Hot Rods whats going on with the front frame on this car???
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Dec 2, 2024.
  1. DuraGlide
    DuraGlide
    Since it already has the cross spring, I'd move the plate up between the tail lights and hang a polished quick change rear there the correct width to ease the rim search. Save a lot of work lowering the back and make it more interesting visually.
    ALLDONE likes this.
  2. Modern wheels have modern offsets
    Old style wheels don’t
    Can get different back spaces on some of these
    ALLDONE likes this.
  3. twenty8
    twenty8
    15X9 MATTE BLACK OEM FORD STEEL WHEEL WITH 5.25" BACKSPACE. DEDICATED 5-114.3 PCD
    anthony myrick likes this.
  4. twenty8
    twenty8
    16x8 is available as old style steel 5x4.5" bolt pattern with 5.25" backspacing (19mm positive offset).
    ALLDONE likes this.
  5. ALLDONE
    ALLDONE
    some time I chase a mistake around in circles..don't have a clue why I got 15'' wheels and tires....---+++++++
  6. ALLDONE
    ALLDONE
    anyway... been slowly working on lowering the rear....got it down 1'' probley 2'' to go still.. probley just get 8'' wheels for the rear...had to order a chrome lic plate frame ww/ a light...hopefuly that'll make the rear of the car easier on the eye... so slow progress,... still gotta cut the front shock mounts off and move them and the lights forward... got chrome shocks for it...this is one of those hotrods that you drive all you want...cross country would not be a problem..
  7. ALLDONE
    ALLDONE
    beings the car has so much chrome and yellow, thought I would just stay with that...it's just not the same try'n to fix a build as it is to start fresh..maybe they are just being nice,,, but most all that see the car say it looks good...maybe not a real traditional build... but sometimes not being like everyone else works for me....it is what it is....
  8. ALLDONE
    ALLDONE
    I've been packing away at this...lots of work with no visual progress.... lots of ground issues as usual.. but now every thing works with no issues...put the new exhaust, and cut off the shock and head light mounts and lowered them and moved them forward...put chrome shocks and turned the exhaust out in front of the rear tire... shes getting there...
    369482075834887953[9493].JPG 835547418695113739[9497].JPG 2835970908180168850[9496].JPG 3116826337557420240[9494].JPG 4710087933497271325[9488].JPG 5426331601090688730[9491].JPG 5781438063806969855[9489].JPG 6342778460703155095[9486].JPG 6546107735143475641[9495].JPG
    Deutscher likes this.
  9. ALLDONE
    ALLDONE
    the exhaust is magnaflo 2 1/4''... custom made hangers and out in front of the tires...had to order a chrome lic plate frame with a light from so cal... no one in vegas had one in stock.. I think it will make the rear look better when the plate is up where it goes between the tail lights...
    my home made welder spent all day working on pop's roadster....
    hotrodjack33 likes this.
  10. ALLDONE
    ALLDONE
    got to go get paint matched... and think I'll put 15 x 8's on the rear... they don't make a positive offset wheel but they do have a zero... that'll bring the tires in a little more
    this roadster is a treat to drive... lots of power and no rattles that and unbelievable smooth ride... the new shocks front and rear added to the road force balanced tires made a nice difference
  11. ALLDONE
    ALLDONE
    they mounted the hood with dzus fasteners.... another "nobody in town" item....I ordered some and they came in yester day... also ordered a 40 ford steering wheel... they come black... trying to figure if I should paint it yellow or tan to match the seats.... or just leave it black... that and if I should change the interior to black...????
    so comments welcome on that idea...I know everyone here hates the wheels... I love that...
    again,... re do's are tough... gotta work with what cha got..
    369482075834887953[9493].JPG 835547418695113739[9497].JPG 2835970908180168850[9496].JPG 5426331601090688730[9491].JPG
  12. ALLDONE
    ALLDONE
    how it looked when I got it...I didn't like it... so I changed it...most would have just left it... the head lights really bothered me, that and the big mickys on the rear... the rest has been clean and repair..
  13. ALLDONE
    ALLDONE
    also wondering... where can you get the pie plates for square spindles.... the plate that goes on before the rotor on the front brakes???
  14. tim troutman
    tim troutman
    Pete and Jake's Super Bell Finned Backing Plates 1130-P These may be what your looking for as a friend of mine once said " those almost make disk brakes look good almost"
    ALLDONE likes this.
  15. ALLDONE
    ALLDONE
    thanks a zillion for the reply... thats what i want...
  16. ALLDONE
    ALLDONE
    I have 4 hole square spindles....P&J is round
  17. ALLDONE
    ALLDONE
    Being fact that I don't know **** about these ol cars, or how to work on then, I still would like to know what I do have...now this is just a guess, I've CRS real bad and going back 30-40 years I draw a blank.... but... my guess is this car has a 55-64 chevy p***, car rear end..???
  18. ALLDONE
    ALLDONE
    and... are these 46-48 ford front spindles??? they are square and not round where the brake mount plate goes
  19. ALLDONE
    ALLDONE
    my thinking is the square started in 42???
  20. Fordors
    Fordors
    Correct, they are most commonly called '42-'48 spindles. Also, the king pins are a 1/2" longer so are not a direct interchange with the '37-'41's.
  21. ALLDONE
    ALLDONE
    so the axel is also 42-48? aren't they wider???
  22. Fordors
    Fordors
    From the photos your axle could be Model A through 1936. The height of the spring perch bosses on the axle will be 2 1/4” on an A axle, and 2” on the ‘32-‘36 axles.
    For me the easiest identifier for spotting a ‘37 and later axle is the shorter distance between the spring perch bosses and the king pins.
    Model A-‘36
    ‘37-‘48-
    ALLDONE likes this.
  23. ALLDONE
    ALLDONE
    thank you,... I have 2-29's 2-31's and a 32 at this house and they all are about the same A-36
  24. Mart
    Mart
    I think the car looks a lot better now. To my eye there is just too much yellow. Too much street rod 80s monochrome. I'd lose the yellow on the front steering parts and hubs. Maybe other things like the back axle. The yellow on the engine is also too "look at me" for my taste.
    But in reality you have a pretty nice car that runs and drives and was built to a high standard. It is what it is. Enjoy it.
    Edit: Spindles do look like 42-46 "squareback". Axle looks like a old school dropped 33-36.
    Mart.
    ALLDONE and dwollam like this.
  25. ALLDONE
    ALLDONE
    i'm with you on the yellow...it's growiing on me alittle, but slowly... what about the rear ,...55 chevy?? I put new chrome shocks so far..
  26. ALLDONE
    ALLDONE
    one thing for sure... i'm going over ever square inch of this car.... look at this pic, and if you can blow the pic up and look at the spring....the whole spring stack is all to the driver side... they never put a long spring bolt through the stack.... so when I took the 4 nuts off the the spring clamp.....they are all just laying on top of each other and all pushed to one side.... like I said, I will make a car out this pile of bolts.... and one I can trust knowing that it's right... and be satisfied when I have looked and put a wrench on every fastener...and made sure it's done proper... the front axel was 3/8 farther to one side, my thought was ... how could that be???? till I saw that there was no bolt coming through the bottom spring clap....with any of these old cars...I never ***ume it's right... I check to make sure
  27. ALLDONE
    ALLDONE
    Some things you can't use the "THATS GOOD ENOUGH" and this is one of them... that bolt has to be in there to center the front suspension, and keep it centered.... who the hell would think that it's not needed???? again.... I will make a safe and reliable car out of it...
  28. ALLDONE
    ALLDONE
    I don't know nothing about anything,... but heres what happens without the bolt....
  29. Shared off in the wreck?
  30. ALLDONE
    ALLDONE
    I have been busy, moved the shock mount forward and the lights forward 4'' ... got some paint matched and been toughing up all the paint chips,,,,new exhaust to clean up the clutter underneath, removed the lic plate bracket..., waiting on the new one from So Cal speed.. I think it's looking better... slowly.... still alot I wanna do... the oil pan needs polished... hope I don't have to take if off....but might be nice to see what I got...motor runs good and strong,,, so I should be able to fuc that up with just a 1/2 in socket...
    oh, and new right size shocks front and back...the wire hanging down is the power for the lic plate light...
