Technical "will it run" '63 Olds 394
Discussion in 'The Hokey Ass Message Board' started by Paul, Jan 18, 2025.
  1. Paul
    Paul
    Editor
    I posted some of this to the what are you working on thread but thought maybe it should have it's own thread so...
    I have a few search words I cruise the local ads with.
    this engine came up a little over a week ago.
    so I made the twenty minute drive out to take a look.
    it was sitting on a pallet outside under a tarp but it was complete and I could turn it over by hand with the fan.
    the price was dirt cheap so I figured it was worth taking a chance,
    if nothing else it had parts potential, like the number 23 heads, the ones you want for the 394.
    so I brought it home and hung it up to dry over night
  2. Paul
    Paul
    Editor
    the next day I set it on the floor and took a closer look
    and ordered a carburetor kit
    PXL_20250108_181808615.jpg PXL_20250108_181814602.jpg PXL_20250108_181824852.jpg PXL_20250108_181830187.jpg
  3. Paul
    Paul
    Editor
    day three the carburetor gets a rebuild
    before picture for visual record of how the linkage was arranged
  4. Paul
    Paul
    Editor
    pulled the distributor and cleaned it up and spun it on the machine to check all functions, all good.
    scrounged my parts pile for ignition tune up stuff,
    found points, condenser, rotor, cap, plugs and plug wires, some new and some good used.
  5. Paul
    Paul
    Editor
    and it fired right up
    ran it for about a minute or two
    just long enough to see it was worth further examination
    Okie Pete, Moondog13, Tuck and 34 others like this.
  6. Having experience working on those specific engines I really have no doubt it'll run. I've seen 394s that shouldn't be able to start up drive across town into my shop lol. So count me as a vote if confidence in your Engine. Saw one that was stuck fry a starter trying to start it. Guy that had it went and got another starter and it rattled to life lol
    Okie Pete, Tuck, bchctybob and 6 others like this.
  7. Paul
    Paul
    Editor
    I have been wanting to build another run stand,
    so this seemed like a good time to do that.
    again, back to the misc parts and materials stash
    and put together a basic stand,
    this one is for now anyway '63-'64 Olds specific,
    to mount the '49-'62 Olds engines will require an alternate front support,
    not a big deal.
    I hooked up water temperature and oil pressure gauges,
    found an NOS fuel pump in my stash I'd forgotten about! that was a happy find.
    mounted the engine and ran it
    Okie Pete, Moondog13, Tuck and 25 others like this.
  8. Bandit Billy
    Bandit Billy
  9. Paul
    Paul
    Editor
    I could see and hear something was not all right.
    it sounded like one cylinder was not hitting.
    did a compression test and yep, number 3 was dead.. like zero dead.
    the rest were good, a bit of a wide range between highest and lowest but good.
    the guy I bought the engine from said it had been outside under a tarp for "a few years"
    I figured number three intake must have been open and water had found it's way in.
    best case a hone and re-ring, worst case serious pitting to the cylinder wall trashing the block
    Okie Pete, OFT, bchctybob and 10 others like this.
  10. Paul
    Paul
    Editor
    today I pulled the head to see what the damage was..
    number three cylinder shows carbon near the top from ring failure
    I used acetone and a grey scotch brite to gently clean the carbon
    which revealed some vertical scoring, not severe but not good either.
  11. Paul
    Paul
    Editor
    and that is where I'm at right now.
    Okie Pete, Tuck, bchctybob and 14 others like this.
  12. Paul
    Paul
    Editor
    I have gaskets to put it all back together
    which I am tempted to do
    but I have no doubt the rings have been compromised and would fail again quickly.
    I believe if this is to go back together and live for any length of time it will need at least a hone and ring job.
    Okie Pete, Tuck, 34 5W Paul and 8 others like this.
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you foresee a use for it , I'd do it right , everything back to better than stock , that's smooth , torquey reliable engine .
  14. Paul
    Paul
    Editor
    I agree but right now it's just an interesting distraction.. distraction number 2 at that..
    I should be focusing on distraction number 1
    the '60 371 in the corner..
  15. Tim
    Tim
    from KCMO
    Is that a model A radiator on the run stand?
    Moondog13 and Sharpone like this.
  16. Paul
    Paul
    Editor
    yes it is, non pressure, in fact I don't even have a cap for it right now, it's my only spare radiator that doesn't leak!
  17. Tim
    Tim
    from KCMO
    I hear a ton of people talk about running them back when that’s all they had access to with no trouble. Hear less people admit to doing it now
    bobss396, Sharpone and Paul like this.
  18. Sharpone
    Sharpone
    Neat engine I like it
    Dan
    Paul likes this.
  19. oldsmobum
    oldsmobum
    from SoCal
    Very cool engine, but glad it wasn’t me because I would have brought it home too and I don’t have any room! 0 psi on cylinder 3 is a little dramatic… Did you check the valves on that cylinder? The only time I ever had nothing on a cylinder was a bogus exhaust valve… The seat was completely missing!
  20. Paul
    Paul
    Editor
    I couldn't leave it alone.
    'pulled number three piston,
    both compression rings were in pieces.
    updates forthcoming
    may not be for a few days though
  21. bobss396
    bobss396
    My first personal engine I dove into was a 394 in my '64 Olds 88. The car itself was in amazing shape. But... it needed a valve job first.
    I was 18 and low on bucks. A local shop did the heads over and it needed a few things, the total came to $57. With gaskets and oil change supplies, the grand total came to $90.
    It ran quite well after it went back together. I found some chrome valve covers for it and some other parts from a friend who was junking a '63 Olds.
  22. Paul
    Paul
    Editor
    I had a few cars before getting my first Olds, a 1962 98 holiday sedan.
    It must have been in about 1980.
    I've had lots of cars since but that one car made an impression on me, the power, style, ride and feel. so much power, room and light it really was a pleasure to drive.
    Tuck, bchctybob, Jeff Norwell and 3 others like this.
  23. treb11
    treb11
    Those ribbed valve covers are pretty. Not garish or wierd. My $0.02
  24. bobss396
    bobss396
    I thought my '64 88 was smooth until I took my dad's car pooling buddy's '62 Catalina in for service one day.
    Like driving a cloud, ultra quiet and 2x more power than my car and low miles.
    bchctybob and Paul like this.
  25. 38Chevy454
    38Chevy454
    That looks like a great find. The correct way would be to give it a quick hone and re-ring, and touch up the valve seats while heads are off. That should be good for long time, I wouldn't bother with bottom end as the oil pressure looks fine. Just clean out the pan and what sludge inside the engine you can. But the low budget short term fix could be just new rings on #3, and slap it back together. It's pretty amazing how durable the old engines can be, and how long a quick fix can work and keep going.
    I like the run stand, seems to work just fine!
  26. Tim
    Tim
    from KCMO
    they are the stock covers
  27. rob-redm
    rob-redm
    damn , now I feel bad junking the 394 I had in the garage from 61 Olds 2 dr post I owned.. cool car... never had seen a lower buck Olds , body painted reveal moldings around the side gl***.. front and rear was stainless. Russian guy came and bought it.. a few years later it was at the Portland swap running and driving for sale.. Was fun listening to the guy tell me about it ( lol) .. his whole tune changed after I showed him the picture I had when it was on the trailer coming back from Graham/Kapowsin . ..
    Algoma56, Sharpone and Paul like this.
  28. Paul
    Paul
    Editor
    I'm really trying to make this an inexpensive exercise.
    like as close to zero cash outlay as possible.
    I have other better things to spend my money on,
    like the Delta blower drive setup I've been pursuing..
    not counting parts I already had on hand I'm at just over two hundred bucks,
    that's initial cost of the engine plus carb kit, gaskets and misc little ****.
    that was until I ordered an NOS set of piston rings off ebay, hey only $33.00 shipped to my door.
    they arrived today, I don't know what they fit but it sure isn't a 394.
    damn..
    I could order a set from one of the local parts stores and have them this afternoon
    but that would definitely blow my budget.
    I may get creative and do the unheard of..
    the thought that keeps coming to mind is when I was an engineer's ***istant on a small ship almost fifty years ago,
    one of the mains ****ed a valve crossing the gulf of Alaska.
    we tore down the engine while motoring in circles in twenty foot swells,
    raided the spare parts locker and patched it back together just enough to get to port.
    then tore it all down again and put it back together right.
    not the same but in some situations you make due with what you got.
    stay tuned
    Okie Pete, Moondog13, Tuck and 12 others like this.
  29. Sharpone
    Sharpone
  30. Paul
    Paul
    Editor
    thanks Dan,
    I've taken your advice and placed an order.
