Technical Stewart Warner Speedometer Glass Pitted
Discussion in 'Traditional Hot Rods' started by Crew Chief, Jan 7, 2025.
  1. Crew Chief
    Crew Chief
    I am frustrated with this piece of flat gl*** that came off a perfectly good zeroed out Stewart Warner speedometer. This is one of the metal ones unlike the new plastic ones. The gl*** seems to be etched. I can't feel any pitting with my fingers. It may be a gl*** imperfection. I have tried everything to polish it out but nothing is working. I even tried Turtle Wax polishing compound to no avail. The gl*** is 3 1/8" in diameter. I found a gl*** place on the internet and they want $50 for the gl***.
    What do you all think? I bought what I thought was the right size gl*** off of Ebay and it was too big. The lady had a no return policy. My fault for not asking. Speedo.jpg
  2. continentaljohn
    continentaljohn
    I would cut a new piece myself. So what gauge face is the speedo
  3. Jmountainjr
    Jmountainjr
    How much too big is the Ebay piece? Could you use the old one to mark the edge to size and then sand down to size?
    twenty8 and Crew Chief like this.
  4. Bandit Billy
    Bandit Billy
    You can sand that out but not polish it out. Just like polishing metals, die grinder, fine paper (start at 3000 and see if it cleans it up, I wouldn't go more course than 1000 personally to start). Then as fine as 7000 and machine polish. Keep the galss wet with a spray bottle with plain water in it. You may break it or ruin it but what do have to lose? Make a pattern first incase the heat shatters the gl***. I have polished gl*** scratches (gouges) out of t-top panels and an expensive pair of Maui Jim sungl***es. Worth a shot, right?
    loudbang, 57Fury440, X-cpe and 2 others like this.
  5. tubman
    tubman
    Look further on the internet (possibly eBay?). I had an old vacuum gauge I wanted to fix and found a replacement gl*** much cheaper than $50. Actually, most of the cost was freight; I ordered two so I had a spare (or insurance). The place I found (about 5 years ago) had a large supply of different sizes and thicknesses.
    Crew Chief likes this.
  6. alchemy
    alchemy
  7. Fordors
    Fordors
    Look into jewelers rouge, it comes in different grades and can be used to polish scratches on gl***.
  8. Crew Chief
    Crew Chief
    I have already replaced the odometer.
  9. tubman
    tubman
  10. rusty valley
    rusty valley
    I had a local stained gl*** maker/lady cut me some odd shaped turn signal lenses of red gl*** (provided by me) for 5 bucks each. trimmed and polished edges too.
    Fordors and Crew Chief like this.
  11. twenty8
    twenty8
    A linishing belt will make short work of getting it down to the correct size. Make sure the belt is not too rough, and keep the gl*** cool. Have a bucket of water there and dip the gl*** very regularly. Don't let it heat up very much. It won't need to be perfect. The edges will not be seen. If you want to protect the faces from scratching while you work on it, cover with masking tape and mark the required size with permanent marker.
  12. Crew Chief
    Crew Chief
    All great suggestions. Alchemy posted a link to Timesavers. To save time, I ordered from them at $2.75/ each plus shipping. Came in at about $10.00 total. Hope it is not too good to be true. Thank you all. I can always depend on you for solid advice.
    twenty8, winduptoy and pprather like this.
  13. I have been going to my local gl*** place for 30 odd years now and a small 3 inch or 4inch piece usually costs €2 or a packet of cookies o_O . Flat 10 inch 3mm gl*** for round vintage French headlights he does for €5 or €7.50 each, depending on his mood :rolleyes:. He allways uses new s****s. A few weeks ago there was a new guy who promptly went to the PC, did his calculations starting with pricing a new sheet of gl*** , calculating waste and all sorts of **** and came up with a total of €40. WTF, boss happened to walk in, went to the s**** bin and once again €10 for cutting two 10 inch lenses with their special tool for circles :D.
  14. e1956v
    e1956v
    Alliance Vendor
    Jeff beat me to it, I always use Time Savers
    They also have convex gl*** at excellent prices.
    Crew Chief and winduptoy like this.
  15. Jagmech
    Jagmech
    Ronell clock , you can buy flat or convex lenses, 2"-19" very reasonable, used them frequently.
  16. In_The_Pink
    In_The_Pink
