Projects Traditional Banger Build
Discussion in 'Traditional Hot Rods' started by reffiesj, May 17, 2023.
  1. Dubonet Garage
    Dubonet Garage
    from France
    Nice! A tip if you want to give the leather a little shine: rub it with a banana peel!
    winduptoy and reffiesj like this.
  2. ha ha
  3. reffiesj
    reffiesj
    Decided to try out some Brewster caps to see how they fit the car - really pleased with the way they turned out. Only drawback is they need to be removed to add air to the tires.
    Jimmy, jet996, Stogy and 11 others like this.
  4. Deutscher
    Deutscher
    from Germany
    I didn't know that at all, they look great. Greetings Harald
    winduptoy likes this.
  5. richard noble
    richard noble
  6. reffiesj
    reffiesj
    Thanks Harald.
    Richard - I appreciate the kind words on the headlights - agonized over them a lot.
    Managed to chase down some grounding issues with the headlights and taillights and everything is working now. Got some plates on it as well - need to find a set of vintage plates to replace the modern ones but that is lower on my priority list.
    Started work on fitting the hood and dialing in the straps - am really happy with how the first one came together. Will definitely take some fine tuning but that should be easy once the footman loops are in place.
    Stogy, osage orange, Jeff34 and 5 others like this.
  7. winduptoy
    winduptoy
    I understand you wanting to get the hood tied down....nice....but now it time to wear those tits off the tires
  8. reffiesj
    reffiesj
    Winduptoy - am getting very close to having it out on the road - just need to chase down an upper radiator hose leak (waiting on some Permatex #2 to be delivered) and then I can start wearing down those tires….in the meantime I got the rest of the hood straps installed.
    V8-m, richard noble, hotrodA and 13 others like this.
  9. ModelAMitch
    ModelAMitch
    Those wheel caps look awesome, keep up the great work!
    Stogy and winduptoy like this.
  10. lamaison
    lamaison
    from Canada
    Curious what you're thinking about as far as the running board splash aprons. I kind of like the look of them left on - if you go that direction, what usually gets done to stop them from flapping around blowing in the breeze?
    Stogy likes this.
  11. reffiesj
    reffiesj
    Thx ModelAMitch!
    Lamaison - from what I have read / seen it seems like most folks fab a couple of support brackets to provide some added rigidity to the apron. That seems to me like it will work fine and won’t be very noticeable if it follows the contour of the apron and is mounted on the underside. It is on my to do list…
  12. trikejunkie
    trikejunkie
    from Scotland
    That is what I did - but let the car sit ticking over to see where it flapped the most then just done a basic strut from the chassis to the side skirt.
    jet996 and Deutscher like this.
  13. reffiesj
    reffiesj
    Ordered a Burtz 6.5:1 head and started prepping it for install. Waiting on some parts and need to have the springs in my FSI changed out before it will be ready for the road. Curious to see how it performs. What are folks’ recommendations for a performance cam - am thinking about doing a swap while I have the head off. Seems like folks recommend the 340 touring grind but am interested in hearing what has worked for others. I don’t want to have to have any machining done so needs to work with stock valves. IMG_2624.jpeg
  14. reffiesj
    reffiesj
    Ordered up a 340 touring cam from Burtz and started to break down the engine for installation of the new cylinder head, cam and modern valve components.
  15. reffiesj
    reffiesj
    Got the valve train out - not too bad except for one valve guide that was lodged in really tight. Eventually lots of Kroil, some heat and a BFH got it out. Two head studs also did not come out right away - am going to pull out the Kroil, induction bolt tool and snap on stud removal socket and see how it goes IMG_2636.jpeg IMG_2637.jpeg
    richard noble and ZerroHalfcup like this.
  16. Kevin Pharis
    Kevin Pharis
    from Califunny
    Wowza! A standard bore A bone! That’s sumpin you don’t see every day
    Outback and rusty valley like this.
  17. If I remember correctly (30 years) the last time I had a broken stud removed I used these guys: www.brokentap.com, (714) 836-6824. Not cheap but "aerospace quality". Keep the number handy in case one of those studs snap.
    Charlie Stephens
    reffiesj likes this.
  18. Really good job on this car!
  19. reffiesj
    reffiesj
    Kevin - I was a bit surprised to see it as well!
    Charlie - thanks for the recommendation - thankfully I didn’t need it - last two came out after a few cycles of heat and penetrating oil.
    Hitchhiker - thanks for the support!
    Head studs out and ready for next steps…
  20. With that kind of luck I hope you went out and bought a lottery ticket.
    Charlie Stephens
  21. reffiesj
    reffiesj
    Got the new lifters, Burtz cam and aluminum timing gear installed in place of the fiber gear that was in there.
    Oil pan gasket is a bit wonky since I took a razor to some of it to get it out of the way but will be replaced and resealed once I get the timing cover and front motor mounts bolted back up.
    Also managed to strip the timing cover and inspection cover to prep it for new paint.
  22. reffiesj
    reffiesj
    Made some good progress on getting everything assembled. Pretty straightforward other than the valve springs and modern valves. Was planning to run spacers to achieve higher spring rates but there is no way I could get them in - things got easier when the Sunnen valve compressor arrived - works much better than any of the other ones I bought but still no way I was going to fit the spacers. Need to button up a few things and am waiting on FS Ignitions to update my Zipper for the higher compression but am almost ready to fire it back up. Hoping to be able to attend RPM Nationals and Antique Nationals in early May.
    IMG_2769.jpeg IMG_2720.jpeg IMG_2772.jpeg IMG_2774.jpeg IMG_2776.jpeg IMG_2779.jpeg IMG_2781.jpeg IMG_2782.jpeg IMG_2783.jpeg
    V8-m, Stovebolt, ModelAMitch and 7 others like this.
  23. reffiesj
    reffiesj
    Got everything back together and reasonably dialed in. I was fighting a lot of popping and backfire under load which turned out to be air leaking in at the intake /exhaust manifold. Seems to be running well now. Others may know this, but it turns out my exhaust washers were backwards - proper install is with the concave side facing the engine - hoping I can save others a little bit of grief….
    winduptoy, lucky, Danny105 and 5 others like this.
  24. reffiesj
    reffiesj
    Working on priming / painting the secondary throttle return spring mount and figuring out how to weld up a bracket for my vintage fire extinguisher overflow can. Also got my non-vintage fire extinguisher mounted. All are on the safety checklist for RPM Nationals.
    winduptoy, ZerroHalfcup and Deutscher like this.
  25. ALLDONE
    ALLDONE
    what jets??? all my bangers I start with 39's and tune from there...vegas is around 2000'
  26. reffiesj
    reffiesj
    I am using stock 0.036" main jet and #71 power valve but I am at sea level.
    winduptoy and 51 mercules like this.
  27. reffiesj
    reffiesj
    Mount for tank fabricated and in primer. Overflow tank polished up and inlet tube soldered on. Last item on the must do checklist is fabricating a pair of drum retainers - that is next weekend’s project..
  28. reffiesj
    reffiesj
    Working on drum retainers - am hoping to get them wrapped up tomorrow.
  29. reffiesj
    reffiesj
    Both sides fabricated and in primer.
    winduptoy, J.Ukrop, Jeff34 and 3 others like this.
  30. V8-m
    V8-m
    from Alaska
    I think you should use thicker material for it.
    Dan from Oakland and 4bangerbob like this.
