Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
    IMG_2895.jpeg IMG_2896.jpeg IMG_2893.jpeg Finished AFB rebuild thank you Jon @carbking for your help and parts. I was going to polish the carb but after 15 or 20 minutes and very little progress I gave up. I’m going to try to marry the Chrysler pie tin air cleaner top to the Elderbrock chrome piece leaving a chrome outer ring. Maybe install a 273 Charger decal?
  2. lumpy 63
    lumpy 63
    20250112_103805.jpg Seemed like Corvette day at the shop...Dwayne shot the 58 fuelie yesterday and loaded it up on his ramp truck this morning.
    rod1, mad mikey, Okie Pete and 17 others like this.
  3. tubman
    tubman
    Unpacked the small base Rochester 4G 4BBL carb off a stick shift '53 Olds. I bring a carburetor or two to Florida when I go down in the winter so when I need a car "fix", I can take one out and rebuild it. I have several vintage dual quad setups for old Oldsmobiles as well as a couple of flathead 4BBL intakes that all take the old "Square" pattern carbs. So far, I have three of these identical Olds carbs, and two matching small base WCFB's. I ended up"specializing" in these so they wouldn't get "lost in the shuffle". I recently acquired a Stromberg "Aeroquad" by accident (the guy thought it was a WCFB); now I have to decide if I want to start dealing with these. Probably not as this one isn't in the best of shape.
    At my age, it's about all I can do anymore.
  4. Lone Star Mopar
    Lone Star Mopar
    My brother finished inner & outer rockers. Body mount braces & a new wheel well surround for me.
    All these parts were made with basic hand tools. Hammer forms & an English wheel. Only pre made panels were the ones you can't see.
    It will get bodywork & paint when My wallet quits smoking... I'm very stoked on the work he's done for us.
    Up next I'll handle the 261, T5 & 57 Chevy rear end swap. 20241231_155015.jpg 20250102_143941.jpg 20250108_175654.jpg
  5. fastcar1953
    fastcar1953
    I got disc brakes on front of Nova and started back on truck project. 473172259_9450359918321543_7653498980905376915_n.jpg 473233060_9450359291654939_4300562930877155292_n.jpg 473253901_9450359608321574_8119271695677792207_n.jpg 473327787_9450359114988290_9000406087235326527_n.jpg 473416118_9450360084988193_7061207841893908136_n.jpg 473280620_9450360208321514_8385936289283114008_n.jpg 473284959_9450360421654826_802545542359526840_n.jpg
  6. guthriesmith
    guthriesmith
    Tearing down a 312 to rebuild and swap into my 56.
  7. You guys all had more fun than I did. I sat at a Harley swap meet all day trying to turn Harley parts into Chevy parts via cash. Around here, motorcycle swap meets aren’t like they used to be. About half as many vendors and small crowds of people.
  8. pila38
    pila38
    rod1, mad mikey, Okie Pete and 11 others like this.
  9. lumpy 63
    lumpy 63
    mad mikey, 427 sleeper and saltflats like this.
  10. abe lugo
    abe lugo
    Trying to do mostly indoor stuff. Still learning upholstery for hobby. Getting all the attachments for my Mom's old Kenmore. Walking foot is in the mail.
    But tackled headliner and sunvisors on the F100. It's a work truck so good enough.
    and added the chipboard to replacement windlace for the wagon. Changing from 60/70 flange style to the soft tube fabric style.
    my goal is to do the Fairlane stock looking door panels.
    75833672361__0403BD2B-A2E0-4536-9E98-E5338AD49D65.jpeg IMG_6140.jpeg IMG_6139.jpeg IMG_6137.jpeg IMG_6025.jpeg IMG_6035.jpeg
  11. fastcar1953
    fastcar1953
    @lumpy 63 2 1/2 inches. while its off going to try to install roll cage.
  12. fastcar1953
    fastcar1953
  13. Roothawg
    Roothawg
    I need that rollback.
  14. lumpy 63
    lumpy 63
    He drives it everywhere, has a built 390 in it:cool:
  15. Roothawg
    Roothawg
    It's on the bucket list.....:D
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sure, getting older ****’s. I don’t see like I use to. Masking was a pain in the… IMG_3720.jpeg
    Turned out fair. Had some paint bleed but some acetone and a small paint brush cured that problem. IMG_3721.jpeg
  17. lumpy 63
    lumpy 63
    No rubber dagmars for Johnny Gee?
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
  19. fastcar1953
    fastcar1953
    Gear vendor installed on th400. IMG_20250113_171809_778.jpg IMG_20250113_171821_069.jpg IMG_20250113_171902_982.jpg
    rod1, mad mikey, Okie Pete and 6 others like this.
  20. lumpy 63
    lumpy 63
    I'm thinking thats gunna be a really short driveshaft:D
    rod1, mad mikey, seb fontana and 7 others like this.
  21. Stock Racer
    Stock Racer
    Creating a poor mans floor shift steering column.
    mad mikey, Okie Pete, enloe and 8 others like this.
  22. saltflats
    saltflats
    from Missouri
    Try fine line tape next time on the edges then fill in the gaps with masking tape.
  23. fastcar1953
    fastcar1953
    About 26 inches.
  24. Mike Miller
    Mike Miller
    Working on re-installing the front and rear gl*** in the 59 g***er. It's cold here and the new seals are very stiff. DSCF5826.JPG DSCF5825.JPG DSCF5827.JPG
  25. seb fontana
    seb fontana
    from ct
    Still working on my sand blaster. All most done. Spent more money than I thought to up grade a HF cabinet blaster. Hope it works.!!
  26. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Rockets didn’t fit correctly on the hood. Got a plan on how to refasten rocket to lower half shell since these had been blown apart at some time in its life. Ace run in the morning for couple of tiny machine screws and nut’s and a little pot metal luck. IMG_3730.jpeg
    pila38, saltflats, mad mikey and 4 others like this.
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    By the way. Where’s my clip set for the grill at this moment?
    pila38, enloe, saltflats and 10 others like this.
  28. DDDenny
    Man, that is such a beautiful color!
  29. snoc653
    snoc653
    from Iowa
    I say build one. Pick the cab of your choice and fit it on a 2006 and up F350 crew cab dually long bed frame and build it how you want. A ramp truck is more vintage, but a true roll back is way more versatile.
    Roothawg and 427 sleeper like this.
  30. surestar
    surestar
    from canada
    36E016A4-934A-4FF5-B089-79F910E6F42E.jpeg F461E1FE-117D-4FEC-9812-D2B78D19BDA2.jpeg 95C449E2-9FB4-4827-B847-CCAD7000C503.jpeg Just getting started on this ‘52 Chevy pick up. Got the ch***is started with the usual goodies Sbc, 700r blazer rear etc. Not exactly traditional I know, but I have been down the beam axle road and that’s not for me anymore. Looking for some comfort for what will be a daily driver. As usual ,I got ahead of myself and did the seat already... it’s a long winter out here on the bald *** prairies....
    pila38, enloe, little red 50 and 10 others like this.
