History Original 1928 Film Shows Full Lincoln Assembly Line
Discussion in 'The Hokey Ass Message Board' started by NoRust, Dec 26, 2024.
  1. NoRust
    NoRust
    Deuces, alanp561, SPEC and 13 others like this.
  2. chevy57dude
    chevy57dude
    Just watched it all the way through. Labor intensive! Not many jobs in that factory I'd want to do all day long. How about the guys hefting cylinder blocks by hand into the honing machines? Or grinding frame horns.. Great video, thanks for posting it up!
    Deuces, Driver50x and SS327 like this.
  3. woodiewagon46
    woodiewagon46
    from New York
    Check out the guy with the white shirt and bow tie installing the top with a magnetic hammer and taking the roof tacks out of his mouth! He looks like a waiter in some restaurant.
    Deuces, SS327 and chevy57dude like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    And those guys were knocking down a dollar per hour if they were at the top of their game, that was good money for the times.
    Thank you for posting, I thoroughly enjoyed the entire video. HRP
  5. 38Chevy454
    38Chevy454
    Neat video. Can definitely see the aviation influence in the engine design. Kind of strange seeing the piston and rod ***emblies loaded in from the bottom. Lots of use of go/no-go gauges during the manufacturing process.
  6. 19Fordy
    19Fordy
    Just think, that was state of the art machining 96 years ago. Most likely none of those workers are alive but, we still can enjoy the fruits of their labor. YES. THEY SURE DID LABOR. That was hard, back braking work.
  7. The tooling/manufacturing engineers sure were the labor/time saving masterminds of the day! All the fixturing and process shots are great!!
    Deuces and SS327 like this.
  8. ClayMart
    ClayMart
    Interesting to see the tools and fixtures used for building the wood framed bodies.
    Deuces likes this.
  9. SS327
    SS327
    And none of it was done with great precision either. Just clamp the wood and cut the wood, over and over again.
    Deuces and ClayMart like this.
  10. Robdski
    Robdski
    Great video, thanks for posting.
    Deuces likes this.
  11. stuart in mn
    stuart in mn
    There sure was a lot of hand labor in seat upholstery and top inserts.
    Deuces, ClayMart and chevy57dude like this.
  12. metlmunchr
    metlmunchr
    The thing that really surprised me was that the cam was cut entirely from a piece of round bar stock rather than being cast as a blank and machined/ground to final shape/size. A billet cam costs perhaps 5X as much as one made from a cast blank today, and that's with the speed of CNC to do all the machining. Back then, when they were roughing out the lobes on a horizontal mill, the final piece cost probably more on the order of 15X the cost of a cast blank cam. Strange thing which, sorta like polishing the frame rails, added nothing to the value of the car, but significantly added to the cost.
  13. ClayMart
    ClayMart
    Also looked like they spent some time smoothing out the as-cast finish of the crankcase and cylinder castings. And I'd bet that the salesman always pointed out these smoothed surfaces to every prospective buyer.
  14. Beanscoot
    Beanscoot
    This was an odd scene, the man is using a small squeeze bulb to raise a ball bearing(?) which is then bounced on a cam lobe. Hardness testing?
    Deuces likes this.
  15. noboD
    noboD
    Fabulous. My neighbor's '22 Lincoln touring car has an aluminum body. Does anyone know if the sedans were aluminum too? Did you see at 19 to 20 minutes the crankshaft is flat plane? I thought that was a new concept. Thanks for posting. The Dodge Brothers club has a factory film similar to this. Done in 1917ish the photography is not as good. I think it can be viewed on AACA library website in their Youtube section. It tells how many tons of br***, horsehair, leather, etc. are used every day. Just keeping up the supply chain would have been monumental.
    metlmunchr, Deuces and ClayMart like this.
  16. The37Kid
    The37Kid
    THANK YOU! Finally got to see a lot of ***embly line features I've always wondered about. Welded wire wheel ***embly, wood body ***embly, and body masking & paint. Hand held body beading was something I never knew existed. I'll watch it a few more times I'm sure.
    Driver50x and Deuces like this.
  17. kustomkat1950
    kustomkat1950
    from Coastal GA
    Wow. Thank you for sharing that. That was amazing! I don't do ford, but have owned 7 Lincoln Continentals.
    Deuces likes this.
  18. Beanscoot
    Beanscoot
    The wheel making was surprisingly time consuming, but what really impressed me was the fully machined combustion chambers.
  19. Deuces
    Deuces
    Pontiac did the same for the ram air heads.....
    SS327 likes this.
  20. Driver50x
    Driver50x
    What a cool video. And very high quality for that time frame.
    Deuces likes this.
