Projects Keeper Coupe
Discussion in 'Traditional Hot Rods' started by trevorsworth, Dec 27, 2024.
  1. Rickybop
    Rickybop
    $200 ?!?
    What is this, 1961?
    :D
    Hitchhiker, Sharpone, Stogy and 8 others like this.
  2. Rickybop
    Rickybop
  3. Roothawg
    Roothawg
    Look up Mike Zenor’s coupe. It’s a neat little car.
    never mind I did it for ya…..
  4. trevorsworth
    trevorsworth
    IMG_0150.jpeg IMG_0151.jpeg IMG_0152.jpeg IMG_0154.jpeg IMG_0155.jpeg IMG_0156.jpeg IMG_0157.jpeg IMG_0158.jpeg IMG_0159.jpeg IMG_0160.jpeg IMG_0162.jpeg IMG_0166.jpeg
    Still sporting its hand painted numbers and windshield sticker from its last campaign at Green Valley... when this car was parked it was running a mechanically injected Canadian flathead supposedly with 4" bores.
    An engine which still exists... which he is open to selling me.
  5. Tim
    Tim
    from KCMO
    Man that rules! Go Sid Go!
    that ****ter shield is nuts
    Sharpone, Stogy, 54delray and 5 others like this.
  6. Looks like a 50 Merc rear axle housing.
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Looks like a lot of h***le.
    Let me know if you would like to double your money.:rolleyes:
    ( meant to hit the post ****on yesterday hope I'm not too late )
    Sharpone, Stogy, Apenaut and 5 others like this.
  8. trevorsworth
    trevorsworth
    Okay... so as the story goes, his dad started building the car in the early 50s and raced it into the early 60s until it got replaced by an Anglia (which he still has). He was a flathead nut and it never had anything but flatheads in it. He never ran a hood or running boards (but Guy remembers when he acquired the car, the original running boards had been replaced with wood), but we did find an aluminum hood that he made & never used which has been inside tucked away all this time.
    He was a tooling engineer and he designed & cast many of the parts on the car, like the shock mounts. That's really cool - but could be a blessing or a curse when it comes to putting this car back together.
    He has the grille shell and radiator, which I'm going to meet him at his warehouse next week to get and to check out the Hillborn injected flathead that came out of the car along with the rest of the parts hoard that got moved there. Sounds like it's a '32 shell.
    I can't wait to dig into this thing, guys... I still can't believe it.
  9. Rickybop
    Rickybop
    "I still can't believe it"...
    ... is really really good. :)
  10. chevy57dude
    chevy57dude
    I'm very happy for you and the car! Looking forward to the ''cleaned up'' pics.
  11. trevorsworth
    trevorsworth
    On its way to the shop... the adventure begins.
  12. tubman
    tubman
    He must have meant a 4" stroke. A common understandable mistake. If possible. it would be nice to reunite it with the car if it's really still around.
  13. trevorsworth
    trevorsworth
    He was very specific about his father casting the pistons himself and punching the block out to its limits. He was definitely talking about the bore. I'm sure there's some "lore" in there... he stressed that it was a Canadian Mercury block but I don't know of specifically Canadian flatheads being considered better for any reason? Mercury, yes... and the 8CM does have a 4" stroke... so probably just crossed wires in memory. I think a 4" bore in any flathead is not possible.
  14. The most I've ever been involved directly with is 3-3/8" bore. That and a little offset grind on a 4" crank gives up 296 ci if I remember the numbers correctly. That was about all we could squeeze out of them and keep them together.
  15. In_The_Pink
    In_The_Pink
    It's good to have friends who'll tip you off when they come across something like this. :)
    Looks like it'll be an interesting and challenging project for you, but still plenty of wiggle room to build it how you like.
    I'll suggest the Candy Cane Coupe name, just because of that awesome roll bar and the timing. Enjoy!
  16. RodStRace
    RodStRace
    @trevorsworth If you take the body off this and stick on a pickup, I'll personally come to Texas and make you kick your own ***!
    Write down everything (or record it) you are told. Some casual remark may be very important later. Walk him from one end of the car to the other, asking about each thing.
    Sharpone, Stogy, Thor1 and 8 others like this.
  17. RodStRace
    RodStRace
  18. trevorsworth
    trevorsworth
    What are the odds that thing's even any good? I don't know anything about tachs. This will probably be my first car with working gauges. :D
    Sharpone, Stogy, 54delray and 9 others like this.
  19. Bugguts
    Bugguts
    Very cool car and story.
    I love the roll bar and how the owner made the rear spring mounts.
    Guys would laugh if doing it that way nowadays.
    hotrodharry2, Sharpone, Stogy and 4 others like this.
  20. Okie Pete
    Okie Pete
    Very Kool . The car is in good hands .
    Sharpone, duecesteve and trevorsworth like this.
  21. tubman
    tubman
    Almost nil. Back in those days, the electronics inside needed all kinds of weird voltages, so they had batteries in them to run the electronics. A little neglect and some corrosission and the insides were toast. You may have gotten lucky and someone removed the batteries. If so, I think at least one of them may be available Soviet military surplus. I am not kidding.
  22. trevorsworth
    trevorsworth
    Can someone help me understand the AHRA F/G cl***?
    If I'm understanding correctly, with a 255 cu 8CM, that would mean this car was 3,723 pounds?? It doesn't even seem possible to make a Model A that heavy lol.
  23. tubman
    tubman
    Your rules are too new. Back when I drag raced in the very early sixties, there were special (bottom) cl***es for flatheads and sixes. It was "D/Altered" and "F/Gas" in those types and "X/Dragster" for 4-cylinder machines. If that's what you had, that's the cl*** you ran.
    EDIT : There was also a "D/Dragster" cl*** for flatheads and sixes.
    Things were much simpler back then.
  24. Joe Blow
    Joe Blow
    Here's a good discussion on mid 50's to mid 60's cl*** designations being all over the place. Not sure of the date on this pic but you can see a 60 pickup in it.
    https://www.jalopyjournal.com/forum/threads/early-drag-racing-cl***es.61637/
    Okie Pete, Sharpone, 302GMC and 6 others like this.
  25. 1971BB427
    1971BB427
    from Oregon
    AHRA and NHRA had slightly different rules, so you'd need to find AHRA rules for the era it ran to know details.
  26. Hot Rods Ta Hell
    Hot Rods Ta Hell
    You absolutely HAVE TO buy the Flathead that goes with the car (even if it's too hot to run on the street and sits in your garage between HAMB Drag runs) and hopefully all the extra parts down to the walls and maybe the Anglia too. Especially if the prices are at give away prices like the Model A was!!! Take a truck and trailer and a friend or two and lots of cash (borrow the money if you have to). Hopefully there's some other small parts (gauges, etc) to the car stored there. Sell some of the unwanted stuff off later. This should be an Iron Trap Garage style buyout on the spot before he gets second thoughts and changes his mind.
    It's a killer find and deserves to be put back together the way it was ran.
    Ask the owner for photos (or at least make copies if he won't let go of them). Just maybe somewhere out there is some old footage from Green Valley or other earlier drags.
    Can't wait to see photos of the parts hoard.
  27. trevorsworth
    trevorsworth
    He feels that the real money is in the parts hoard and not in the individual cars... he knows what the engine is worth and I don't know if I'm ready to play in those leagues. But I'll do what I can and bring home what I can. I definitely don't have the capital for a buyout.
    He mentioned having photos. He seemed surprised, but appreciative that I was interested and committed to putting the car back and not just street rodding it. I hope he'll work with me on some of the parts to bring it back to what it deserves to be.
  28. RMONTY
    RMONTY
    I traded some guy some parts or something a while back and ended up with this old flathead out of a 49 dump truck I think he said. AND I have the hookup on upholstery work that is dirt cheap! Hmmm
    Sharpone, enloe, bchctybob and 4 others like this.
  29. Manostihl83
    Manostihl83
    Congratulations on the find man! Some people have all the luck! I’m jealous keep us updated! Love. Flathead v8! Hopefully someday I can get mine running and find something to put it in!
    Sharpone likes this.
  30. RodStRace
    RodStRace
    Sounds good to me, the more he understands you are not just going to haul off this junk but to restore it and save it's history, the better. Save stuff like this on your phone and show you are a good caretaker, not just a flipper.
    If it's too much to swing and you are comfortable with it, offer payments. I know that a lot of older guys are cash and carry, but this might work to keep the car together.
    https://www.nrhgreenvalleyraceway.com/history
    www.youtube.com/watch?v=Vkmy7untl0I
    www.youtube.com/watch?v=CnZ2iOS1Gx4
    www.youtube.com/watch?v=O8wVdxoPlmw
    www.youtube.com/watch?v=Yc_mWL-nmPw
    www.youtube.com/watch?v=y50PhqW5D_w
    www.youtube.com/watch?v=CVi0252-ofQ
    www.youtube.com/watch?v=c1kctMPjUYs
    4 across!?!
    www.youtube.com/watch?v=94j8QUzMWvA
    more 4!
    www.youtube.com/watch?v=DTLbzao2y88
    https://bangshift.com/general-news/...lost-drag-strips-in-the-history-of-the-sport/
