Projects Master cyl question
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Dec 27, 2024.
  1. IowaTom
    IowaTom
    Been a long time since I've replaced a master cylinder and need your expertise on which reservoir goes to front discs and rear drums. I'm using a Wilwood flat-top 1" bore. Does the larger reservoir feed the discs or the drums?
    Thanks for helping a dummy!
  2. lemondana
    lemondana
    from Lincoln NE
    Large compartment feeds the disc brakes.
  3. manyolcars
    manyolcars
    have I ever mentioned that we need a sub-forum just for brakes? :)
  4. RodStRace
    RodStRace
    BTW, this is usually the rear reservoir, closest to the firewall.
    So rear brakes in front, front brakes in rear. You want the fronts to grab first, although if everything is bled properly, it will be at the same time.
    Example
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    bobss396, RICH B, MAD MIKE and 2 others like this.
  6. IowaTom
    IowaTom
    You guys are golden! Thank you much!
    Sharpone likes this.
  7. RodStRace
    RodStRace
    Most I've seen are what I showed, but there is always an exception!
    The willwood is probably equal size under the cover, like a corvette 4WDB MC.
    bschwoeble and Sharpone like this.
  8. Last edited: Dec 28, 2024
  9. MAD MIKE
    MAD MIKE
    from 94577
    FWIW
    As posted by Johnny Gee, this disc/drum MC was used in most GM cars/light trucks from '69- ~'80 that used disc front brakes. This MC was then replaced by the 'metric' stepped quick take up plastic reservoir units in the late 70's.
    Handy bit is this disc/drum MCs used the same port sizes as the drum/drum MCs in 67-72. So if you want to convert to disc in those cars(or a car that has used a GM 67-72 drum/drum MC) was simply a matter of changing the MC, no need for adapters or re-plumbing at the MC.
  10. Kerrynzl
    Kerrynzl
    This ^^^ is the "urban myth" that @manyolcars was referring to [needing a "sub-forum"]
    None of the braking system has any clamping pressure until all the pressures are equalized throughout the whole hydraulic system.
    Even the floating piston in a tandem m/c will equalize [by volume] to the equal pressures front and rear.
    I no longer give advice on brake threads
    Usually because they are a total *********** of mismatched components [and generic disc conversion kits]
    2OLD2FAST and bschwoeble like this.
  11. I wish I could have given you 10 likes for this instead of just the 1. This is the most beat to death subject here on the H.A.M.B. It seems using the search menu never happens. Honest questions and some help I understand however most often it's from mix-n-match builders that shouldn't touch a Brake Job.
    Sharpone and bschwoeble like this.
  12. Another thing I love about the H.A.M.B. is that for every matter of fact answer someone will have a contradicting FACT about it. To me that means you better know what your doing and how your going to do it before you start.
