Convert 1936 Wide Five to Juice Brakes
Discussion in 'The Hokey Ass Message Board' started by fordmanbernard, Mar 20, 2012.
  1. fordmanbernard
    fordmanbernard
    from Idaho
    I am wondering if there is a conversion kit out there that will allow me to convert wide five to juice brakes. I am also looking to convert the rear axle to an open driveline.
    I am looking for Links to info and good knowledge to get me going.
    Kent
  2. oj
    oj
    You must have the early wide5 because it was wide5 that introduced juice brakes in '37? Anyway, no conversion needed - just a backing plate.
    Open drive conversion? been a few good threads on doing them - try the 'search function'
    Welcome to the hamb, those were good questions and you are in the right place.
  3. I have 2 open drive banjo's from trucks. 46-47 Ford f1's. You are a long way away though.
  4. justabeater37
    justabeater37
    Juice brakes in 39 I thought. I also think that 36 has different spindles. Somebody jump in and correct me. Have you talked to Wilson Welding or the like for a conversion with new parts?
    51 mercules likes this.
  5. Richard at Early V8 Garage
  6. wilson welding has a nice kit.will fit only 39 up spindles.some mod still needed.I have a 36 ford with this setup.bendix design.good braking.39 spindles will fit 36 axle.
  7. mastergun1980
    mastergun1980
    from Alva OK
    I'll break it down - 36 has the older style spindle - You want 37 up spindles - 39 was the first year Ford had juice brakes and 39 is wide five. But 37-4 are the same spindle ( round back ) - The 42 - 46 is square back ( not like the earlier 36 and back ) look for 1/2 dia mounting holes for thae backing plates ( early have 3/8 holes )
    I think you might be able to use the 37-38 drum with hydrolic backing plates but I'm not sure.
  8. DICK SPADARO
    DICK SPADARO
    Lets clarify some of the mistakes of the previous posters. First to install Hydraulic brakes on a 1936 Ford and retain the wide 5 style bolt pattern you CAN use the stock 36 spindles. Installing later 1939- 48 backing plates gives you the hydraulic backing plates but require the use of a spacer ring to center the plates on the spindle snout. The brake drums required are 1937-39 Ford everything just bolts together. The tricky part is the clutch and brake pedal, it is possible to use the 1939 hydraulic pedal ***embly on your 36 frame with slight modification or purchase a unit from early Ford V8 Garage that allows you to use the stock pedals with a remote positioned master cylinder.
    Converting your ear end to open drive is not difficult, you can purchase a unit that will just bolt on to convert your rear banjo to open drive.
    Kiwi 4d likes this.
  9. fordmanbernard
    fordmanbernard
    from Idaho
    Thank you guys for the help.
    I have a custom Tube frame that I have built for a model A and I have some extra axles from my '36 build that I never used. I want to make the front and rear juice brakes, and open drive shaft. I plan on splitting the wish bones and doing a suicide front axle mount.
    I just need to know how to convert the brakes for sure. I already have them and don't really have a choice to buy anything else. Is there a place to buy them or will I need to just search for the backing plates and drums?
  10. need louvers ?
    need louvers ?
    What **** was saying was that you can use your '36 wide five drums with the hydraulics. There is a adaptor/spacer kit that is available through any early Ford shop(and certainly **** himself) to help with the backing plate situation. As far as original backing plates, your on your own as far as finding them, but '39-'48 is what you are looking for.
  11. I second your suggestion:
    Richard Lacy at earlyv8@aol.com, (626) 338-2282
    Charlie Stephens
  12. fordmanbernard
    fordmanbernard
    from Idaho
    Can the backing plates be off a car or pickup?
  13. pasadenahotrod
    pasadenahotrod
    from Texas
    NO, that is not what **** was saying. You cannot use 36 hub/drum ***emblies with hydraulic brakes. You must find 37-39 hub/drum ***emblies to use with the hydraulic brake backing plates.
    It is easier to just find a set of 37-41 Spindles and not have to use bearing spacers and spacer rings on the old ones. There are plenty of 39-48 hydraulic backing plates around to make your front and rear conversion without much h***le.
    The hardest thing to find will be a good set of 37-39 hub/drum ***emblies.
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    Yes. 39-48 car or 39-47 pickup.
  15. Bruce Lancaster
    Bruce Lancaster
    to clarify even more...you need '37-9 front drum, '36 rear will work.
    '32-5 spindles are early, '37-9 are late. '36 are confused...early bolt circle, late spindle pin. As **** said, you need the adapter ring to center the backing plate, you can toss the other part of the common adapter kit because '36 bearing spacing is late type.
    You can use '39-42 or '46-48 backing plates.
  16. Bruce Lancaster
    Bruce Lancaster
    On the rear drum...I have never actually handled a '36 rear drum, but '37-9 drum is its service replacement so I ***ume it will work. '36 front drum cannot be used because backspage is wrong.
  17. fordmanbernard
    fordmanbernard
    from Idaho
    Thank you all for the Help.
  18. Very helpful thread!
  19. Richard (EV8G)
    Richard (EV8G)
    Thanks to those who suggested/recommended us...
    There IS one way to convert a 36 (fronts) to hydraulic and use the original hubs/drums,
    ***uming that the drums have not been machined past 12.060" diameter (or whatever
    limit is determined after a typical big argument - but the thicker the drum, the better!)
    39-40 LINCOLN BENDIX "deep" brakes will fit the 36 front spindle after grinding the top
    of the spindle for clearance with the "ledge" below the wheel cylinder. ALSO must use
    a special Kingpin/Bearning kit (our exclusive) as the "sockets" on the original 36 kingpin
    for the mechanical brake linkage IS right in the way, as is the bearing. Our kit moves
    the bearing/load-carrying to the bottom of the axle. These 39-40 deep Lincolns have
    the same inward offset as the 36 (and 35) original brakes, so everything will line up ok.
    The brakes are a little scarce and expensive, but they are WAY better than the Ford/Lockheed brakes!!!
    36 rear drums can be used with rear hydraulics, as they have the same offset as 39's
    and ARE interchangeable. Yes, 39 first year hydraulic brakes. Most 36 rear hubs have
    a SLEEVE in them and therefore use the smaller rear bearing BUT still use the larger rear
    seal. In fact, some 37's still have that arrangement - transitional phase... 36 rears do
    look different, with variations even within that year, but 37-38-39's (one piece or two)
    are interchangeable.
    The 36 front spindles have the smaller bolt pattern and 3/8" bolt holes BUT they have
    the "wider boss" to space the inner bearing correctly AND for the grease seal to ride on.
    I always thought the 35's had a thinner boss, but have found 35's with the wider also.
    So, when using the adaptor kit, only need the spacer ring for the brake plate BUT the
    typical $20 kit includes both - and they are two brittle-and-too-thick piston rings that
    often shatter when the bolts are tightened, and the bearing spacers are actually two
    valve seats that are wrongly-dimensioned. We offer a DELUXE kit like the one that Dave Wilton used to make that is far superior (and of course costs alot more) but we will sell
    you only what you need, so that makes it not so bad... Our bearing spacers are a press
    fit onto the spindle, so they do not rotate and provide a surface for the grease seal to ride on... but not required for 36 and many 35's... they are required for 32-34 and some
    35's. The part of the kit that you do need for 36 are two flanged spacers that are drilled to match the hole pattern and sizes of the spindle bolt holes (3/8") and have an integral ring that fits between the grease shield and brake plate and causes the large center hole on the brake plate to be reduced to fit the spindle. Just have to file little quarter-moons from the original 1/2" holes just into the large center hole, allowing the original bolts to p*** through.
    Thanks again!
    Richard
  20. Matlack
    Matlack
    Nice thread, I just started my 36 5 window and this will be very useful! I am trying to keep it a traditional hot rod, but it seems it will be harder than I thought it would be.
    thanks
  21. Orlen
    Orlen
    from Denver, CO
    Old thread but still great info to me.
    Thanks!
    Nailhead A-V8 likes this.
  22. |Tom|
    |Tom|
    To the top. Great info!
  23. Admiral Tom
    Admiral Tom
    Great information, but, too bad the Early V8 Garage is no longer around! Boling Brothers might be a reasonable subs***ute to get started as far as install kits, but you still need to find those ever elusive 37-39 Ford Front Drums for a Wide Five install if you want to keep your 36 spindles.
  24. The Early V8 Garage is still around but it's a one man operation since Richard retired so it can be hard to get in touch with Dennis who runs the shop by himself nowadays. Dennis is also active here on HAMB @Dennis Lacy
    37slantback likes this.
  25. @BlueNotes is correct. His son Dennis @Dennis Lacy runs the shop now, and you can still get everything from him. Just be patient, as he is a one-man shop.
    hotrodjack33 likes this.
  26. Dennis Lacy
    Dennis Lacy
    Yes, Early V8 Garage is still alive and well. My Dad, Richard, stepped back in August of 2023 following some health and cognitive issues. I am now running the shop and still producing our hydraulic brake conversion master cylinder bracket kits, hand brake kits and pre-formed brake lines. Also still a fully functioning physical shop.
