Technical 64 283 pad codes?
Discussion in 'The Hokey Ass Message Board' started by OldoginMd, May 10, 2024.
  1. I am going to look at a SBC engine for sale
    The casting on it is 3959352 which suggests 1964 283
    The pad appears to have CFC 1207 with a 88 stamped in different font at an angle
    Can someone help me make sense of the pad meaning ?
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    That doesn't look factory to me; also, CFC is an '82 305 if Chevrolet stamped it.
    OldoginMd, SS327 and Deuces like this.
  3. TRAVLR
    TRAVLR
    I have seen these type stampings before on counter engines. You're engine wasn't installed in a car or truck at the factory, it was sold over the counter as a replacement/crate engine. Are you sure the number isn't 3959532?
    Deuces and hrm2k like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    how about a picture of the casting number and casting date and a picture of the whole engine? also please choose full image when posting pics...
  5. squirrel
    that's not a Chevy stamp...it's from some machine shop or something....
    As Mark said, the casting numbers on the back, and what other parts have been installed on the engine, will give you all the info you're gonna get on this one. Sorry.
    Deuces likes this.
  6. TRAVLR
    TRAVLR
    I've seen the CFC code on early 60's 283's and 327's built at the Flint Engine Plant. The 1207 stands for December 7th. As mentioned earlier, the 88 is probably from a machine shop or the previous owner. That part of the stamp isn't from the GM engine plant.
  7. Todd
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    how about a picture of the whole engine and please select full image when posting pics
  10. Thank you Squirrel , as far as I am concerned ,your word ,need not go further in this conversation
    Tunlrat
  11. I would like to thank all of you I left the motor where it sits
  12. squirrel
    I'm interested in Todd's reply...as there are things about the stamp that do look like Chevy could have made it. It's not the normal sequence we see on most engines, though.
  13. Mr48chev
    I slipped over to the dark side to a 2011 thread on a Corvette board and if Screenshot (161).png Old skydog's info is correct that is indeed a replacement block. There should be a date code just above the bellhousing line in line with the distributor hole or close to it. That will have a letter, day of the month and last number of the year.
    J. A. Miller likes this.
  14. drumyn29
    drumyn29
    Found this number stamped near the fuel pump
  15. squirrel
    A 4 digit number stamped like that is most likely an invoice number from a machine shop, so they can keep track of who's block it is.
    Truckdoctor Andy and Mr48chev like this.
  16. slowmotion
    slowmotion
    Looks like a fat damper & a 010 block, interesting.
    drumyn29 likes this.
  17. drumyn29
    drumyn29
    I had a feeling you would know.
  18. Mr48chev
    Factory 62 283 is going to read C = Regular production engine 3 speed. CD = Regular engine overdrive D regular engine powerglide.
    That from the 62 Chevy pfd from the GM heritage center archives https://www.gm.com/content/dam/comp...information-kits/chevrolet/1962-Chevrolet.pdf
    Link to the pfds for various years Info is good from mid 30's to early 60's turns more into the sales brochures and model info later. https://www.gm.com/heritage/archive/vehicle-information-kits Screenshot (1871).png
    Dang, that will teach me to read through the whole thread before checking for an answer.
    I've got to agree with Jim, that number stamped on the pad by the fuel pump is a machine shops tracking number. It probably matches numbers on the work order.
  19. squirrel
    or at least look at the date the thread was started?
    Truckdoctor Andy and Moriarity like this.
  20. Mr48chev
    It was morning and I hadn't had a full cup of coffee yet. That's my excuse and I am sticking to it.
    An interesting tid bit though is that according to the Lime Book 3 digit prefix/suffix numbers didn't start until 1970. That is except now, because around 1966 the third digit meant either Holley or Rochester carb on certain engines. Screenshot (1875).png http://www.camaros.org/pdf/LimeBook.pdf
  21. squirrel
    yeah, I've had a IVR suffix 396 for decades, and only recently figured out what it means.
  22. drumyn29
    drumyn29
    I am so lost on these numbers.
  23. squirrel
    like I said, they're most likely the invoice number from when the block was taken to a machine shop. Many shops stamped the work order number on the parts they took in, so they could keep track of them.
    they are NOT original Chevy numbers.
  24. drumyn29
    drumyn29
    Works for me, thanks!
