Technical Early Hemi #2 (354 Hemi build thread)
Discussion in 'The Hokey Ass Message Board' started by 57 Fargo, Dec 29, 2023.
  1. 57 Fargo
    57 Fargo
    I can give them a quick shave to flatten them out while I’m waiting for valve guides
    AndersF and 427 sleeper like this.
  2. RodStRace
    RodStRace
    Back when we could buy chunky gas! :D
    Most surface cutters/grinders will leave a good surface for gaskets, but if you want to go the extra mile, select the head gaskets first and find out what surface finish they prefer.
    Example
    https://www.jegs.com/i/Cometic-Gaskets/245/C5211-045/10002/-1
    "A surface finish of 50 RA (roughness average) or finer is recommended for proper gasket seal"
  3. 57 Fargo
    57 Fargo
    Haha! Basically I finish everything cast iron to one finish. Hasn’t caused me a problem yet but you’re not wrong. I’m picking away at this thing as I can afford it. The crank should be done soon. The bearings are on the way, I’m going to make a call tomorrow to get the guides and exhaust valves coming. This way the heads will be done. I can then move on to the block, I can deck it and hopefully pistons will be soon to do the boring and honing.
  4. gimpyshotrods
    gimpyshotrods
    If you were close, I could CNC machine those heads to erase that damage.
    Unless it were a 354. In which case I just have a stack of good heads.
  5. 57 Fargo
    57 Fargo
    It is a 354, I’ll just knock down any sharp spots. Not overly concerned about that.
    Truckdoctor Andy likes this.
  6. hemiracer
    hemiracer
    113DEB38-31D5-4D25-8DE6-F4858CA22B19.png I think you need another 857 Fargo with 354 Hemi it’s in Ft Sask
  7. 57 Fargo
    57 Fargo
    Oh my!!!! Tell me much, much more!!
    427 sleeper likes this.
  8. hemiracer
    hemiracer
    I’ve owned for awhile, thought I would get at it , it’s complete in a storage yard. I race Bville with a 354 and thought I could use another. Don’t know condition of motor , never got that far.
    427 sleeper and 57 Fargo like this.
  9. 57 Fargo
    57 Fargo
    I sent ya a PM, the red envelope on the top
    right, I’m definable interested in it, even just the truck minus motor. Of course with is cooler yet!
    Truckdoctor Andy and 427 sleeper like this.
  10. silent rick
    silent rick
    cast iron boat anchor, i mean a cast iron boat/marine intake
    slayer, AndersF, 1biggun and 2 others like this.
  11. 57 Fargo
    57 Fargo
    Eek!! I would run one!
  12. silent rick
    silent rick
    I know you would
  13. silent rick
    silent rick
    edmunds 2x2 on my red ram
    slayer, bostonhemi, AndersF and 3 others like this.
  14. gimpyshotrods
    gimpyshotrods
    Me too!
  15. 57 Fargo
    57 Fargo
    Well these heads are determined to fight me, all was going well, until it wasn’t. IMG_5835.jpeg IMG_5837.jpeg IMG_5836.jpeg
    Got the first head set up in the surfacer, took 0.003” off and it cleaned up nicely, decided to take one more cut and at the very end of the head the table moved and a cutter caught the head and made a decent mess. I think it would probably be ok but I didn’t bother to take any pictures of it as I left in disgust with myself. Also broke two cutters so need to replace those as well. Not a good day.
    The table on the surfacer just rides on rollers, I think I moved it to far to the one side and it kicked the end up. Rookie mistake
  16. 427 sleeper
    427 sleeper
    We've ALL been there... :oops:
    Time for a good stiff ****tail :cool:
    bchctybob likes this.
  17. 57 Fargo
    57 Fargo
    I did call Hot Heads and order some parts though!
    bchctybob and Truckdoctor Andy like this.
  18. twenty8
    twenty8
    Awww man, that ****s. Some days are diamonds........... and some not so much.:(
  19. 57 Fargo
    57 Fargo
    Yeah, it’s the very end of the gasket surface, I think it would probably be ok anyways. I may have a line on another set of heads, @hemiracer is checking into some, and I know a guy in Edmonton may have some.
  20. hemiracer
    hemiracer
    955EF9FA-A7D5-4068-A7FA-50E28EF5EB9F.png What you really need for induction on your early Hemi. Would wake up the whole Peace country with this set up.
  21. 57 Fargo
    57 Fargo
    I do love multiple carbs!
  22. 57 Fargo
    57 Fargo
    IMG_5840.jpeg Yesterdays whoops. I think there is probably enough there to still seal fine…
  23. 57 Fargo
    57 Fargo
    Sometimes i really wonder about my intelligence….thats a head bolt hole its fine.
  24. SS327
    SS327
    Can’t like that. :(
  25. 57 Fargo
    57 Fargo
    Oh like away, I was too mad yesterday to look, the chunk missing at the end is by a head bolt hole. It will be perfectly fine, once I replace all the cutters on our surfacer I’ll skim a thou or two off to get rid of the other scratches.
  26. Beanscoot
    Beanscoot
    The truck 2 x 1 intake with weird carbs would be pretty cool, cleaned up:
    It would also fit (cover) the tall water ports in the head.
  27. 57 Fargo
    57 Fargo
    Yours?
  28. George
    George
    Om thehemi.com a guy started putting two 2GC carbs on one of those using 1 to 2 bl adaptors, his wife got sick & never posted if he ever finished the project.
    57 Fargo likes this.
  29. gimpyshotrods
    gimpyshotrods
    JB weld, not JB Quick.
    Fill up the grooves, and the shave it flat with a utility knife blade.
    It will seal just fine. No need to cut it more.
  30. 57 Fargo
    57 Fargo
    Oh yeah it would be fine, they look worse in the picture than they are. I bet 0.001” cleans it up. Just pisses me off.
    bchctybob and 427 sleeper like this.
