Projects Help staring flat head
Discussion in 'The Hokey Ass Message Board' started by iwanaflattie, Dec 25, 2024.
  1. Hello,
    Happy holidays.
    I was messing with the flathead in the welder yesterday again,and almost got to fire up.
    After the last attempt when it almost started but when I tried again it seemed like the battery died.
    I think I fried the starter solenoid.
    Problem one.
    This welder is al set up with gauges,starter button,fuel primer,it has a block heater etc.
    The starter button was sitting there but no wire attached to it.
    How does the button work? Just grounds the wire to the relay?
    Problem 2.
    When I hook the battery cables it automatically spins the starter, does the starter button(wire) have to do anything with this?
    Problem 3.
    I think I fried the starter relay, could I test this by hooking the battery directly to the starter?
    Thanks in advance.
  2. F-ONE
    F-ONE
    from Alabama
    I would check the connections and grounds. The wiring may be too small a gauge or corroded.
    Check all the connections and wire.
    A simple clean up can do wonders.
    That looks like a simple push button starter switch from like a Ford F1.
    You may want to look at a wiring diagram from one of those.
  3. Thank you..
    I just bypassed the starter,hooked a wire to the distributor and it fired up!!!!!
    alanp561, tb33anda3rd, NoSurf and 8 others like this.
  4. alchemy
    alchemy
    Were you cranking by hand?
  5. Sorry,I bypassed the starter solenoid,hooked the battery directly to the starter and it fired up,sadly I couldn't keep it running.
    Bad fuel pump,bad primer pump and God only what other issues are hiding.only thing I can do is try.
    SS327 likes this.
  6. As I said before,the flathead fired up and started ,and ran for a few seconds,,then it didn't start so I took a brake from it.
    I just looked at the primer pump and it's a 6v..
    Ooooops
  7. In my very limited experience, the diaphragm in the fuel pump was torn, and that was a long time ago.
