outback
    from NE Vic, Oz
    Thanks guys, that is what we had hoped. The oil pump is vw & he was a little concerned about the extra pressure in there. I expect to hear it run over the Christmas break
  4. It should be no problem, I have run 100 psi for longer runs at Bonneville with no gasket
    J
    jet996 and Outback like this.
  5. Crazydaddyo
    Crazydaddyo
    I like to add some screws in the rail between the two chambers.
  6. steve hackel
    steve hackel
    Would it be possible to post a few more pictures of the oil pump conversion and the oil filters adapter - along with any available information thanks, Steve Hackel
    Outback likes this.
  7. Thanks guy!!
    Smart idea! That made me think of Hot Rod's coverage on the H&H Riley engine. He's got quite a few Screenshot 2024-12-21 at 1.54.00 PM.png
    winduptoy, jet996 and Outback like this.
  8. Outback
    Outback
    from NE Vic, Oz
    I'll see what I can dig up. The engine is in the ch***is as of yesterday
  9. set me on fire
    set me on fire
  10. Outback
    Outback
    from NE Vic, Oz
    Here you go, the order may be a little mucked up.
    The oil pump is vw beetle & oil filter housing has a pressure valve & is Aussie gm v8
    img_15_1735212364192.jpg img_14_1735212351426.jpg img_13_1735212292627.jpg img_12_1735212281233.jpg img_11_1735212269959.jpg img_10_1735212232672.jpg img_9_1735212224507.jpg img_8_1735212214465.jpg img_7_1735212203007.jpg img_6_1735212160551.jpg img_5_1735212149916.jpg img_4_1735212141697.jpg img_3_1735212133370.jpg img_1_1735212083464.jpg
    barobert, winduptoy, hotrodA and 11 others like this.
  11. Deutscher
    Deutscher
    from Germany
    Thats a great Work.
    Greetings Harald
    Outback likes this.
  12. Wow, my wrist hurts just looking at those bends. Solid work!!
  13. Outback
    Outback
    from NE Vic, Oz
    He's hoping for oil pressure & a run today
    winduptoy likes this.
  14. Outback
    Outback
    from NE Vic, Oz
    Well I heard & saw it run, sounds nice. No ph/camera so no pics, won't be long till it's bombing around!
    winduptoy and johnneilson like this.
  15. Interested in the sump baffling. I’m planning to redo mine as I lose pressure on right hand bends.
    winduptoy and Outback like this.
  16. Outback
    Outback
    from NE Vic, Oz
    Will try to find photos, there'll be some on an Aussie A fb group.
    He was getting 45psi of oil at idle
  17. @Outback, that’s nice work, and good use of, off the shelve parts, modified to work with our old engines. I really like how he has given the machined parts a cast look. Can you share how that was done? Is the oil pump fitted into a custom main bearing cap ?
    Outback and Retson the Racer like this.
  18. While it'll give you a different finish than what Outback posted, using a needle scaler with rounded off needles gives a really finish. [​IMG]
  19. Fabber McGee
    Fabber McGee
    The engine of this vintage snowmobile is located at the very back of the machine. The carb intake was located straight back in the snow dust and a filter would plug right away. Snow coming in hitting the piston skirts would scrub off the oil and cause early wear.
    My solution was to cut the carb flange off the manifold and TIG in a cast elbow that I sawed off a Ford 300 six injection manifold to turn the carb to a place where I could get a fresh air tube on it and gather snow free intake air from farther forward.
    Vintage racing rules require a stock engine, so I had to make my alteration look factory. I ground the welds smooth, then beat it up with a needle scaler and followed that with a small amount of blasting sand in my cabinet. Sand, not gl*** beads. If anyone asks, my planned response would be a shrug of my shoulders and, " I dunno, maybe it was a factory prototype. It sure as hell needed something."
    So, what do you think, does it look like a factory part?
  20. Fabber McGee
    Fabber McGee
    Not exactly a 4 banger, but it does fire 4 times in 2 revolutions, haha.
  21. Outback
    Outback
    from NE Vic, Oz
    I believe he uses a die grinder running very slowly to achieve the finish
    Yes he made custom main caps to suit the oil pump,
    He also welded the counter weights on & built up the rear seal area to run a modern lip seal.
    He's a little concerned about the extra load on the pump drive, with 55psi. Has anyone had issues with pump drive failure with higher pressure's
    skip65 and Fabber McGee like this.
  22. Dan from Oakland
    Dan from Oakland
    I'm not a big fan of running a big hi pressure pump off of the stock distributor drive gear, but guys do it all the time.
    All high oil pressure gives you is bragging rights- run the least oil pressure you need to make the bearings happy. Twice the pressure is twice the load on the drive gear. All big hi volume oil pumps do is beat the **** out of the oil- most of it gets byp***ed back into the oil pan without ever lubricating anything. Just food for thought. Happy New Year everyone!!
  23. Outback
    Outback
    from NE Vic, Oz
    Thanks Dan,
    I think he'll adjust the pressure reg to get the pressure down a bit, I guess the question is what psi do the bearings need to be happy. I'm sure he'll find a happy place, the cam is only slightly better than a B grind so not a big reving machine.
  24. IHMO a proper bearing installation only needs 30 psi at speed and 10-15 at idle
    There is a rule of thumb 10 psi per 1000 rpm speed
    I have had GM v8 motors with 5 psi idle and 30 at 5k that just last forever
    as you know the stk mod a was not pressurized but had a groove to supply oil across the length of the bearing and they ran a long time
    J
    Outback and winduptoy like this.
  25. Jiminy
    Jiminy
