Projects Just Another Hemi Powered Model A Coupe Build
Discussion in 'The Hokey Ass Message Board' started by ClutchDumpinDan, Aug 1, 2019.
  1. DJM
    DJM
    Dang Russell can’t even let the paint dry. For you great price…1 Million Dollars. upload_2025-1-5_13-35-18.png
    Stogy, D-Russ, Dino 64 and 2 others like this.
  2. ClutchDumpinDan
    ClutchDumpinDan
    Getting the Hemi Coupe updates caught up. Steering column, steering shaft and pedal ***embly installed. Brake lines and hoses finished up.
    pila38, MP&C, lothiandon1940 and 7 others like this.
  3. ClutchDumpinDan
    ClutchDumpinDan
    Wiring done and gauges installed…
    IMG_9140.jpeg IMG_9174.jpeg IMG_9194.jpeg IMG_9192.jpeg IMG_8276.jpeg IMG_9193.jpeg
    pila38, Paul B, Just Gary and 17 others like this.
  4. ClutchDumpinDan
    ClutchDumpinDan
    Fuel tank, fuel lines, fuel pressure regulator, intake and trunk area finished up on the Hemi Coupe.
  5. Tim
    Tim
    from KCMO
    That regulator/filter is rad! What is it?
    Stogy and ClutchDumpinDan like this.
  6. AmishMike
    AmishMike
    Great car. But - picture of front wheel & suspension, rubber brake line looks a little short for a hard left turn. Maybe?
    ClutchDumpinDan likes this.
  7. ClutchDumpinDan
    ClutchDumpinDan
    Made by Filter King. They have gl*** bowl ones as well.
    Stogy, Just Gary, Tim and 1 other person like this.
  8. ClutchDumpinDan
    ClutchDumpinDan
    It sure does! Bad angle on the photo. It has a pretty decent zig/zag kinda dip in it. Goes full lock just fine :D
    Stogy, AmishMike and lothiandon1940 like this.
  9. ClutchDumpinDan
    ClutchDumpinDan
    Final body parts painted. Cut, buffed and ready for install.
  10. lothiandon1940
    lothiandon1940
  11. ClutchDumpinDan
    ClutchDumpinDan
    Interior wood installed. All stained and clear coated.
  12. ClutchDumpinDan
    ClutchDumpinDan
    Wrapping up some final details. Dashboard waterfall polished & installed, side view mirrors installed, little retainer made for the throttle return spring, throttle pedal mount fabricated & installed, throttle pedal modified for better ratio & fitment and column mount tach installed.
    It’s getting close to done!
  13. Dino 64
    Dino 64
    from Virginia
    Love that dash, came out great :) !
  14. ClutchDumpinDan
    ClutchDumpinDan
  15. Stogy
    Stogy
    It looks familiar...or let's say inspired by and that's not uncommon in Hambville eh! I agree...it looks sharp... @ClutchDumpinDan congratulations on the many milestones coming together for the grand finale...
  16. ClutchDumpinDan
    ClutchDumpinDan
    Certainly not the first nor last one to do it. Popular choice for good reason :D
    lothiandon1940, Just Gary and Stogy like this.
  17. Dino 64
    Dino 64
    from Virginia
    Bobby Hilton’s ‘ Gentleman’s Coupe’ has the same dash. 36 Ford I believe :)
  18. Stogy
    Stogy
    I had something wedged in my glove box door to keep it closed...now I have a small L bracket with a spring hooked on it with the other end on the back of the box...36 had some simple springs hooked on the hinges to snap it shut. I might go that route but I made an aluminum box liner that might interfere with OEM springs so I was going to use a magnetic drawer clip...someday...:)
  19. Just Gary
    Just Gary
  20. Stogy
    Stogy
    The black in lieu of chrome really looks awesome too.
  21. lothiandon1940
    lothiandon1940
    ...I was just thinking the same thing. Love that look.
    Stogy, ClutchDumpinDan and brady1929 like this.
  22. pila38
    pila38
    Beautiful coupe. Congratulations on the first drive, must have been hard to fit that smile inside that A!
  23. akoutlaw
    akoutlaw
    Dan, where did you get the throttle pedal from?
  24. ClutchDumpinDan
    ClutchDumpinDan
    Thanks! I was a little worried at first that it might look too monotone and street-roddy with all the chrome painted black. Looks cooler than I'd expected though, glad I stuck to the plan.
    lothiandon1940 and Stogy like this.
  25. ClutchDumpinDan
    ClutchDumpinDan
    It's a cheap-o. Probably Speedway or Amazon. Good to cut up and make fit where you need. Along with the extra length, I put a pretty good offset in it to get it in the right spot and aligned with other pedals. Cheaper/quicker than building one from scratch.
    akoutlaw, lothiandon1940 and Stogy like this.
  26. Kevin Ardinger
    Kevin Ardinger
    Very cool project Dan! Nice work! Hey, are the pedals from R Jays? Looks like the clutch is 180 degree and the brake is 90? Were they two separate ***emblies?
    Dino 64 and ClutchDumpinDan like this.
  27. ClutchDumpinDan
    ClutchDumpinDan
    Thanks Kevin! Pedal ***embly is one unit. Correct, clutch M/C is 180º and M/C is at 90º
    Been awhile since purchase, but I think it came from Kugel. Lot of people making them now luckily and they aren't insane expensive anymore (or I'm not so cheap?)
  28. akoutlaw
    akoutlaw
    Thank you.
  29. ClutchDumpinDan
    ClutchDumpinDan
    The Hemi Coupe is on the road! It’s gotten some test miles on it when the weather has allowed. Everything is dialed in and ready for the owner to enjoy it while deciding on some final interior and trim details.
    IMG_4538.jpeg IMG_4540.jpeg IMG_4542.jpeg IMG_4543.jpeg IMG_4544.jpeg IMG_4545.jpeg IMG_4550.jpeg
  30. lothiandon1940
    lothiandon1940
    So very cool!
    Dino 64 likes this.
