Technical Interior door trim how to?
Discussion in 'Traditional Customs' started by topher5150, Jan 12, 2025.
  1. topher5150
    topher5150
    I've been thinking about re-doing my door panels on my 47 to a design that I was thinking about earlier. My thought was to make a panel with a small bead rolled around the edges to fit in the blue tape...or textured metal with a separate piece of trim over it.
    What's a clean way to attach this panel? Everything outside of the blue tape will be white vinyl.
    reagen and Tow Truck Tom like this.
  2. GordonC
    GordonC
    I just used screws with caps for the screw heads on mine. Traditional and looks pretty good.
    reagen, akoutlaw and Tow Truck Tom like this.
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    The main securement will come from the pieces ( fixtures ) shown.
    To keep the edges on board @GordonC said.
    GordonC likes this.
  4. topher5150
    topher5150
    I really need to work at proof-reading
    I wanted to put a metal panel and trim on the panel.
    GordonC likes this.
  5. You’re asking how to make a metal trim piece or insert?
    If so, look up aluminum extrusion trim
    Textured metal panels
    Trim comes in different sizes and shapes. Can easily be shaped
    several styles of textured panels
    disturbio, reagen, RodStRace and 2 others like this.
  6. K13
    K13
    He is asking how to attach the panel he makes to the door panel.
    Lots of way to do it. Glue it on. Double sided tape. Small rare earth magnets embedded in the door panel.
  7. RodStRace
    RodStRace
    What was often done by the factory was a formed trim with tabs that stuck thru the backing board. These were fitted over the upholstery, then bent over behind the board. That's a lot of custom fabrication with tight tolerances for a one-off.
    I've been pondering the same thing, and have figured it was a ton of work to make from scratch. Probably lay out the design on a board, use a router on a wood blank to make a channel then form some aluminum to fit, remember to include those tabs! Polish, then get the backing board and align everything.
    I guess you could use round stock or half round and form it. This could be drilled and tapped if the tabs sound flimsy. Tiny screws and big washers to spread the load.
    https://www.mcmaster.com/products/aluminum-half-rounds/
    The next thought was to try to find a factory set that fit the idea. That's kind of a needle in a haystack.
    Some are repop'ed.
    https://www.speedwaymotors.com/OER-...nel-Trim-Moldings-for-1967-Camaro,117693.html
    Attaching the board to the door/kick/quarter is screws with or without cap covers, metal door clips or plastic Christmas trees.
    https://www.oreillyauto.com/shop/b/...im---molding/interior-trim-clips/74d1d12353dd
    reagen likes this.
  8. RodStRace
    RodStRace
