What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. guthriesmith
    guthriesmith
    What is that body made of? Appears that to fix the front wing, you cut both sides off and fabricated new ones out of aluminum or something? That will likely be much more durable that whatever the rest is made of.
    29A-V8, porkshop and anthony myrick like this.
  2. Unknown plastic. But an ABS plastic “welding rod” stuck to it
    https://www.jalopyjournal.com/forum/threads/go-carts-ok-indy-styled-go-cart-rebuild.1328470/
    both wings were broke. So we made new ones from s**** aluminum.
    The busted plastic was welded, stapled and finished out with panel bond
  3. Okie Pete
    Okie Pete
  4. SS327
    SS327
    porkshop, guthriesmith and 29A-V8 like this.
  5. Okie Pete
    Okie Pete
    It was an old burnt out vacuum tube . It’s going to be a robot
    rod1, porkshop, guthriesmith and 4 others like this.
  6. Okie Pete
    Okie Pete
    IMG_0725.jpeg It’s got tracks
    jimmy959, safetythird, enloe and 14 others like this.
  7. Baumi
    Baumi
    I finished rebuilding the rearend on my ´88 BMW 535i, it had been sitting since 2004 and now that it´s back on the road everything starts to leak. But that was to be expected, haha... thhis should have been the last thing... there, I said it...
  8. 29A-V8
    29A-V8
    from wyoming
    SS327
    you must be a younger fellow................ no offence :D
    porkshop and Okie Pete like this.
  9. 29A-V8
    29A-V8
    from wyoming
  10. SS327
    SS327
    No, I recognized the tube. Just never saw one with the other stuff on it and got confused.
  11. Late 60s maybe 70, JC Penny ****Tracker. 3 wheeler
    ad from Penny’s
    IMG_4074.jpeg I’ve had it a while. My uncle bought is used around 1971. Been riding this since I was a kid. Talked him out of it a few years back. Son said it’s time to get it fixed.
    cleaned out the tank, cleaned up the carb, got to replace a brake cable and make a throttle return spring (maybe beef up the current one) and replace a tube.
    We got it running this evening.
  12. Okie Pete
    Okie Pete
    IMG_0746.jpeg IMG_0747.jpeg I’ve got to make another hand / claw and glue them on . Then clean up some stuff
    Bleach, enloe, RMcCulley and 11 others like this.
  13. SS327
    SS327
    Oakie Pete has tubes. Maybe ask him for one?
  14. Okie Pete
    Okie Pete
    It was the only one I had . It came out of a control box for a m***age device that I found in an old dump site .
    SS327, anthony myrick and porkshop like this.
  15. Okie Pete
    Okie Pete
  16. guthriesmith
    guthriesmith
    porkshop, Okie Pete and Deuces like this.
  17. Got it going
    need to straighten up some old wreck damage.
    Clean it up
    some old ads
  18. guthriesmith
    guthriesmith
    Well…I worked on my Chevelle today but still don’t have it fixed. Starts right up but then acts like it loses ignition or something. Anyway, didn’t have much time to troubleshoot today with 10 other projects around the house too. I also worked on my 56 enough to get it started and say I drove it the last day of the year. Maybe I’ll take it to the car wash tomorrow. I think it feels neglected.
  19. been chasing some issues, intermittent high idle, intermittent hard starting, sound was off...
    went to pull the wires, found 1 issue right away with the cap..
    checked the plug wires, they all checked out.
    Replaced cap & rotor.
    Had a hunch to check choke cable... Found the choke cable needed "re-adjusting" after replacing the motor mounts... still chasing the intermittent high idle and intermittent hard starting ... IMG_2341.jpeg
  20. TA DAD
    TA DAD
    from NC
    Giving my old Dodge some well earned love, new vc gaskets , belts and hoses , radiator and a heater core. Man I hate working on cars lol but I do like being in my space ! IMG_0237 (2).JPG IMG_1765.JPG IMG_1766.JPG IMG_1775.JPG
    Okie Pete, porkshop, Deuces and 3 others like this.
  21. j hansen
    j hansen
    Ohh,, i got to steal that oilfilter idea!
    But I`m will place it under my cleaner.
    Thx @TA DAD
    RMcCulley, porkshop and Deuces like this.
  22. TA DAD
    TA DAD
    from NC
    I use a fuel filter for a diesel truck , it does keep the solvent clean plus I use a scotch brite pad in the tub drain to catch what I miss on the initial cleaning.
  23. Oneball
    Oneball
    Oil cooler seals on my 20 year old daily. Jeez there’s a lot of stuff to come off to get to this point!
    Okie Pete and porkshop like this.
  24. Bleach
    Bleach
    Okie Pete, porkshop and Oneball like this.
  25. Oneball
    Oneball
    Mercedes 3.0L V6 diesel (OM642). I suppose the one plus is unlike a Ford FE I don’t need a crane to lift the intake.
  26. Bleach
    Bleach
    No wonder it doesn’t look familiar. I guess we didn’t get that one here’s in the US.
    Last Mercedes I worked on was an 80’s OM 617 turbo diesel. That was much simpler than everything afterwards.
    Oneball, enloe and Okie Pete like this.
  27. Oneball
    Oneball
    I’m pretty sure you get it over there, they also used it in Jeeps and Chrysler 300, there’s literally a trunk full of stuff normally above what you can see now!
    Bleach likes this.
  28. Bleach
    Bleach
    I became disinterested in all things produced by Daimler-Benz after my OM603 powered W124. Both the car and engine were a steaming pile of ****.
    I test drove a E320 CDI back around 2005. I was impressed by all the power it had and that it didn’t really sound like a diesel. I just didn’t feel the $55K list price was worth it.
    Best of luck with your Benz.
  29. j hansen
    j hansen
    Then there is some *******`s,,,like my 2007 300 HEMI WAGON
    Bleach, porkshop and Oneball like this.
  30. j hansen
    j hansen
    New paint on the 300 wheels.
    First a good clean!:D
    Then sanding.
    Then primer, color and clear.
    Uncle Ronn, Okie Pete, Bleach and 2 others like this.
