Technical blower pulley tool
Discussion in 'The Hokey Ass Message Board' started by wuga, Dec 28, 2024.
  1. wuga
    wuga
    I have decided to reinstall my blower engine back into my Tudor. Before I do, I want to do some cursory checking including turning the engine over by hand. I am running a 2" wide notched belt. The crank bolt is buried under the lower blower pulley. I have tried oil filter grippers on the pulley but to no avail. Does anyone know of a tool specifically made to grab the notched pulley without damaging the teeth.
    Warren
  2. squirrel
    the blower drive snout should have a 1/2" square hole in it, it appears in the center of the upper pulley. Use a breaker bar to turn it.
  3. 19Eddy30
    19Eddy30
    from VA
    On mine , About 1-3/4 space between Elec fan & face of pulley , This Is one I made to fit my need to Rotate Blower / Engine to use with Open or close wrench when unable to use Breaker Bar nor Ratchet.
    First 2 pic's , &" If" Alternator belt adjusted correctly you can also rotate the engine with the alternator
    Pulley bolt.
    Other tools are for Moroso Aluminum Oil Pan with internal bolts ,
    Up inside Pan
    Also 1/4 5/8 Spark plug socket to use on Tight Header plugs to use
    1/4 wrench , Just thoughts;)
    Just Gary, mad mikey, Chucky and 2 others like this.
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Both answers above are spot on.
    If perchance you can't swing it.
    I would bet that a loop of clothesline beneath your filter strap, would give the purchase needed.
    Apologies to real mechanics.
    Just Gary, SS327 and mad mikey like this.
  5. mad mikey
    mad mikey
    ^^^^^YEP^^^^
    Tow Truck Tom likes this.
  6. mad mikey
    mad mikey
  7. wuga
    wuga
    Here are a couple of pictures of the upper and lower drives. There is no hole or bolthead to get ahold of. This setup was built by Bob Beezer, the the Indian starter from the early Nationals. I really need a tool that will latch into the ribs of the drive gears.
    Warren
    swade41 likes this.
  8. 19Eddy30
    19Eddy30
    from VA
    No big deal there is a tool for that set up you need
    Its basically a big washer with a square drive in the center that Bolts to the pulley or crank ,
    Easy to make, Hole saw , welder & drill old socket, or file required.
    mad mikey and Tow Truck Tom like this.
  9. Jmountainjr
    Jmountainjr
    If it was mine, I would machine a steel or aluminum disk that would bolt on using the upper pulley mounting bolts (length adjusted as needed) that incorporates a means to attach a wrench to turn over the engine. Latching onto pulley OD isn't a good long term solution .
    RodStRace and Tow Truck Tom like this.
  10. 19Eddy30
    19Eddy30
    from VA
    Or weld a 1/2 drive socket or 3/8s to snout , about 1/2 deep/ long ,
    We are skinning cats in many different ways:D
    Tow Truck Tom and mad mikey like this.
  11. 19Eddy30
    19Eddy30
    from VA
    There been times thing's out side box ,
    Not have a tool , used like oil filter wrench , my leather belt & like round doll like a broom handle
    Watching MacGyver paid off,
    a**** the many nicknames I have been called besides A$$ , MacGyver Ed
    SS327 likes this.
  12. wuga
    wuga
    I wanted a positive drive like on my other engines. I did not want to weld to the aluminum pulley. I have ordered the rotation plate. Perfect answer. Thank you all.
    Warren
    RodStRace and BJR like this.
  13. 19Eddy30
    19Eddy30
    from VA
    A Few weeks ago on a OT , lost head light ,like usual 2 am No one up , vampire hours , I had a cord from a 110v house cord , I cut up , cut plug off head light
    Wired to head light straight to battery to get me home:mad:
  14. 19Eddy30
    19Eddy30
    from VA
    No problem with that, things like this fun to me , just thinking how to Solve or just get me to my shop
  15. squirrel
    you don't need all 6 bolts, you could just weld any decent sized nut to the middle of a long enough 1" x 1/4" steel bar with a 3/8" hole at each end, and you'd be done. But the fancy machined part will look so much better!
    Truckdoctor Andy likes this.
  16. wuga
    wuga
    I could have done that, but I don't like cobbled parts an a fully balanced drive train, even on a small diameter. Once the engine is installed, no one will be able to see the plate anyway.
    Warren
  17. Fordors
    Fordors
    @wuga , have you considered that the bolt circle on that plate from Alky Digger may have a different bolt circle than your pulley? I see a 6-53 that has custom ball bearing end plates and also a blower drive that was fabricated for a 53 series blower. I’d advise finding out if that rotation plate actually fits your pulley.
  18. 19Eddy30
    19Eddy30
    from VA
    Not busting on your build ,
    You mention balancing, I can tell you your drive snout is not Perfect , Belt going to absorb vibration from Blower to crank ,
    Do not know how potent your engine
    Nor Rpm's turning ,
    I know many use ,, For me I do not like using top pulley that fair away & off center of the bearing on that type of snout , with out more support,
    & the load on front main bearing with out crank suport , & load on arm idler,
    I use 8 & 14 mm belts .I have striped to many 1/2 belts.
    Again Not busting on your parts , I have Brocken long snouts , It can & has became costly over the years,
    Like pics I have post with just grade 8 normal bolts / nuts .I have some times
    Just use what I grab my hands on with out going threw a few 5 gallon buckets
    Of ARP bolts , nuts , studs ,
    NAS bolts nuts studs , same with boxes & boxes fittings .
    When it comes to paint , I will not more likely paint Vehicle again,
    I had painted one with all H O K candy's & pearls ,really 2 , 2nd tow Dual several Ks just in paint, One burnout , chips from slinging
    Grit , small pebbles, off slicks ,
    I know we all have our own ways of doing things And different opinions!!
  19. Harv
    Harv
    from Sydney
    That’s what I do… length of flat bar, two bolt holes and a square one for a breaker bar. If it is temporary, 2 bolts will do. If it lives there forever, use all 6 and make it neat.
    cheers,
    Harv
  20. Harv
    Harv
    from Sydney
    Once the engine is installed, remove the plate. Not something you use very often unless you’re turning over a fueller to prove clear of nitro, quick to take on and off, no need for permanent.
    cheers,
    Harv
