Projects Chopped sun visor?
Discussion in 'Traditional Hot Rods' started by carz, Jan 2, 2025.
  1. carz
    carz
    from colorado
    My '28 A is chopped 3' and I cant see much out my windshield. I was thinking of chopping the sunvisor about an inch. Has anyone ever done this? I've searched for pictures and only see some with hole, which I dont want to do that.
  2. alchemy
    alchemy
    Probably easiest to just put the break in the top edge a little farther down, and trim the excess off. Would take a bit of t******* on the sides too, and maybe redrill the mounting holes in the body up higher.
    A couple hours work, then paint.
    -Brent- likes this.
  3. KevKo
    KevKo
    from Motown
    If your Model A is chopped 3 feet, you can take the visor off and you still won’t be able to see out of it. I’m just joking with you. I know you meant 3”.
    deadbeat likes this.
  4. 325w
    325w
    Maybe find a Murray body header.
  5. pecker head
    pecker head
    30-31 Visor is shorter.
    dirt t, -Brent- and 46international like this.
  6. pecker head
    pecker head
    IMG_5012.jpeg My 28 chopped 5” with 30-31 visor.
  7. Is it? I did not know that, thanks. I was thinking the chop on the car in question is 3" while my '30 Tudor is cut 4" and it is not too bad to see out of.
    Wonder if the O.P. could do something with the seat mount to get it just a little lower... just a thought.
    pecker head likes this.
  8. Unkl Ian
    Unkl Ian
    Do a test in cardboard, to verify vision before cutting.
  9. Definitely digging that coupe
  10. 5window
    5window
    My '31 coupe is chopped 3.5" and I don't have an issue with vision but I am only 5'8". I do use one of the stoplight prisms in case I am first in line at the light
  11. alchemy
    alchemy
    Also a difference to note, the 28-9 visor is mounted under the header eyebrow (lower). The 30-1 visor is mounted up high and level with the top.
    Budget36 and jaracer like this.
  12. Unkl Ian
    Unkl Ian
    Could try a slightly different angle.
    If you have to cut the stock visor, take the material off the back.
    marioD, BJR and Budget36 like this.
  13. carz
    carz
    from colorado
    Great ideas!
    Thx.
