History 28-31 MODEL A THAT DOES IT FOR YOU! Feel free to post your Model A
Discussion in 'Traditional Hot Rods' started by HOTRODPRIMER, Dec 14, 2024.
  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. Stan Back
    Stan Back
    He looks concerned -- as he should be. He's got the wrong year grille shell and will probably have to settle for one of those over-common bulbous 1932 ones.
  5. 40ragtopdown
    40ragtopdown
  6. 40ragtopdown
    40ragtopdown
  7. 40ragtopdown
    40ragtopdown
  8. 40ragtopdown
    40ragtopdown
  9. 40ragtopdown
    40ragtopdown
  10. 40ragtopdown
    40ragtopdown
  11. 40ragtopdown
    40ragtopdown
  12. 40ragtopdown
    40ragtopdown
  13. 40ragtopdown
    40ragtopdown
  14. 40ragtopdown
    40ragtopdown
  15. 40ragtopdown
    40ragtopdown
  16. 40ragtopdown
    40ragtopdown
  17. 40ragtopdown
    40ragtopdown
  18. 40ragtopdown
    40ragtopdown
  19. 40ragtopdown
    40ragtopdown
  20. 40ragtopdown
    40ragtopdown
  21. Never2low
    Never2low
  22. 282doorUK
    282doorUK
    Apart from the hall of mirrors effect, what sort of weirdness is going on with that engine?
  23. wuga
    wuga
    Here is a write up on the engine.
    Warren
    Power came from a bored and stroker 1957 Lincoln engine. The engine and engine compartment were heavily chromed, and it ran a McCulloch-Paxton blower. Howard had a theory that several small tubes were better than one big one, so he made several air tubes that fed the blower. The mill ran a Grancor crank, reworked valves, a Herbert roller cam, Forgedtrue pistons, milled heads, two four-barrel Rochester carbs, dual electric fuel pumps, Mallory magneto ignition, a Schiefer flywheel and other goodies.[1]
    dwollam, Speccie, deadbeat and 3 others like this.
  24. banjorear
    banjorear
  25. banjorear
    banjorear
    CSPIDY likes this.
  26. 282doorUK
    282doorUK
    Thanks Warren, not sure I'm any wiser though!o_O:confused:
  27. 40ragtopdown
    40ragtopdown
  28. 40ragtopdown
    40ragtopdown
  29. 40ragtopdown
    40ragtopdown
  30. 40ragtopdown
    40ragtopdown
