Hot Rods outer rims
Discussion in 'The Hokey Ass Message Board' started by bangngears, Dec 28, 2024.
  1. bangngears
    bangngears
    from ofallon mo
    Does anyone offer 15' outer rims. i need 2 outers 7 inches wide to add my centers too.
  2. deathrowdave
    deathrowdave
    from NKy
    Hoops , check speedway or wheel manufactures
    Tim likes this.
  3. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    15 foot outer rims are going to be hard to find - and fit up.
  4. big duece
    big duece
    from kansas
  5. deuceman32
    deuceman32
    Which centers are you wanting to use? You will need to know the diameter. For example, a 15" early Ford steelie center is about 12&5/8" and a 16" early Ford steelie center is about 13&5/8".
  6. big duece
    big duece
    from kansas
    Good point, the Miller site that I posted has their ID at 12.5" which would not work for GM
  7. bangngears
    bangngears
    from ofallon mo
    I would put Chevy centers in them
  8. Unkl Ian
    Unkl Ian
    Speedway has hoops, no idea on dimensions.
  9. skooch
    skooch
    Something like this?
  10. alchemy
    alchemy
    Have you measured the centers you want to use? Not all Chevy centers are the same. When you have that measurement you can begin shopping.
  11. AccurateMike
    AccurateMike
  12. bangngears
    bangngears
    from ofallon mo
    ordered some from Miller tire, then found some at Heywheel a little cheaper . So thanks to big deuce for leading to Miller
    THE FRENCHTOWN FLYER likes this.
  13. bangngears
    bangngears
    from ofallon mo
    55 chevy centers are 12.5
  14. bangngears
    bangngears
    from ofallon mo
    Speedway does not offer outers
