Technical Can anyone tell me how to form a lip like this?
Discussion in 'The Hokey Ass Message Board' started by ekimneirbo, Jan 12, 2025.
  1. ekimneirbo
    ekimneirbo
    x
  2. RodStRace
    RodStRace
    I'd guess it was custom, either hand formed or as you say, a pair of dies. If a company made a flat panel with a flare for a '39 teardrop, it wouldn't work on a curved panel like this, requiring hand forming anyway.
    If you wanted to replicate this yourself, a die that's curved and shaped to make the flare could be fabb'ed out of wood if that's easier for your skills, but I'd expect even if you got 2 panels ready to weld in with the proper curve and flush to the housings, there would be metal finishing involved after they were installed.
    It's one of those little signatures of a well crafted hot rod that whispers, "I've got the eye and the skills".
    EDIT: I'll mention that it is sticking out at the top, and inset at the bottom. They went for an exact angle of the light, then split the difference top and bottom. Not all inset, not all bulging out. Master work.
  3. X-cpe
    X-cpe
    Been thinking about something like that for my tail lights.
    One option, could either buy or hammerform a pair of frenching buckets for the tail lights. Make a hammerform or a pair of dies for the top roll. Trim the buckets to fit and weld.
    Edit: RodStRace types faster than I do.
    Paul and hrm2k like this.
  4. Model A Gomez
    Model A Gomez
    Really nice workmanship, would take a lot of time and talent to inset them and flare the top. I have seen the inset and the kits to do that but this is above and beyond that!
    ekimneirbo likes this.
  5. Mr48chev
    I hate to use the S word but Speedway and no doubt several others sell the recessed buckets for a 39 tail light to make it easy to french it in and then make your own lip like in the photo. Screenshot (1899).png
    vtx1800, ekimneirbo and X-cpe like this.
  6. bill gruendeman
    bill gruendeman
    I would think it is to better to hammer form a bucket, then weld it to the panel. Trying to hammer form a bucket in to the panel will not leave enough room for the hammer. I made these buckets that way and rolled a flange to **** weld to the panel IMG_0639.jpeg
    Okie Pete, 5window, vtx1800 and 4 others like this.
  7. chopolds
    chopolds
    from howell, nj
  8. rusty valley
    rusty valley
    anthony myrick and RodStRace like this.
  9. Joe Blow
    Joe Blow
    pprather and ekimneirbo like this.
  10. I’m hillbilly tech at my shop
    I’d make it with a hammer
    Before I knew what a bead roller was I used hammers.
    Still do for stuff the roller can’t
  11. One piece of metal
  12. You can do a lot with the chisel end of a body hammer
    just hammers
  13. choptop40
    choptop40
    Hot rod Shop panels look like you can reverse it to have the raised panel facing out..
  14. 5window
    5window
  15. I agree with Anthony. I'd be done with that in short order. careful calculating on how much to cut out would be very important. Patterns are cheap and disposable. :)
    ekimneirbo and anthony myrick like this.
  16. lostone
    lostone
    from kansas
    I'd use the buckets, protrude the top lip of the bucket outside the rear panel, weld some round rod around the top lip the grind and shape that rod to my desired shape.
    I've got to find ways "around" metal shaping by hand because I'm much better at welding and grinding !!
    @anthony myrick can I bring my 31 Tudor and come play at your house for a while ??!!
  17. A bucket isn’t very hard to make
    We built these for modified 51 merc lights
    it does help when building to fit crusty pieces though.
    Almost hammerd a detail like you’re asking about on the top. Decided to leave it smooth
  18. With a stamping machine or Pullmax you can machine/grind and file male and female dies to a desired profile.
    The taper part is learning how and when to back off the machine.
    Or whack it with a hammer.
    Here’s a crude tutorial how.
    Figure out a shape (piece of s**** 18 gauge from the floor)
    Then start whacking. I use the chisel end of a body hammer and hit the other end with a rubber mallet
    then flip over and continue whacking
    flip back and forth until ya get the shape ya want
    The edge of a bench comes in handy(wood on steel bench)
    keep flipping and whacking
    then clean it up.
    Quick crude tutorial
    You can keep hammering and sharpening up detail and better finish work if desired.
    This one tapers towards the curve. You’d be surprised how deep you can stretch this stuff
    Tools used: chisel hammer, rubber mallet, pieces of wood, sturdy bench.
    This shaping chisel set helps
  19. marfen
    marfen
    from sask
    Good stuff. love to see metal shaping on the hamb. Good idea to go this route as those flat tail lights never sit that great on the curved below deck panel.
    ekimneirbo and Tow Truck Tom like this.
  20. RodStRace
    RodStRace
    @anthony myrick thank you for the tutorial! Nice to see the steps and the tools used.
    I kind of ***ociate metal shaping and electrical skills. They are both kind of magical to those without the knowledge and experience.
    Most of us have dented a panel at some point. The ability to keep tapping until it becomes the desired shape is something people have done for centuries, but it is still not common.
    It served you well as a marketable skill, so you know it's value. I'll repeat myself, master work.
  21. No. Adequate for the situation and tools available
    I worked with a “master” or much better than me
    I’m a getter did metal guy
    ekimneirbo and RodStRace like this.
  22. RodStRace
    RodStRace
    Better than a cave 'n pave dude.
    X-cpe, ekimneirbo and anthony myrick like this.
