Hot Rods Dropped axel with stock model A sterling arm and mechanical brakes
Discussion in 'The Hokey Ass Message Board' started by 52Truckin, Jan 13, 2025.
  1. 52Truckin
    52Truckin
    I am installing a 4” dropped axle. It is the stock axle that was under the car. I sent it to Anson Axle and he did a great job. Trouble is I can’t seem to bend my steering arm in such a way that keeps the steering rod from hitting the steering arm. I fabed a bracket to hold the brake acutator. Any help is appreciated.
  2. lostone
    lostone
    from kansas
    Can you get some pics ? It would be about the only way to "see" your problems and give you a somewhat accurate advice and fix..
    chlsnk likes this.
  3. Pete Eastwood
    Pete Eastwood
    from california
    It sounds like you are running the mechanical brakes.
    If that's the case, do yourself a favor and switch to 32 / 34
    spindles & brakes. they are better brakes & the spindle arms
    are better for re-shaping for your dropped axle.
  4. Howard Allgood
    Howard Allgood
    I think I have the steering figured out. I am putting the wishbone on the axle and find when I slide one side of the wishbone on the axle to insert the perch pin the other side of the wishbone is off by a couple feet. Looks like I have to heat and twist the wishbone to get it to fit. Where is the best location on the wishbone to heat in this situation?
    winduptoy likes this.
  5. adam401
    adam401
    I’ve dropped a couple model As with mechanical brakes. Tie rod above the wishbone, drag link in stock location. This car pictures is lowered with a 33 axle. This is 1.5 lower than stock. If your axle is a 4” model A axle I believe that makes it 1.75” lower than stock. So basically this is very similar to your setup but I used 32-34 perch pins. If you could start over I would suggest you just swap the model a stuff to 32-34 stuff. Basically the same drop and almost bolt together. But what you’re doing is fine. Good luck. IMG_3343.png
  6. Pete Eastwood
    Pete Eastwood
    from california
    Are you using a stock model A wishbone?
    What dropped axle are you using?
    You could be creating more problems by using the wrong combination of parts.
  7. chlsnk
    chlsnk
    Can we see some photos of what you have going?
  8. Model A Gomez
    Model A Gomez
    I went through this on the Model A I'm working on and finally came to the conclusion that I wasn't able to make the left steering arm clear everything no matter how I bent it. The 32-34 spindles and steering arms will work so that's the way to go.
  9. Howard Allgood
    Howard Allgood
    My axle is dropped 4 inches
    bschwoeble likes this.
  10. Howard Allgood
    Howard Allgood
