Checker cab
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Nov 22, 2024.
  1. RodStRace
    RodStRace
    For 700 you could buy a another battery, hold down, isolator to keep it charged, a little air compressor and a bunch of filters!:)
    porkshop, Sharpone and squirrel like this.
  2. squirrel
    or an in tank pump ***embly....
  3. gene-koning
    gene-koning
    Lots of other options with $700 to spend. A modern tank with an electric fuel pump option sure sounds like a better alternative, your not restoring the car, leave those expensive replacement tanks for the restorers.
    Sharpone likes this.
  4. squirrel
    I'm planning to add a modern efi engine soon, so I'll have to change the fuel system. Problem is the new pump won't work with the existing engine.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just checked in inTucson. Tomorrow Bisbee.
    porkshop and squirrel like this.
  6. RMcCulley
    RMcCulley
    Is it possible to use recirculating type fuel pressure regulator?
    Sharpone and porkshop like this.
  7. squirrel
    I'm kinda between Tucson and Bisbee...if you're able to take 90/92 towards Bisbee, and it's not too late in the day, swing by
    520 456 6428
  8. squirrel
    The efi system will use a recirculating pump, but it's a really heavy duty unit that puts out a lot of pressure and flow, and not what the little 6 would be happy with.
    Sharpone, porkshop and 41 GMC K-18 like this.
  9. miker98038
    miker98038
    When I put the SN2000 on my Yblock I used an Aeromotive fuel pressure regulator. I had a cheap in line electric pump I used to prime the carb. With the right spring and a boost regulated unit, it ran 4-5 psi to the Edelbrock carb, and ramped it up 4 psi under boost. When that pump failed I bought a pump “recommended “ by my dyno guy. It was a Bosch and said it would support 700 hp on a Porsche **x turbo (sorry, a long time ago). Worked fine. When I changed to EFI, I changed the spring in the aeromotive unit, and took the pressure up to a throttle body injector level. I did have a return line.
    Might be an easy, if not real cheap, answer.
    I recognized the shot of the Checker in the Walmart lot. I made a U-turn there trying to find the Native Wings on the other side of the road last spring.
  10. A Boner
    A Boner
    Atlas 4200 potential…if you want to stick with a 6!
    In 2025…what would Marathon have done?
    RodStRace, Sharpone and porkshop like this.
  11. Maverick Daddy
    Maverick Daddy
  12. squirrel
    The kustom version needs to chop about 8 inches out of the roof and section 6 inches out of the body!
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. squirrel
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Good thing this is the off topic portion of the HAMB
  16. Sharpone
    Sharpone
    Oh wow traded
    the Checker for a couple vettes
    IMG_2881.jpeg IMG_2880.jpeg Seems like a reasonable trade.
    Dan
  17. squirrel
    The black one is Jay Allen's. Of Broken Spoke Saloon fame. also races bikes at Bonneville.
    He also lives in the building with the Indian sign painted on it. And he bought the blue 39 Chevy from me 30 years ago, that's when I met him.
    A Boner, bobss396, porkshop and 4 others like this.
  18. T. Turtle
    T. Turtle
    I grew up in 60s-70s Israel and the things were everywhere, fitted with mighty British Perkins diesels with about 80 hp or so. We had a thing known as Service Cab which used to do intercity routes, it was more expensive than a coach but (very slightly) faster, spent hours in them going to and from school or returning from the navy base later. Always thought a modified one would make sense so watching this space to see what you'll do with yours...
    Pic is of one going from Jerusalem to Tel Aviv.
  19. squirrel
    Interesting, thanks!
    I got the new 10SI alternator installed. Now it charges with the right current and voltage.
  20. squirrel
    yeah, I fixed it
  21. Zuffen
    Zuffen
    from Sydney
    What an interesting way to run two belts.
    I ***ume you adjust the alternator first then the Power Steering Pump?
    I've never seen that before.
  22. squirrel
    Yeah, you adjust it like you said. Somehow it doesn't seem strange to me...but I've worked on a lot of different American cars from this era.
  23. 38Chevy454
    38Chevy454
    The 10SI is just such a simple reliable swap into almost anything. Low cost, reliable, fairly compact size and can be found anywhere. I even used a 10SI since I have such familiarity with them when I rewired my 37 Ford Ute with a SBF; made a custom bolt for the lower pivot since the Ford alternator uses a 7/16 bolt vs the 3/8 of the 10SI.
    You can find a complete rebuild kit for them for around $30 on ebay, and they are easy to rebuild. Get a free or $5 core at the swap meet, and you can have a new performing alternator for cheap.
  24. snoc653
    snoc653
    from Iowa
    I love the work they did to put a very subtle bulge in the rear fenders. That is a serious project your friend is working on.
  25. squirrel
    wow, there's a lot of work in that car! I noticed the Checker is just about as big as an old pickup truck...so I guess the diesel is a good choice for it
  26. squirrel
    Working on seats...since the kid who moved back home, used to work at a thermal seat place, they're experienced at working on new seats. This car has old seats. But I guess we'll see how it goes. New blue/gray vinyl to replace the original slightly bluish gray Naugahyde.
    Starting with the rear seat bottom, which is the "easy" one to do.
    Squablow, Thor1, 41 GMC K-18 and 14 others like this.
  27. squirrel
    The front seat is pretty bad, kid is practicing on the rear seat first...
    I'm making new door panels, too. At least the fronts. They were really badly water soaked and crumbling, although the vinyl wasn't too bad.
    Squablow, Thor1, rod1 and 12 others like this.
  28. Greg Rogers
    Greg Rogers
    Jim, have you ever used a old Speed-o-Stat Dana aftermarket cruise control? I bought some on eBay and used them years ago on a 65 Coronet and a 70 Vista Cruiser. Still have some complete units but will prolly never use. I think a lot of those were bought as Christmas gifts and ended up on a shelf for years. Then someone puts one on Ebay and it goes high- say $150. The 3 people see that and put theirs on- one goes for $130, 2nd for $20, 3rd for $5. That's how I got some cheap.
  29. SS327
    SS327
    If you get in the mood to dig one out and are interested in selling it, please PM me.
    Bill's Auto Works likes this.
