Hot Rods T-Altered unearthed, resurection started, Milwaukee car raced at The Grove
Discussion in 'The Hokey Ass Message Board' started by titus, Nov 24, 2024.
  1. titus
    titus
    Made a little more progress, side tracked with other more important stuff, got some hoops bent up, had a buddy draw some rear end mounting brackets up and got then cut out, got rear roll bar in and rear end brackets tacked in and rear tacked in, then got the body mounted, now time to start getting the motor/trans mocked up/mounted
    IMG_1805.jpeg IMG_1788.jpeg IMG_1792.jpeg IMG_1701.jpeg IMG_1700.jpeg IMG_1699.jpeg IMG_1670.jpeg IMG_1671.jpeg
  2. Okie Pete
    Okie Pete
    Looking great . You’ll be tearing down the drag strip soon . Looks like you’ve cornered the market on headlight buckets
    WC145, Sharpone, Squablow and 2 others like this.
  3. BigJoeArt
    BigJoeArt
    Good stuff man! Can't wait to see it as a roller!
  4. hrm2k
    hrm2k
    Score !!!!
    Sharpone and porkshop like this.
  5. rusty valley
    rusty valley
    I've never seen an anvil thats shiny from constant use. Carry on
  6. alchemy
    alchemy
    ***us could build a whole hot rod just using the parts thrown under the workbench.
    1oldtimer, WC145, hiboy32 and 4 others like this.
  7. Phillips
    Phillips
    You may be thinking of Bill Wendt, wild street altered. I'd post a pic but don't want to derail the thread.
  8. primed34
    primed34
    I think you're right.
  9. titus
    titus
    Made a bunch more progress, rounded up some killer palamides 18” 12 spokes, found a lakewood bellhousing, got the clutch-flight attached to the hemi, got it slung up in the ch***is and got motor mounts made and mocked up the rest of the motor including the hemi stack injector. last night i tinkered on headers
    IMG_2544.jpeg IMG_2555.jpeg IMG_2629.jpeg IMG_2694.jpeg IMG_2721.jpeg IMG_2720.jpeg IMG_2726.jpeg IMG_2728.jpeg IMG_2729.jpeg 73E91718-10AB-4517-AC69-5E2AB4F4F90C.jpeg IMG_2738.png IMG_2740.jpeg IMG_2743.jpeg IMG_2747.jpeg IMG_2750.jpeg IMG_2758.jpeg
    attitudor, Outback, WC145 and 27 others like this.
  10. Chucky
    Chucky
    That’s coming together nicely!
    porkshop and Sharpone like this.
  11. Sky Six
    Sky Six
    from Arizona
    very, very nice.
  12. Dave G in Gansevoort
    from Upstate NY
    I can hear the nitro now…
  13. Kevin Ardinger
    Kevin Ardinger
    Clutchflight included or did you have one. Pretty rare as well. Super cool find! Looking forward to seeing it progress! Thanks
    Outback, porkshop and Sharpone like this.
  14. titus
    titus
    i bought it locally about 10 years ago, been on the shelf waiting for the perfect project!!
    Outback, WC145, Tim and 5 others like this.
  15. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    HELPFUL CLUTCHFLITE HINT: Do NOT shift to Neutral and kill the engine after going through the lights!
    The pump will stop pumping and starve the output yoke of lube, seizing it onto the tailshaft bushing. That will stop your driveshaft RIGHT NOW! and lock up the slicks.
    Ask me how I know.
    Outback, deadbeat, WC145 and 11 others like this.
  16. Sharpone
    Sharpone
    Most Excellent
    Dan
  17. catdad49
    catdad49
    ***us, Quain Stott just picked up one of these (his is a little later version). He might be looking for some others to play with, just saying!!
  18. NoSurf
    NoSurf
    Very cool
  19. RodStRace
    RodStRace
    I can guess how you know, but could you say what you found is correct?
    I'd ***ume neutral, engine running still pumps, but you can't read the plugs.
    I'd also ***ume clutch in isn't pumping, the same as engine off.
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I ran a clutchflite behind my six banger altered. The six cylinder drag engine is particularly susceptible to oil starvation on decells because of the long oil pan. I had previously run a clutchless 4-speed and got into the habit of
    hit the traps
    flick 'er up into neutral
    kill the engine
    hit the brakes
    When I switched to the clutchflite I continued to use the same method of shutting down. Since the clutchflite has no rear pump the trans is left with no oil pressure. The slip joint / yoke was pressure fed oil and it starved with no oil, seized the yoke on the bushing, and locked up the rear axle at around 130+ mph.
    BoyHowdy that will raise the pucker factor of a ride in an already intense experience of driving an altered.
    That was one of the reasons I removed the clutchflite, in addition to slider clutch maintenance issues, and improvements in Powerglides and converters.
    Outback, WC145, neilswheels and 4 others like this.
  21. neilswheels
    neilswheels
    from England
    Caught some of this build on Insta. But can always see more of it. So following. Great looking drag car
    Outback, Sharpone and porkshop like this.
  22. titus
    titus
    i realized the forgot to do an update, i had the car at GSTA’s 67th annual rod and custom show back in April, i had been busting **** on it to get it rolling for the show, turned out pretty good, still need to build a motor for it at some point and of course lots of other stuff
    IMG_5226.jpeg 2174DBF4-1BC7-413C-86D2-78E80CE75CCC.jpeg IMG_5231.jpeg IMG_5244.jpeg IMG_5246.jpeg IMG_5276.jpeg IMG_5291.jpeg IMG_5161.jpeg IMG_5163.jpeg IMG_5147.jpeg IMG_5146.jpeg IMG_5145.jpeg IMG_5144.jpeg IMG_5120.jpeg
  23. NoSurf
    NoSurf
  24. catdad49
    catdad49
    Is that your "Altered Ego"?! Love it.
  25. LOST ANGEL
    LOST ANGEL
  26. WC145
    WC145
    from Maine
    That is incredibly cool! It's great that you found it, not too many folks could bring it back to life.
  27. Great match to the old pic! Fine looking machine!
