Projects 32 make over started
Discussion in 'The Hokey Ass Message Board' started by pantodd74, Jan 3, 2025.
  1. pantodd74
    pantodd74
    So the make over on our 32 has started. It's been in it's current condition since 60 or 61. The motor leaks like an old panhead and the clutch is slipping. The suspension is worn out and the electrical system is piss poor. I will be posting a long as things happen. I will post pic's as soon as I remember how to.
  2. Robdski
    Robdski
    Wishing you great success with the redo!
    mad mikey and Tow Truck Tom like this.
  3. nochop
    nochop
    from norcal
    Good Luck. I’m doing mine now
  4. sdroadster
    sdroadster
    The look is illusive. Beware of the temptation to purchase ready made street rod parts.
    Outback, G_Don, tb33anda3rd and 3 others like this.
  5. nochop
    nochop
    from norcal
    Post some pics…..we love pics
  6. nochop
    nochop
    from norcal
    GuyW, catdad49, billyt and 52 others like this.
  7. deathrowdave
    deathrowdave
    from NKy
    If she ain’t leakin better check da oil , she needs a bit ! ( Panhead )
    Outback, Okie Pete, SS327 and 3 others like this.
  8. pantodd74
    pantodd74
    So the engine is ready to come out as soon as I locate the chain for the cherry picker. I crawled under the back to remove the drive shaft and took a real good look at the back end. What I saw was an oldddd home made 4 link set up. The bars have eye bolts welded in and the nuts on the bracket bolts holding them in are back welded. Tiny little coil springs on top of the axle tubes with old worn out shocks. I will take pic's of the old school mess tomorrow. Also noticed the p***enger rear wheel cylinder is leaking as well.
  9. pantodd74
    pantodd74
    Vic Walter, mvee33, EVL401 and 11 others like this.
  10. Mr48chev
    There is always that "one more thing I found" going on when you dive into a project. That will be a nice one when you get done again though.
  11. pantodd74
    pantodd74
    It's like any project. You always open that bag of worms that keeps diving into your pocket. But it will be brought back into the 2025 year of parts and mechanical running order. The wife wants an auto trans installed. So I'm gonna find out what it's gonna take to make it fit in place of the T-10 transmission. The floor is a sheet of plywood cut to fit. I'm pretty sure the turbo 350 is longer than the T-10 trans. If I have to turn the plywood into sheet metal that's not an issue. I just want a safe and reliable car that she can enjoy when I'm not in the p***enger seat. She will be getting her hands dirty and will know all the basic's to get home in case of an issue.
    Toms Dogs, GuyW, Kiwi 4d and 8 others like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I believe what we see, is a rescue.
    Good on you Sir
    :D
    Outback, osage orange, nochop and 2 others like this.
  13. mad mikey
    mad mikey
    Make her great again. Enjoy, and keep us posted.
  14. pantodd74
    pantodd74
    20250104_125402-1.jpg So it appears to have a 9" rear end. Here are some more pic's. 20250104_125439.jpg 20250104_125521.jpg 20250104_125521.jpg
  15. alchemy
    alchemy
    Isn’t that 57 Chevy?
    Make your photos full size, not thumbnail.
    Toms Dogs, 49ratfink, dumprat and 6 others like this.
  16. pantodd74
    pantodd74
    Not sure alchemy. It has a center section just like the 9" in my Chevelle.
  17. glennpm
    glennpm
    Sure is a '56 '57
  18. jaracer
    jaracer
    There's always a Powerglide.
    Outback and Okie Pete like this.
  19. DuraGlide
    DuraGlide
    There is a short shaft turbo 350 and a long shaft version. The short shaft is the same length as the T10 and bell housing. Short shafts were for Camaros and Novas while the long shafts were in Impalas and trucks. I'm looking at doing the opposite swap in my 34.
  20. pantodd74
    pantodd74
    Glennpm what are the indicators I should look for on the rear end? Also DuraGlide according to the internet the 350 with 6" tailhousing is 27 something inches long and the T10 is 24 something.
  21. alchemy
    alchemy
    Are the flanges where the backing plates bolt on squareish, or round with the top sliced off?
  22. pantodd74
    pantodd74
    Doing some research it appears to be a 57 Chevy rear end. The 55 and 56 didn't have the drain plug. I will have to clean the tubes to find the numbers to know exactly what we have.
    Okie Pete likes this.
  23. pantodd74
    pantodd74
  24. ALLDONE
    ALLDONE
    thats a 55-64... check for posi... they were real liberal back then...if you a 9'' the 3rd member hangs below the 2 nuts.... so if you can put a ratchet w/ extension on the two bottom nuts it's not a 9
    19Eddy30 likes this.
  25. ALLDONE
    ALLDONE
    if it has weld marks for spring perch... it's pre 58
  26. ALLDONE
    ALLDONE
    looking closer, looks like weld marks where they cut off the control arms... so now i say 1958-1964
    Vic Walter and Outback like this.
  27. pantodd74
    pantodd74
    IIRC it is a posi unit after doing a small burnout and leaving to tire marks. I'm gonna have to pull the body so I can get in there and take measurements before I cut out all the old suspension and prep it for new 4 link set up.
  28. RodStRace
    RodStRace
  29. Corn Fed
    Corn Fed
    Look on the front of the dropout. If there is a large P cast into the driver's side, it's a posi.
  30. HOTRODPRIMER
    HOTRODPRIMER
    Having put thousands of miles on my old '56 Panhead I know exactly what your talking about, but I always used the ****ogy that my bike doesn't leak it just marks it's spot! :D HRP
