Projects Rear end swap for '59 Chevy Apache
Discussion in 'The Hokey Ass Message Board' started by hpBent, Jun 24, 2023.
  1. hpBent
    hpBent
    Hey folks!
    I am building a 1959 Chevy Apache pickup (custom, not stock) and am hoping to get a few ideas from those of you who have put a passenger car rear end under an Apache.
    My backing plates measure approximately 57" as measured from inside to inside. I have a lead on an early Camaro 10 bolt (8.5 version) that measures 54", a little too narrow, but with the correct wheel backspacing...
    Are there any other passenger car Chevy rear ends that might be a better fit without extensive mods?
    Thanks!
  2. lumpy 63
    lumpy 63
    2nd gen Camaro works very well, I have used em in 3 different 55-59 pickups. I believe they are 61" wide overall
  3. lumpy 63
    lumpy 63
    My current daily driver has one with 8.5 " Americans with 255 70 15 tires .
    hpBent likes this.
  4. hpBent
    hpBent
    So you don't even notice the approx. 2" width difference as compared to stock?
  5. Budget36
    Budget36
    Don’t be concerned with backing plate to backing plate, what you want to do is look at wheel mounting surface to WMS.
    And yes, 2nd Gen FBodies rears are a good fit width wise.
  6. guthriesmith
    guthriesmith
    Another vote for 2nd generation Camaro or Firebird. I even had one of those in a 50 Chevy pickup and it worked out well.
    hpBent and Truckdoctor Andy like this.
  7. Budget36
    Budget36
    I just looked under my ‘57, has an early GMC rearend with 10 inch wheels (about neutral offset) and had to raise it up an inch (will change that) to the L60’s wouldn’t rub the lip of the fender. But I could also , with proper offset gain another 1-1.5 inches inside. But An 8 inch wheel should be just fine.
    Truckdoctor Andy likes this.
  8. lumpy 63
    lumpy 63
    It completely fills the wheelwells with not a lot of room to spare:D
  9. Lloyd's paint & glass
  10. hpBent
    hpBent
  11. hpBent
    hpBent
    So it's been a while... I am finally picking back up on my project. I forgot to ask you about the backspacing on your wheels on the rear? And, what are you running up front for wheel/tire and suspension? Thank you!
  12. lumpy 63
    lumpy 63
    If memory serves me the back space is 3.75 the front wheels are 15x6 with 215 70 r15s
  13. lumpy 63
    lumpy 63
    IMG_20241226_180532.jpg It has a subframe swap on the front but we're not supposed to discuss that here
  14. hpBent
    hpBent
    Thank you for the info. It look good and the patina is awesome!
    lumpy 63 likes this.
