Hot Rods 1932 Plymouth PB coupe measurements
Discussion in 'The Hokey Ass Message Board' started by RMR&C, Jan 13, 2025.
  1. RMR&C
    RMR&C
    from NW Montana
    Like the ***le says, I need some PB coupe body measurements.
    From firewall to the rear of body under the deck lid.
    Also width at hinge (B) pillar at the widest point.
    Thanks in advance!
  2. RMR&C
    RMR&C
    from NW Montana
  3. dwollam
    dwollam
    @RMR&C , building another hot rod?
    Dave
  4. RMR&C
    RMR&C
    from NW Montana
    Hi Dave. No, trying to determine the size difference between a 32 Plymouth coupe and a 32 Chrysler coupe
  5. F&J
    F&J
    The 32 PB coupe body shell was unique and it's one year only, and it was not shared with any other 32 Mopar brands. I could look up wheelbase of both, but it's not going to help you because the Plymouth was a 4, and the smallest Chrysler was 6, (so the wheelbase is stretched for the longer engine.)
    I'd have to look up the models of Chrysler, but they had a 6 and several sizes of 8 cylinder ch***is. 31 and 32 Chrysler looks the same, the 6 was CM6 in 31 I believe.
    Leftover 31 style Plymouths were sold in early 1932 called 1932 PA with the older boxy styling.
    RMR&C likes this.
  6. Kreepea_1
    Kreepea_1
    RMR&C likes this.
  7. F&J
    F&J
    you're correct, no idea how I forgot about DeSoto. Hint, hint, old age
    Kreepea_1 likes this.
  8. Joel W
    Joel W
    I will try to get some measurements tomorrow. Kreepea1 what measurements are you looking for?
    RMR&C likes this.
  9. bschwoeble
    bschwoeble
    I just took measurements. The door width, at its widest is 37 7/8''. That's the door, not the opening. I can't open the door all the way to get the opening width. The measurement from the firewall to the pan at the lowest point below the deck lid is 103 1/4". I hope this helps. good luck.
    Kreepea_1 and RMR&C like this.
  10. RMR&C
    RMR&C
    from NW Montana
    Thanks! I still need the overall body width measurement across the B pillars if anyone can get that.
    I appreciate the effort
  11. Kreepea_1
    Kreepea_1
    bschwoeble, thank you for the offer. Like RMR&C, I need measurement between the pillars. Specifically, the A,B,C, and D measurements between the A Pillar and the B Pillar lower screws.
  12. bschwoeble
    bschwoeble
    I'd like to help, but my coupe is put away and it's sandwiched between cars.
  13. quickchangeV8
    quickchangeV8
    A good friend here in town has a 1932 Plymouth PB coupe. I'll drop over today and see if the coupe is in his shop or if it has been put away for the winter months. He is looking for a deck lid for that 1932 Plymouth PB coupe. If anyone has one or know of a deck lid that can be purchased, or any possible leads, any information would be greatly appreciated.
  14. Kreepea_1
    Kreepea_1
    Thanks bschwoeble! And my apologies because I meant to address my last post to @Joel W in response to him asking what measurements I needed.
    bschwoeble likes this.
  15. RMR&C
    RMR&C
    from NW Montana
    TTT one more time
  16. Joel W
    Joel W
    Sorry it has been such a delay- I must not have notifiications turned on for this thread- stumbled back into it by accident... Here are the measurements: A 40-1/2", B 48-1/2", C 35-3/4", D 35-5/8". I checked C & D multiple times. I can check another coupe body when it isn't so cold out. If I don't respond quickly, send me a message. Hope these measurements help!
  17. Kreepea_1
    Kreepea_1
    Thank you, @Joel W !
