Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. patsurf
    patsurf
    how much a pound ?
    guthriesmith likes this.
  2. Sharpone
    Sharpone
    IMG_2871.jpeg IMG_2872.jpeg IMG_2878.jpeg IMG_2876.jpeg Started the rebuild on the Carter AFB for the dirt cheap Dart.
    Dan
  3. choptop40
    choptop40
    125.00 to 145.00 a ton..that beast was around 12,000 lbs...
    Okie Pete likes this.
  4. patsurf
    patsurf
    actually i was teasing about how much per for the dash!
    pila38 likes this.
  5. Gastrap
    Gastrap
    Working on adding a Gear Vendors overdrive to the back of the Torqueflite in my AD truck. I got pretty lucky on the placement of my crossmember and the choice of an 8 inch wide tunnel when I built this years ago, I certainly didn't have this in mind back then. Added a little welded in radius in the center of the frame for the drain instead of relocating the plug. This one has the optional deep sump.
    rod1, Okie Pete, pila38 and 5 others like this.
  6. swade41
    swade41
    from Buffalo,NY
    I've taken the last couple days off from working on the 57 p/u but the bed wood kit came in today.
    I wrestled the wood in the house and the stainless out into the garage, hopefully that keeps the wood from warping.
    I'm not sure what I'm tackling next on that bed, probably wire wheel and rust coat the areas that need it.
  7. Dick Stevens
    Dick Stevens
    If the wood does warp, you can straighten it out by putting in an environment that will bring the moisture to the level it currently is at, and you can prevent it from warping by keeping the humidity in the area it is stored in at the right level.
    Sharpone, Okie Pete, swade41 and 2 others like this.
  8. choptop40
    choptop40
    I think I have the speedometer housing dialed in....this is basically the setup I'm going with..tach just for speedo mockup..... PXL_20241231_222649480.jpg
    porkshop, lumpy 63, Sharpone and 8 others like this.
  9. atch
    atch
    @choptop40,
    Please post up pix when you get this all grafted together.
    Sharpone likes this.
  10. Paul
    Paul
    Editor
    adapter plates for blower manifold
  11. LOU WELLS
    LOU WELLS
    from IDAHO
  12. lumpy 63
    lumpy 63
    20250101_155901.jpg Cleaned and painted the Tempest control arms. Started installing the NOS bushings and ball joints
    porkshop, Okie Pete, pila38 and 14 others like this.
  13. lumpy 63
    lumpy 63
    20250103_135222.jpg 20250103_152920.jpg More progress today, my friend Tony blasted the cradle and I did a little welding and shot it with VHT ch***is paint.
    porkshop, Okie Pete, pila38 and 12 others like this.
  14. It sure makes it much easier to work on when they come out like that!!
  15. choptop40
    choptop40
    4 hours of shoveling snow.....Want to keep the driveway clear for somerhing that's getting delivered soon....hint hint..it has 4 wheels... c9e258e2-e0b2-4a17-bf06-9e06785d04fe.jpg 78a28785-63f3-495a-903c-af99bd77e2bd.jpg
  16. nochop
    nochop
    from norcal
    What am I working on? To many to list now that the body is back from paint IMG_7377.jpeg IMG_7482.jpeg
    porkshop, Okie Pete, pila38 and 23 others like this.
  17. saltflats
    saltflats
    from Missouri
    Can't tell if you are grinning or gritting your teeth. :D
    Care looks nice.
  18. nochop
    nochop
    from norcal
    Both lol
  19. HOTRODPRIMER
    HOTRODPRIMER
    Looks better every time I see it, it's gonna be a knock out my friend. HRP
  20. nochop
    nochop
    from norcal
    Thanks HRP!
  21. saltflats
    saltflats
    from Missouri
    I spent a day chasing a plug for my generator to aid for a power loss from the upcoming forecast weather. Took 5 different stops to fined what I needed all the other places were out, It's like a pandemic broke out around here.
    Hope all my effort wards it off.
  22. nochop
    nochop
    from norcal
    Fuuuuuuc! That’s nice
    Sharpone and mad mikey like this.
  23. swade41
    swade41
    from Buffalo,NY
    Cleaning up and painting brackets lately
    porkshop, Okie Pete, pila38 and 7 others like this.
  24. This blizzard has me staying in, hunkering down and studying wiring diagrams in preparation for a springtime thrash to attach the body, ***emble and wire up the '29AA. I'm just thankful that the storm came in as freezing drizzle, not freezing rain and an ice storm, which usually means days to hours of power outages. Woke up this morning to no power interruptions, so despite the heavy, blowing snow, all's good.
  25. saltflats
    saltflats
    from Missouri
    Blue sky garage is closed here for sure. Luckily no power outage here yet.
    porkshop, Okie Pete, Sharpone and 8 others like this.
  26. saltflats
    saltflats
    from Missouri
    I'm just about right in the middle of Missouri. 20 mile south of I70 on 63 south.
  27. James, Andy, it looks like this storm has shifted slightly from tracking just north of I-70 to about 15-20 miles south and heading almost dead east - right through you both, across southern Ill. Indiana, Ohio and eventually into W. Va. and southern Penn. I've got 2.5 inches of sleet here, my sister has 6+ inches of snow just east of the Country Club Plaza in K.C. and my son is just north of you, James, in Columbia. He says there's a nice layer of ice there, too, beneath the snow. I'm staying inside the next couple of days and studying wiring diagrams, trying to figure out how I'll route the tach wire from just above the driver's side window to the negative on the coil. Also trying to figure out the voltmeter wiring route from the stock dash to ???
  28. BJR
    BJR
    We have green gr*** and no snow here at my farm in sunny Wisconsin. :D Of co**** it was -5 F this morning.
  29. lumpy 63
    lumpy 63
    20250105_112247.jpg although the only work I did on this was to push it outa the booth, I thought you guys might like to see this. Still needs to be cut and buffed.
