Technical 51 Henry J Front Axle Question
Discussion in 'Traditional Hot Rods' started by Psycho Deville, Jan 7, 2025.
  1. I was wondering if anyone used a '47 Ford F1 axle in a Henry J drag car? Or... Other than '61-65 Econoline, what other options are out there?
    Thanks
  2. swade41
    swade41
    from Buffalo,NY
    If wheel mounting surface to wms works and you can find brakes for it, then why not.
    deathrowdave likes this.
  3. RodStRace
    RodStRace
    If yo have frame rails (spring perch width) and wheel surface measurements (wheels placed where you want under the body) and maybe even drop, you can search for those attributes. There is also the aftermarket, but again you need more than "Fits Henry J".
    Psycho Deville likes this.
  4. Thanks guys.. i'll be mocking it up this weekend see if it works. Fingers Crossed
    RodStRace likes this.
  5. swade41
    swade41
    from Buffalo,NY
    If you decide to go tube axle, 48 inch king pin width is almost identical to stock Henry J width.
  6. Such a *****in car!!! I've seen this before but dont know much about it. Is this your HJ?
  7. swade41
    swade41
    from Buffalo,NY
    hotrodjack33 likes this.
  8. 1971BB427
    1971BB427
    from Oregon
    If the stock axle is 48" kingpin width, then add 8" to wheel mounting surface, or maybe 9" with disc brakes. That means the Econoline axles will be too wide as they're around 61" wide at WMS to WMS. And the Chevy Greebriar vans are the same. The early '49-'54 Chevy truck axles are about 1.5" narrower, so closer, and might work. I've never used an early F1 axle, so you'll need to measure it before buying. But I see no reason they wouldn't work other than the larger bolt pattern. But that can be changed if you convert to disc brakes, and use a smaller pattern.
  9. 31Apickup
    31Apickup
    The 42-47 pickups use the same spindles as the 42-48 p***enger cars, there are numerous brake options.
  10. 28rpu
    28rpu
    I used an F1 axle and springs on my Henry J. It's not a direct fit but with some fabricated mounts it worked well. IMG_3900.JPG IMG_3901.JPG
  11. Awesome!!! I'll be doing the same. @28rpu What did you do with your rear suspension?
  12. 327Eric
    327Eric
    Mine has a 53 Chevy Truck axle.
