Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. 31B'ville, Is this the current stage of your Project?
    31chevymike likes this.
  2. 31 B'ville
    31 B'ville
    from SE Pa
    No, it was a running car until several months ago. It is now stripped down to the frame for detailing, painting, and final ***embly.
    Not trying to hijack this thread, just sharing my experience. IMG_7703.jpeg IMG_7526.jpeg IMG_8998.jpeg
  3. Jay Altemus
    Jay Altemus
    I think it looks great. Well done.
    31chevymike and 31 B'ville like this.
  4. Jay Altemus
    Jay Altemus
    Got more of the floor framed today. I’m pleased with the results. I pie cut and then welded a dog leg at the very rear of the beam that forms the door threshold. I got the angle nearly perfect. I test fit it and then made a copy for the other side.
    These are currently just clamped in place so I can fine tune the position.
    The B pillar will be supported right about where the dog leg bends to line up with the rear beam.
    IMG_8091.jpeg IMG_8094.jpeg IMG_8095.jpeg IMG_8101.jpeg IMG_8100.jpeg IMG_8110.jpeg IMG_8111.jpeg IMG_8115.jpeg IMG_8114.jpeg IMG_8098.jpeg IMG_8096.jpeg IMG_8092.jpeg
  5. Jay Altemus
    Jay Altemus
    My good friend bought a 1934 Chevy 1.5 ton truck October 2023. A few months later he bought a partial wood kit for the cab of that 34 and the guy said he could make the wood kit for my 34 Master coupe. Here’s the contact info.
    Cl***ic Wood Products
    1006 N Raleigh St.
    Greensboro, NC
    27405
    336-691-1344
    My friend said to talk to Ricky.
  6. Jay Altemus; Thanks for the contact info. I will contact him first of next week.
  7. The only piece of wood that I bought for my '31 - the main floor from Auto Wood Restoration, way back in '95. I've been wanting to replace the window regulator wood boards (and regulators), which are badly in need to be replaced, to no avail. Possibly the wood for my roof would be a future acquisition down the line. Here's that link that Jay had provided for us from his buddy's '34 truck:
    Wood Parts - Cl***ic Wood Products Llc
  8. Jay Altemus
    Jay Altemus
    I tack welded the floor beams together and I’m happy how things lined up. See video link below.
    Since I’ve never done anything this extensive, I need some guidance. How do I go about attaching the flooring pieces to the ch***is? I think the original wood was bolted to holes in the upper flange of the frame. I’m thinking I will need some sort of body mount bracket with bushings. Here’s a video of my work from today. LINK HERE
  9. Jay Altemus
    Jay Altemus
    I tested my metal fab skills today. If I get a report card it will be a C+ for rocker fabrication. I’ll make a second attempt another day. I sure wish I had a planishing hammer.
    Anyway, today’s finished product would be acceptable, but I’m thinking I can do better. Here’s the video. VIDEO LINK
  10. Back when I did the 34 I used 2"x3" 3/16" wall rectangle tubing for the main sub rail. This shows the sub rail and Apost with the new door hinge pockets. You can see both sides as well as other stuff. Don't know if that helps or not. I made standoffs and welded the to the outer side of the rails then took a 1/4" drill and went through the sub rail and standoff for a pilot hole. Next, I did a 1" hole saw through just the top of sub rail and a 3/8" through the rest for body to frame mount bolts. Once the floor pans were in place I used a 1' plastic plug to cap the access hole.
    Couple photos of the Door inner structure also. Feel free to ask about anything you see. I think I remember most of it and I have other photos. This is a 34 Standard 2 door sedan. If anyone is in need, I have a full door wood kit for both doors available.
    34 Chev door jambs 001.jpg 34 Chev door jambs 002.jpg 20160712_090606.jpg 20160712_090747.jpg 20190304_165629.jpg 20190307_140443.jpg
  11. Jay Altemus
    Jay Altemus
    Thanks PnB. I am not 100% sure I know what a sub-rail is. I’m still learning how to decipher terminology used when building a hot rod.
    I did a little internet search.
    Is a sub-rail the same thing as the beam(s) that form the floor framework?
  12. Yes. Go to the very top photo in the 6 I posted above. The new iron that the A post is welded to and p***es to the rear of the car through the actual door opening is the Sub-Rail. There's one on each side and starts at the firewall and goes to where the rear kick up starts. As I said prior, there is Zero wood in this car. I believe in stock form that piece was 2"x8" solid beam and everything mounting to it was mitered into it and screwed on.
    31chevymike and Jay Altemus like this.
  13. snoop74
    snoop74
    Okie Pete, Tim, PA Gas and 5 others like this.
  14. Jay Altemus
    Jay Altemus
    Sometimes you get lucky. Today was my day.
    Just bought this for the coupe. I’m thrilled. I sure hope it looks as good on the coupe as I have pictured in my mind.
    IMG_8251.jpeg IMG_8250.jpeg IMG_8252.jpeg IMG_8253.jpeg IMG_8254.jpeg IMG_8255.jpeg
  15. snoop74 likes this.
  16. snoop74
    snoop74
    Thanks! I’m going to try and shoot it Saturday. I’ve been sanding on it, 133 louvers or so giving me finger cramps
  17. snoop74
    snoop74
  18. Jay Altemus
    Jay Altemus
    No. I have a 1965 SBC 283 bored 0.060 with a 268H cam. Not a lot of HP but should be just right for this coupe. This new purchase will serve as a hood ornament if I can’t use it as a radiator cap.
  19. snoop74
    snoop74
    I don’t know if the old radiators were pressurized , so idk if that’ll work if you have an aluminum radiator ? Mine is just an ornament too I run a big washer under it to keep it in place. IMG_0326.jpeg
  20. tb33anda3rd
    tb33anda3rd
    the old original radiators were not pressurized. I have a new radiator with the cap under the hood and have the mascot bolted to the shell also.
  21. snoop74
    snoop74
  22. Jay Altemus
    Jay Altemus
    I had to resort to hammer forming to make this rocker piece the correct shape. Prior attempts using my sheet metal break and shrinker failed.
    I could make the bead the correct shape by making very small bends every 1/16 inch with my sheet metal break, but the piece was completely straight. Then when I used the shrinker to make the piece convex, it would cause the bead to flatten. So that didn’t work.
    I decided to fabricate a dolly/anvil using strips of quarter inch square rod. I laid the rod inside the original rocker to make a crude mold.
    I then welded things together and ended up with this dolly/anvil that works very nicely. I don’t hammer directly on the dolly. The dolly simply is a form that the metal wraps around.
    Here’s a short VIDEO LINK.
    Okie Pete, Tim, snoop74 and 4 others like this.
  23. Jay Altemus
    Jay Altemus
    Subframe ready for paint.
  24. brokedownbiker
    brokedownbiker
    I don't post much but I figured this might help somebody out if they're building a '31.
    I've been trying to locate some decent rear fenders since I got the car (a year and a half). Well I finally broke down and bought some new re-pops. They were on eBay and they were pretty pricey so I was hesitant but after two sets of old originals I bought sight unseen (long story-worse shape than my originals) and a set of Speedway fibergl*** rears listed as fitting a 32 (I was told they should have fit- not even close) I bought them and crossed my fingers. Before they arrived I went into the hospital for some replacement parts of my own so I didn't have a chance to check them out when they arrived.
    Finally healed up enough after my knee replacement to hobble out to the shop for an hour or so every day and unboxed them yesterday. Wow. I'm impressed, they are are very well made, everything lies up and matches, they even have the raised bead around the perimeter. The pic shows the right side fender beside a damaged and butchered original fender (one of the collection I ended up with).
    Now it's time to get back to it- I have a couple of small rust repairs to do on the front fenders and then I can start prepping for paint- I really want to get them done and installed for the spring, I've been driving it as it is in my avatar pic since I got it on the road.
    Just thought I'd share, I don't get online very often but really enjoy the HAMB and this Bowtie group especially, there are some seriously talented folks here!
  25. Jay Altemus
    Jay Altemus
    I’m also impressed with what you bought. Can you share the name of the eBay vendor?
    Thanks for sharing your success story.
    31chevymike and Tim like this.
  26. Jay, I believe that vendor could only be AMMUSCLE at American Muscle Car Parts | eBay Stores. My only regret is that the company seems to be content with supplying mostly earlier Chevrolet repro parts in steel, and ignoring the need for mid '30s Chevrolet's, not recognizing how much MORE popular that Chevy cars have been lately! It might be worthy to contact that company and state your case to an ever popular market that is FINALLY growing - I'm happy to see this much more now than when I first bought my '31 in the mid-nineties!
  27. Jay Altemus
    Jay Altemus
    I made 2 rocker pieces a little over a week ago by hammer forming. Today I joined them and I’m pleased with the result. It’s pretty darn close to the original. Here’s a video with some of the details. VIDEO LINK
  28. Six Ball
    Six Ball
    from Nevada
    That is some impressive work! Very well done.
    31 B'ville and Jay Altemus like this.
  29. brokedownbiker
    brokedownbiker
    Hi Jay, here is a link to one of the fenders, all the info is there-
    https://www.ebay.com/itm/276691540355
    Jay Altemus likes this.
  30. Jay Altemus
    Jay Altemus
    That’s a very nice fender. Pricey but a very well made piece. You’ll soon forget the pain in the wallet.
