Technical Ideas for 6X2 air cleaner/cleaners. Ford FE.
Discussion in 'The Hokey Ass Message Board' started by movin/on, Jan 8, 2025.
  1. movin/on
    movin/on
    I've got an Edelbrock F68 (Ford FE engine) and want some type of air cleaner/s that looks HAMB friendly. Please post pictures of them and the manufacturer if possible.
    Attached is a picture of my setup with Stromberg WW's. I've turned the P***engers side 3 so all the linkage is inboard. Fabbing up linkage and fuel lines for the outside of each bank.
    Richard >>> Movin/on
    jet996 and Spooky like this.
  2. Spooky
    Spooky
    Neat set up- my question is, what are you putting this amazing set up in?
    Car, truck, hot rod, custom?
  3. Never heard of one of those for a Ford FE. Very cool, but you will probably be fabbing you own air cleaner.
  4. movin/on
    movin/on
    Well it's non-Ford and a 1960. Bought it in 1977 for $2400 with new interior and all new stainless. It was stripped of all paint. 1960 Vette roadster. Putting in a 9" 4.11 with Detroit Locker, wide ratio big in big out 4 spd. I had it converted, RC Bell and 427 FE with a 428 crank. Should be 454 CI, solid Cam and ported heads. Long tube Ford CI headers. Hoping for just over 500HP.
    Movin/on
    flatout51, mitch 36, swade41 and 2 others like this.
  5. Joe Blow
    Joe Blow
    Short velocity stacks/bug horns (with screens) are probably going to look the least cluttered. OTB
    Spooky, loudbang and Just Gary like this.
  6. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I used an early Ford ****** element in a home built housing on my side drafts. Maybe two of them side-by-side could work? carbs 10.JPG carbs 11.JPG carbs 12.JPG carbs 13.JPG
  7. mkubacak
    mkubacak
  8. Spooky
    Spooky
    I LIKE IT!
  9. Flatrod17
    Flatrod17
    Might want to machine the tops of the carbs to get rid of the V flange. That way more air cleaner options could be available, that clamp on. Or of building something easier to make a flange to fit.
    I would like to see this setup installed in the car!!
    Looking back I see the end carb on the right side does not have the v flange. Mismatched carb?
  10. Flatrod17
    Flatrod17
    Maybe a couple of these if they would fit side by side. Would have to make a lower piece for sure.
    THE FRENCHTOWN FLYER likes this.
  11. flatout51
    flatout51
    Dadgum! I thought my 3x2 FE intake was cool! Haha! I agree with the velocity stacks above or some frog mouth breathers!
  12. 57 HEAP
    57 HEAP
    Since you have six carbs, I would go with six air cleaners. It would be a shame to hide the carbs with one huge air cleaner.
