Projects 32 make over started
Discussion in 'The Hokey Ass Message Board' started by pantodd74, Jan 3, 2025.
  1. 19Eddy30
    19Eddy30
    from VA
    There is 3 length's in Th350's .
    A Long tail most where in a station wagon.
    Most all other where in
    Car / trucks short & mid tail .
    Tow Truck Tom and mad mikey like this.
  2. NealinCA
    NealinCA
    With the factory panhard bracket, I'd say 58-64. I have a 64 Chevy rear in my 49 GMC pickup that I built in high school...and it uses that same panhard bar bracket.
    Tow Truck Tom and Outback like this.
  3. pantodd74
    pantodd74
    So I have a dilemma. I have a 700R4 blown apart in my shop that I can obtain some hard parts and a kit to rebuild it. Issue I'm having is finding a TH350 that needs rebuilt in my area. I don't want a new (refurbished) one because I can do it myself. The 700 is a bit longer than the 350 but I can fab a new cross member no problem.I'm thinking I should use what I have and it will be a better driver with the OD. Also I know I need to confirm the rear gear before I get a cam and torque converter. Just looking for a mild mannered street rod that momma can enjoy but also show off.
  4. alchemy
    alchemy
    Change the rear gear to fit your engine build, not the other way around.
  5. snoc653
    snoc653
    from Iowa
    The 700r4 has a lower 1st gear than the 350 and will give you better off the line power. The .69 final drive gear will tame the highway RPMs. I would definitely use the 700 rather than wasting time looking for a 350. The biggest challenge will be the TV cable routing and adjusting it.
    1971BB427 likes this.
  6. 325w
    325w
    55-6 no drain on the bottom. 57 started drain on the bottom. 57 a difference in axle bearing over 5-6.
  7. pantodd74
    pantodd74
    The TV cable on the 4 bbl is not an issue. If we decide to run the tri-power I see an issue there with the TV cable.
    Outback and SS327 like this.
  8. nochop
    nochop
    from norcal
    I ran a t 400 on my Tri power olds , no kick down cable
    Tow Truck Tom, 19Eddy30 and SPEC like this.
  9. ALLDONE
    ALLDONE
    THAT'S EYE CANDY RIGHT THERE!!!!
    Vic Walter, dana barlow and nochop like this.
  10. pantodd74
    pantodd74
    Alot of progress today. Unfortunately the body is not coming off the frame. It's welded and bolted together. The clutch is fried hence it slipping. Looks like I will have to pull the rear end out and undo the antiquated rear suspension and install the new improved parts. Not a big deal. 20250110_115007.jpg 20250110_133504.jpg
  11. pantodd74
    pantodd74
    Mods can you fix the pic's to just the 2 not the extra copies? I didn't realize it was doing that.
  12. glennpm
    glennpm
    "Glennpm what are the indicators I should look for on the rear end?"
    Nailhead A-V8, GuyW and Vic Walter like this.
  13. pantodd74
    pantodd74
    Per your axle pic's it is a '57 rear end.
  14. MCjim
    MCjim
    from soCal
    Those are some seriously traditional welds...
    Just Gary and project starter like this.
  15. deathrowdave
    deathrowdave
    from NKy
    If she ain’t leakin , she’s empty ! Better add some ! Loved the old primaries , flow trough design , no recirculating that oil
  16. pantodd74
    pantodd74
    MCjim yes they are! I looked it over real good and if I do anything I will grind them down and MIG over the top. I will know more once I pull the floor out and see the rest of it. Tomorrow I hope to pull the floor, remove the T10 and yank all the wires out of it remove the dash to see what is hiding under it. Also hope to get the flywheel off the motor and on the stand. I'm curious of what is inside.
  17. clem
    clem
    You can do it yourself, edit post and delete extra photos.
    Tow Truck Tom, Outback and pantodd74 like this.
  18. Keep up the good work....I'm enjoying your progress and will be following!
    Tow Truck Tom likes this.
  19. pantodd74
    pantodd74
    Tore the motor down today. Alot of copper showing on some of the rod and main bearings. Motor is .040 cast rotating ***embly. The pistons have the normal wear on the skirts. The heads are the best part of the motor. 2.02 camel backs. It is an 010 block 2 bolt mains. Now the wife and I will toss around what we're going to build. The T10 is out as well. After lifting the floor out of the car I see someone installed an adjustable proportioning valve in the rear brake line. I was telling her last week we can add a line lock or trans brake to do some good burnouts. No longer needed as I can turn the knob and increase or decrease the rear brakes. 20250112_191251.jpg 20250112_184434.jpg 20250112_184424.jpg 20250113_143245.jpg 20250113_124950.jpg 20250113_124945.jpg
  20. nochop
    nochop
    from norcal
    Keep it up!
  21. pantodd74
    pantodd74
    So after some thinking I have a plan. Instead of taking the block to the shop I'm going to build the block I had worked over for my Chevelle. It's an 010 block already bored out .040 and ready to be built. So time to find the right stroker kit, cam, lifters, rockers, pushrods and torque converter to work with the rear gear. I will run a trans cooler on the 700R4 as well. Also have to measure the radiator I removed and get a new one. I have looked at Champion radiators and will get their electric fan/shroud combo. After removing the floor I noticed the single bowl master cylinder. Who sells upgraded brake parts for the 32? Can the 57 rear drums be converted to disc? I will do the research but like to hear from ya'll who have already done what I wanna do.
  22. patsurf
    patsurf
    easier to change whole rear axle!
  23. Corn Fed
    Corn Fed
    Yes there are disk kits for the rear, but you don't need disks. That little roadster is so light it will be fine with drums. I have a 55 Chevy rear in my full fendered 32 coupe and it stops pretty good...and it even has '48 Ford front drum brakes.
  24. pantodd74
    pantodd74
    Yeah the more I thought about it just rebuilding the drums will be fine.
    Tow Truck Tom and Algoma56 like this.
  25. tjm73
    tjm73
    Taking the time and effort to swap an automatic and using anything other than an overdrive is silly in my opinion if this car is going to get driven a lot. Too many pluses to not do it. 200R4 or 700R4 without electronic control would be my choice with your current engine.
    Looks like a cool car. Sounds like a cool wife.
    Tow Truck Tom, Outback and Algoma56 like this.
  26. 57JoeFoMoPar
    57JoeFoMoPar
    All this work to the engine and transmission seems like rearranging the deck chairs on the ***anic if you don't address this ch***is. IMHO that's the biggest issue this car has. You can find a decent running SBC that doesn't leak on Facebook marketplace for $500 and have it installed in an afternoon. That ch***is is a bigger concern. That goes extra with the fact that you're telling us the body is welded to the ch***is with plywood floors screwed down. If you're replacing the engine, transmission, and wiring harness, and also having to fix the brakes and rear suspension, you're halfway through rebuilding the entire car. You might as well address all of the issues at once and have a solid, safe, reliable car when you're done
    Especially for a common year and make like a 32 Ford, getting a new aftermarket ch***is makes the most sense IMHO. Good rails with proper suspension, an actual sheetmetal floor, new running gear and wiring... will pay dividends and ensure another 60 years of use.
    Algoma56 likes this.
  27. pantodd74
    pantodd74
    I have looked into a new ch***is and it's out of our budget. We have been driving and enjoying the roadster for the past 2 years. I'm going to build the motor and trans as I already have both. The rear suspension is going to be all new. The front is going to get some new bushings and shocks. As for the body being welded and bolted to the frame. That is a can of worms that I'm not going to open. It's been that way since 1961 and it's going to stay that way. Even trust worthy friends that build cars agree. I will most likely be fabing a sheet metal floor instead of plywood. tjm73 she is the best wife!
  28. AmishMike
    AmishMike
    Always easy to spend other people’s money. Enjoy what u have with minor fix up, just keep it safe. What’s wrong with plywood floors, anyway?
  29. alchemy
    alchemy
    I would bet that the easiest rear suspension to install in this roadster, and it’s traditionalish too, would be a Pete & Jake ladder bar set with their transverse spring mounts too. Order a catalog from them and it will teach you all you need to know about hot rod suspension. It’s as much a technical manual as a catalog.
    This will be easier to set up than a four bar, will ride great, is tunable to a degree, and looks great if anyone was to poke their head under the back end.
  30. dirt car
    dirt car
    from nebraska
    As my dad always said " If someone is bending over giving a look, plant a boot in their slacks"
