Folks Of Interest The Andy Southard Archive
Discussion in 'The Hokey Ass Message Board' started by Ryan, Jan 2, 2025.
  1. Ryan
    Ryan
    ADMINISTRATOR
    Ryan submitted a new blog post:
  2. Spooky
    Spooky
    I am still enamored going through the books of his photos that were released years ago.
    chryslerfan55 and hrm2k like this.
  3. rob-redm
    rob-redm
    love his books.. I wish he was still with us... what is happening with his archive ? @Ryan
    Spooky, chryslerfan55 and hrm2k like this.
  4. hrm2k
    hrm2k
    Don’t sell yourself short @Ryan . You are your own worst critic. I would think Andy Southard was as down on his photos as you are about yours.
    Your photos are all eye appealing to everybody except you. Quit beating yourself up !!!
  5. downlojoe33
    downlojoe33
    Andy Southard’s was the first byline I remember from my early days of reading the little pages, then the bigger ones. Maybe because of his unusual last name? But now I know it was because of his photography and writing skills. He was top of the heap on both fronts. And his green 56 Ford Victoria has always been one of my favorites. The man had an eye, no doubt.
    hrm2k and chryslerfan55 like this.
  6. downlojoe33
    downlojoe33
    And a great pinstriper to boot.
  7. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Andy is a legend.
    His works, books are a must.
  8. Russ B
    Russ B
    I started noticing Andy’s photos in the late 1950’s or early sixties, in the little books I talked my folks into buying for me. I finally met Andy at the fiftieth GNRS in San Francisco’ Cow Palace. I bought most of his books then and there, and he autographed them for me. It is truly impressive all he has done, and a nice guy as well.
  9. proartguy
    proartguy
    from Sparks, NV
    The well posed photos he had in magazines captured the era.
  10. southpaw-customs
    southpaw-customs
    Check out Speed and Kulture on Youtube. Trent Sherrill has been putting videos together with Andy Southard's collection.
  11. 302GMC
    302GMC
    from Idaho
    The stuff in the background of Andy's pictures usually is of as much interest if not more ....
  12. Nads
    Nads
    from Hypocrisy
    Where would we be without him?
  13. HEMI32
    HEMI32
  14. autobilly
    autobilly
    I believe Speed & Kulture have permission from Mr Southard's estate to access his complete archives.
    This is really great stuff and highly recommended viewing.
    chryslerfan55 and HEMI32 like this.
  15. HEMI32
    HEMI32
    Correct . . . @SpeedandKultureTRENT Sherrill has been working with Andy's widow, his son, & his daughters to preserve the archive.
    chryslerfan55 and autobilly like this.
  16. stuart in mn
    stuart in mn
    Did Andy do his own darkroom work? If not it must have cost him a fortune for photo processing...that's one big difference in the modern digital era, you can take as many photos as you want.
  17. Ryan
    Ryan
    ADMINISTRATOR
    I asked Andy about that during my interview. This is from my notes:
    Question: Do you do your own development? Make your own prints?
    Andy: Off and on, yes. In the very early days, I used a lab. That got expensive and I quickly learned to develop my own film and make contact sheets, prints. Through much of the later 50's and all through the 60's and 70's, I mostly did my own dark work. Of course, most of the published works were printed from my negatives.
  18. jnaki
    jnaki
    Hello,
    When getting started in the dark room setting up, one has to see where all of the items will go. I had unlimited space in my apartment garage on one side of the wall space. With one red El Camino in place, there was room galore on the other side of the floor space. Yes, someone will say the garage is not air tight and darken enough to have a darkroom. That is not true.
    Yes, if one had a 4 wall room with one door and a concrete floor with running water and a drain, that would be great. But, in most houses and apartments, that description is the bathroom or kitchen. Which are used constantly… so, one has to get creative.
    Once the developing table is made and there is room to place the three trays, now the rest is easy. The cost for the sturdy table can be had from the local big box store or 2x4 + 4x4 + some 1 inch finished plywood. The smooth surface can be sanded and coated or sealed with some surface coverings. I opted to use a nice coating of resin and color swirls to get a nice smooth surface like a surfboard that was impervious to spilled drops of solution of sorts.
    Then once the table workplace was set, the garage now needed to be sealed up. No garage is going to be air tight. It needs breathing screens and such to meet codes. But, one can make small sealed wooden plates to fit into the screened areas to make them light tight. You won’t be in there for long hours so no damage to the air circulation will harm the garage parameters.
    The door is the biggest light giving source, so the edges have to have a rubber flexible seal all around the inside edge. When closing the door, the rubber edge will seal the light producing opening all around the edges. Creating a “dark room.”
    As far as running water, sure, if you have a source in the garage, use it as well as the drain. A table to run one last wash tray is necessary, but not always handy. So, make provisions for using the spare bathroom facilities once you are finished with the first two developing trays. It is not necessary to have a three tray area with access to running water.
    I developed my black and white prints, then once I was ready for the washing, I took over a small apartment bathroom and had a flat wooden surface to allow the developing tray get water and drain into the sink drain opening. As that was going on, I could take a break for a snack or talk with my wife. Ha!
    The neat thing was the initial cost of developing cans, reels, trays, fluids, enlarger and lenses and the table were all a part of the program. Within weeks of selling several orders for photo prints, the cost was absorbed within the whole process. Now, for future projects, everything was virtually free.
    The color processing was done by Kodak labs. They are the best and fastest. Once the color slides are chosen, out they go and within several days, a nice color print is on our door step or pick up at the camera store. Labs are/were good for this difficult process and set up. So, there was no need to set up a second section for chemicals and processing stuff.
    Jnaki
    As far as reels for the black and white film developing, there is a HAMB post to show what was used. Practice, practice using a long 35mm film strip inside of a light tight bag will allow you feel how it is done and that you can do this anywhere in the house or garage. Even in the back of a 1940 Ford Sedan Delivery, if needed. But, on location, I used the back of the sedan delivery with a bag and changed my new roll of film in any of the cameras that needed it. light tight and access to all camera’s rear opening film reels.
    If you progress to larger film format, then of course, a second set of reels would be necessary. Same cans, but larger open reels for the larger film format. And a larger film slide in for focusing the enlarger through the film negatives.
    Note:
    The developing table for the enlarger and trays are one in the same. Move the enlarger over to accommodate the three developing trays. When we moved to a small house from our apartment, one small laundry room with a water source and drain was all that was needed. Once side was the modified bench to fit the small room and the other was the new small sink and washing station. The window and door got the “sealing” treatment and there were even shelves to store the trays and developing products. All in a dinky laundry room that was wide enough for a washer and dryer later on in our journey.
    My philosophy is the larger the room, the more space for dust gathering. And we know that minute particles of dust are the “blems” of photos and yes, digitally can be taken out, but why? Why not prevent them from the negative to print stage in the first place? YRMV
  19. stuart in mn
    stuart in mn
    I took a black & white photo developing cl*** in college. It was a lot of fun and I think I had a certain amount of talent for it, but it is an involved process - the school had a nice lab with all the equipment and chemicals (and we got to do as much film as we wanted as part of the tuition) but going on and setting up my own darkroom was more than I was willing to do. I remember taking pics of a vintage Minneapolis-Moline tractor and some motorcycles, but sadly no hot rods or customs. :)
  20. Kevin Bennett
    Kevin Bennett
    Please remove these links.
    Please be advised that Mr. Sherrill is no longer curating the archive. Furthermore, the family has retracted authorization for these materials to be shared digitally; therefore, archive contents are not permitted to be hosted online at this time. We appreciate your prompt cooperation in removing these items and updating your records.
  21. HEMI32
    HEMI32
    @Kevin Bennett -
    Yes, I read the "HAMB Conversation" you sent me earlier this week . . . but hadn't got around to replying to you.
    I'm curious why are you so concerned about the hyperlinks in my post? . . . if you actually click on them, they take you no where near the (now defunct) "Andy Southard Jr. Archive" (which was previously maintained by Mr. Sherrill).
    Are you providing legal representation for Patty Southard and/or the Southard family? . . . or did you purchase the archive from the family? . . . and plan to:
    • Make $$$ off of Andy's historical Rod & Custom photographs / DVDs by selling them piecemeal on the internet (i.e., eBay or other auction site)
    • Donate the archive to a museum (e.g., the Museum of American Speed in Lincoln Nebraska, the Petersen Automotive Museum in Los Angeles, etc.) for a sizeable tax write-off.
    • Share his photographic archive with the m***es on the internet … perhaps behind a paywall that would allow one to download non-watermarked images (à la the Petersen Digital Archive and the Revs Ins***ute Archives websites)
    If its that latter, I'd be more than happy to update my post with links to "advertise" your new "Andy Southard Jr. Archive" website and/or social media sites.
    - @HEMI32
  22. Ahh yes, the late great Andy Southard. That man took more photos than people have teeth ( if you don’t believe me, look it up) . Every once in a while HRM would put one of his pictures on the last page of the magazine.
    RodStRace likes this.
  23. Royalshifter
    Royalshifter
    Moderator
    I miss the videos I thought they were so important to continue the legacy of Andy and so well done by Trent.
    Money was donated from me and my wife on multiple videos to sponsor and help preserve Andy's lifetime work and we feel used in some way.
    Anyone else donate to this cause?
  24. bchctybob
    bchctybob
    So, again, no further response from Mr. Bennett. Someone on the other thread suggested that Andy Southard’s widow might have been advised that there is financial gain to be made from the archives and perhaps obtained legal counsel. I hope they are acting in her best interests and that the archives become available to the public again, if this is the case. These short, cease and desist comments feel very “lawyer-esq” to me.
    chryslerfan55, HEMI32 and SS327 like this.
