Technical Oil pressure sender for gauge and warning light
Discussion in 'The Hokey Ass Message Board' started by ActionYobbo, Dec 28, 2024.
  1. ActionYobbo
    ActionYobbo
    I am not sure what to get. I need a sender that will run a gauge and a warning light. I found a few online but I am asking here before I just try my luck and buy one.
  2. squirrel
    I've never seen one, but I've seen a 1/8" pipe TEE....
  3. TrailerTrashToo
    TrailerTrashToo
    The gauge and the sender must have the same resistance range.
  4. brading
    brading
  5. mark40h
    mark40h
    from quincy,il.
    Brading is right put a T in the block and you can run both. Resistance has nothing to do with it.
    Just Gary, Sharpone and Tim like this.
  6. A T will work fine, I have done it several times over the years.
    mikhett, Sharpone and loudbang like this.
  7. RodStRace
    RodStRace
    A sender for a gauge is going to be bigger, so it can provide a sweep of resistance. The light is a simpler on/off switch and smaller. A tee is the normal answer. You could get some fancy electronic gauge that has logic inside and when the pressure signal drops below a set point, it triggers a light. I don't know of this style being available. This typical kit with gauges and lights uses separate senders.
    https://www.speedwaymotors.com/Auto...ge-Panel-Oil-Fuel-Press-Water-Temp,29547.html
    Sharpone and ClayMart like this.
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'm curious as to why anyone would want both ?
  9. CSPIDY
    CSPIDY
    The advantage to having both a gauge and a light is for redundancy
    so as suggested use a tee for two separate systems
  10. RodStRace
    RodStRace
    Because a short amount of time not watching the gauge can be catastrophic. The light provides a warning to pay attention. Like a shift light for a tach.
  11. Depending on the engine, a lot of times there is another point in the oil galley where an additional sender can be used.
    Wanderlust, Sharpone and squirrel like this.
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
    On dirt track cars we used both /with a tee. And we put a brake light in the car so Micky could see it from the infield and eat you XXX alive if you kept running/or ignoring the op gauge. It wasn’t me but we had a driver that was just like Days of Thunder. He could drive but he wasn’t all that good mechanically.
    Mick later wired in a kill switch that if it dropped below certain level it would literally kill the car. ( remembering we were using a accel dual point and coil ). I don’t remember exacts but it wasn’t that complicated.
    Sharpone likes this.
  13. fleetside66
    fleetside66
    alanp561 likes this.
  14. 57Fury440
    57Fury440
    I have mine set up that way. My gauges are aftermarket and are under the dash, but I like to have my stock dash operate like it is supposed to.
    CSPIDY, Algoma56 and Sharpone like this.
  15. As recommended by the Department Of Redundancy Department.
    o_O
    CSPIDY and rattlecanrods like this.
  16. Sharpone
    Sharpone
    Why not? A bright red light will get your attention way before you notice the gauge heading to zero psi. I like both.
    Dan
  17. deuceman32
    deuceman32
    The red light serves as a great reminder to shut the ignition off as you are coasting to a stop with a brand new hole in the block.
  18. How about a Murphy gauge; set the pointer to switch on the light at the pressure you prefer; maybe keep the alarm too for an audio warning.
    alanp561 and Sharpone like this.
  19. Sharpone
    Sharpone
    I have thought about Murphy Gauges, many industrial engines and equipment run Murphys. They can be wired to shut engine off or turn on a light, also can wire to not allow engine to fire until pressure is reached, they’re reasonably priced and very durable.
    They make temperature gauges also.
    https://www.ebay.com/itm/276276766305
    Dan
    RICH B, squirrel and chevy57dude like this.
  20. nochop
    nochop
    from norcal
    treb11, tb33anda3rd, alanp561 and 5 others like this.
  21. squirrel
    I'd put the TEE on the engine, so when the sender starts leaking it won't be inside the car.
    alanp561, Kerrynzl, RodStRace and 5 others like this.
  22. TRAVLR
    TRAVLR
    from NC
    That is how we did my Dad's 57 chevy. He wanted the original oil pressure light in the dash to still work, but also have a mechanical oil pressure gauge for peace of mind.
  23. Budget36
    Budget36
    I did a google search for oil pressure gauge with warning light, many return hits on the search.
  24. nochop
    nochop
    from norcal
    I placed mine under the dash to reduce clutter in the engine bay.
  25. 2OLD2FAST
    2OLD2FAST
    from illinois
    Must be a whole bunch of inattentive operators out there ... Plus , likes been said , buy the time the light comes on , the damage has been done .
  26. ActionYobbo
    ActionYobbo
    Thanks for the replies.
    I lost my first cars engine to a bad gauge and no warning light. Drain plug fell out! I was scooting down the expressway and the engine started losing power. Gas gauge was close to empty and I thought I was running out of gas. Oil gauge showed 40 and temp was in normal. Engine locked up and gauge still showed 40 with the key on. I got the car like that. The previous owner installed some sport gauges and the warning light was not hooked up. That car always had 40 pounds of oil pressure.
  27. Budget36
    Budget36
    I don’t think inattentive drivers, but a light catches your eye if you’re not scanning the gauges.
  28. nochop
    nochop
    from norcal
    I think the idiot light will flutter under low pressure or low volume
  29. RodStRace
    RodStRace
    Ford has done this for a while. They had complaints about the pressure dropping after the engine warmed up which is normal. Rather than educate, they fixed the customer. They used the switch (not sender) to tell the gauge to go to half way. :mad: Sounds like yours got stuck too.
    nosford likes this.
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    F you're not scanning the gauges. You're an inattentive driver .
