Projects Motor
Discussion in 'Traditional Hot Rods' started by Huckster59, Jan 10, 2025.
  1. Huckster59
    Huckster59
    Just got motor back 283 bored 30 over. One sleeve,10/10 on crank. 302 intake with eddy carb. I think 650 Needing clutch. What’s a good all around clutch. Not racing. New intake bolts ordered too. Lol
    GlassThamesDoug likes this.
  2. RodStRace
    RodStRace
    What trans, flywheel and bellhousing? That might change things.
  3. squirrel
    Yeah, stock should be fine. But first you need to figure out what application you'd need one for, as it could be for a variety of vehicles. So, answer Rods questions, and we'll see what we can find.
    Truckdoctor Andy likes this.
  4. Yep. Count them flywheel teeth and grab a tape measure
  5. hepme
    hepme
    IMO do not use the 3 finger type plate or disc. I've used the diaphragm type and the 3 finger many times, the 3 is always hard for street/town driving.
  6. partsdawg
    partsdawg
    from Minnesota
    Based on the info so far buy one of each style and tooth count then return all that won't work
    jet996, Truckdoctor Andy and squirrel like this.
  7. 6sally6
    6sally6
    Get a big 'un !
    650 carb on a 302 intake..stuck on a lil old 283...you're gonna be slipping it a lot.
    6sally6
    Mel Bergman likes this.
  8. I had the big flywheel that accepted an 11" clutch and used a Luk clutch for a 1980 Corvette or Z28. Tubbed car, healthy SBC with 4.10 gears. Street only, no slicks. Never had a problem.
    Sold that car, needed a clutch and flywheel for the next project ... again went with the 11" Luk and again, no problems.
    Deutscher and loudbang like this.
  9. SS327
    SS327
    Centerforce dual friction!
  10. guthriesmith
    guthriesmith
    I may have that Centerforce dual friction new in a box that I don’t need depending on all the other variables. :D
    -Brent-, Tickety Boo and Huckster59 like this.
  11. I agree on what everyone else has said, stock. Food for thought, I needed a clutch for Papaw, and used a 1970 C-10/350 as an application on the olde Rock Auto. I found a close out 12” clutch kit for $49.95. I also am using the flywheel from the same application, 164 tooth I believe, and a 66 C-10 bellhousing. My point is, check the close out specials. You probably don’t need a 12” clutch, I sure didn’t, but damn it was a good buy.
    GlassThamesDoug, DiggerJoe and jet996 like this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    Motor is an odd ***le for this thread, I would think that "what clutch do I need for my 283 57 Chevy" would get more help.
    Is there a clutch and flywheel currently on it? do you have the flywheel and its corresponding starter? also do you have the bell housing? some take an 11" and some are 10.5"
  13. Mike VV
    Mike VV
    from SoCal
    Just for some factual info -
    You CAN NOT...bore a 283, or most any other automotive block...30 over !!
    .030" is pretty possible, but not...30 over.
    Details...matter.
    Mike
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
  15. Bandit Billy
    Bandit Billy
    Made me think of Sister Christian by Night Ranger
  16. Budget36
    Budget36
    I kinda thought “650” was in reference to a carburetor, but “650 needs a clutch” had me wondering.
    650$ for a clutch or…?
  17. RodStRace
    RodStRace
    @Budget36 this is my attempt to edit.
    With all due respect to @Huckster59, just trying to clear up any confusion.
    I just got my motor back. It's a 283, bored 0.030" over, with one sleeve, 10/10 undersize (0.010") on crank.
    I'm running a 302 intake with eddy carb which I think is a 650 CFM.
    The car needs (Needing) a clutch. What’s a good all around clutch? I will not be racing.
    Budget36 likes this.
  18. Huckster59
    Huckster59
    Stock bell housing 4 speed Saginaw 411 posi
  19. Huckster59
    Huckster59
    Ok here is what I have. 283. Bored .030. 302 intake. Going to use stock flywheel 168 tooth I’m pretty sure. Saginaw 4 speed ,411 posi unit 1960 is the year of rear section ,i do not have flywheel or clutch yet ,also going to run ram horn corvette manifolds , sorry for the confusion
  20. squirrel
    Pick a car and order the parts for it. "stock bellhousing"...there are a lot of different Chevy bellhousings. Picture? casting number? then we can see what you're working with
  21. Huckster59
    Huckster59
    Stock 1957 Chevy Belair bellhousing with the side mounts
    squirrel likes this.
  22. Fordors
    Fordors
    You’re correct, you need the 168 tooth ‘wheel. The tri-Chevy’s came with 10.5” clutches on that 168 tooth f/w but there are also 168T f/w’s drilled for 11” clutches. You can measure the bolt circle to determine which clutch you need, the 10.5” bc is 11 5/8, the 11” bc is 12 5/8”. In any event I would go with a diaphragm, bent finger pressure plate that will use the short throw out bearing.
  23. Huckster59
    Huckster59
    Ok thanks. The flywheel I’m getting from a friend is for 11 clutch. He recommended clutch from oreillys for 69 Chevelle With the 11” flywheel dies that change the starter or will stock starter work with 11”
  24. Fordors
    Fordors
    Your starter should be the three bolt style that bolts to the bellhousing, and yes, the 11" PP will be fine.
  25. Huckster59
    Huckster59
  26. chevy57dude
    chevy57dude
    For small block stuff, I have a hypothetical car to tell a counter person about.
    1970 Nova, 350, 4 speed and no air conditioning. ''New'' enough that it comes up on the computer.
    Be sure your bellhousing will take an 11 inch flywheel.
  27. guthriesmith
    guthriesmith
    Haha…I use 70 Chevelle for my hypothetical car to tell the parts guys often.
  28. Huckster59
    Huckster59
    What I have been told is it will work.
    chevy57dude likes this.
  29. goldmountain
    goldmountain
    Anymore, the "hypothetical" car is way older than the guy at the counter and he can't relate anyhow.
    osage orange and joel like this.
