Projects 37 Tudor family hauler/push car
Discussion in 'Traditional Customs' started by youngrodder1929, Jul 1, 2024.
  1. Mikko_
    Mikko_
    from Sweden
    Love the chop, looks very 40's custom to me.
    brad2v likes this.
  2. Nacifan
    Nacifan
    Just love the look of your build. Please keep posting so we can keep up on your progress. Herez a few pictures I have saved in a file of similar builds. :) 36-ford-sedan-mcfetridge 03.jpg 1940-ford-Sedan- Ken.jpg 2022-Grand-National-Roadster-Show-156-of-171.jpg 123847008_3338054406231442_2342063447257525340_n.jpg
  3. youngrodder1929
    youngrodder1929
    Okie Pete and razoo lew like this.
  4. youngrodder1929
    youngrodder1929
    Today I filled the last holes behind the window and sorted out one of the skirts. They are definitely not for a 1937 sedan the latch was the wrong angle and needed to be extended. It also needed more contour on the rear so I cut the flange off gave it a few shrinks re shaped the flange and welded it back in. PXL_20241027_225200036.MP.jpg
  5. youngrodder1929
    youngrodder1929
    Chop is mostly finished up really just the garnish moldings left and a bit of cleanup left. I have 41 gas filler door I'm going to fit and a passenger rear fender bottom patch that will be all for this round of sheet metal. Next up will be chassis work stay tuned ! PXL_20241116_011727757.MP~2.jpg PXL_20241116_011959379.MP.jpg
  6. alchemy
    alchemy
    I was worried it would have too much squareness at the back corner of the roof, but you seem to have whittled it down and given it a nice flow.
    hfh and youngrodder1929 like this.
  7. miguel.st
    miguel.st
    from germany
    Very nice, good job!
    Outback and youngrodder1929 like this.
  8. youngrodder1929
    youngrodder1929
    Moved on to the chassis for now, Pretty standard style c notch. The frame will get blasted/painted at a later date when the body gets painted . Wishbones will need a massage to clear the frame as well as some floor mods to clear the torque tube. Stay tuned . PXL_20241216_212722865.MP.jpg PXL_20241218_210833640.MP.jpg PXL_20241220_221732535.MP.jpg
  9. youngrodder1929
    youngrodder1929
    Couple goodies Frome the mail to keep my stoke going and a over all pic. It will go down a bit more yet but it gives an idea PXL_20241221_012550084.MP.jpg PXL_20241222_012544208.MP.jpg
  10. alchemy
    alchemy
  11. Rob28
    Rob28
    from Calgary AB
    The stance is looking great. What did you use to lift the body off?
  12. Outback
    Outback
    from NE Vic
    Moondog13, Okie Pete and guthriesmith like this.
  13. youngrodder1929
    youngrodder1929
    Forklift with a jib/boom
    Tim and Okie Pete like this.
  14. youngrodder1929
    youngrodder1929
    Haven't made up my mind on bumps since I want to use it as a push car I'm not sure if I want to use bumpers that are valuable lol
    Okie Pete and Outback like this.
  15. youngrodder1929
    youngrodder1929
    I have the brake and fuel lines run had to put the body back on due to space constraints temporarily a bit more sheet metal today. I reshaped and tacked the deluxe filler door in stock 37 location. Still not sure on what tail lights yet might end up using stock for this year PXL_20250216_020614476.MP.jpg
  16. Tim
    Tim
    from KCMO
    Wow this looks killer!
  17. I'm liking what I'm seeing!
    Have you chopped something before? You make it look so easy, and I know it's not easy. I would really like to build an early custom like this, but I'm not confident in my skills. I can handle it mechanically, but that chop is intimidating.
    Outback and guthriesmith like this.
  18. Tim
    Tim
    from KCMO
    Man @Dan Hay he really nailed it didn’t he? The drip around down the new sail panel around to the back line/curve is on the money.
    really digging the skirted sedan mild customs
    lately.
    Outback, guthriesmith and Dan Hay like this.
  19. That is quite a transformation.
    youngrodder1929 likes this.
  20. youngrodder1929
    youngrodder1929
    Thanks!
  21. youngrodder1929
    youngrodder1929
    Not a chop on anything round model as, dragster body parts and such. I would say look at as many chops in progress as you can and learn as much as you can about the process and go for it !
    Moondog13 and 1-SHOT like this.
  22. youngrodder1929
    youngrodder1929
    Thanks! Was bit of extra work definitely worth the effort I think!
    Outback, Tim and 1-SHOT like this.
  23. youngrodder1929
    youngrodder1929
    Fit up and semi finished, I need to patch the passenger rear fender where it meets the running board then on to the floor, at the current ride high the diff and torque tube is on the floor... Duece days is coming up quick I think the paint will be air drying on the way there lol
    Outback, Okie Pete, Tim and 4 others like this.
  24. 6sally6
    6sally6
    I bet that TIG really threw some heat into the metal !!
    NICEEE Job !!
    6sally6
    Outback likes this.
  25. Tim
    Tim
    from KCMO
    Looks like it grew there! Nice
