Hot Rods DROP AXEL,.. HOW HARD COULD IT BE???
Discussion in 'The Hokey Ass Message Board' started by ALLDONE, Jan 18, 2025.
  1. ALLDONE
    ALLDONE
    APPARENTLY ... TOO HARD FOR ME....LOL
    all I wanna do is change out the stock axel to a 3''/ 4'' drop... pretty easy right>>> the axel has juice brakes and a reverse eye spring.. measuring spring pearh center... around 37''... king pins are at 50'' +/- just wanna swap the axel....after market... /speed way all say 46 and 48'' king pins????? can this be done??? what am I missing????????????????????
  2. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    If all you want to do is lower the car an additional 3/4 inch isn't there an easier way to do it?
    Re-arch springs?
    Move the spring perch/ crossmember up?
    Smaller tire?
    Stogy likes this.
  3. buffaloracer
    buffaloracer
    from kansas
    I think he is looking for a 3 or 4 inch drop. Common to lose two to four inches when dropping a stock axle. Shorten up the tie rod and you are ready to go.
  4. lostone
    lostone
    from kansas
    Yep as you drop the axle the king pin boss moves in. Think of it this way, lay your elbow on a table, move your fist straight out now as you raise your fist while keeping you elbow on the table the flat plane measurement between your elbow and fist gets smaller. Even though the distance between your fist and elbow never change.
    Now there are/were gents that also stretch the neck of the axle as they drop it to help keep the distance between the king pin bosses really close to factory.
    So your only choice may be to find someone that has the ability to stretch and lower at the same time...
    ALLDONE likes this.
  5. ALLDONE
    ALLDONE
    3'' or 4''
  6. ALLDONE and Stogy like this.
  7. Teenagers in the 50s did it
  8. Pete Eastwood
    Pete Eastwood
    from california
    "how hard could it be" Hahahahahahaha . . . . . .
  9. catdad49
    catdad49
    Snowball!
    ALLDONE likes this.
  10. Clydesdale
    Clydesdale
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Duh! My bad. I was rading .75". LOL
  12. 1946caddy
    1946caddy
    from washington
    panhead_pete likes this.
  13. Happydaze
    Happydaze
    Im ***uming this is the car. Narrowing the track some I'd have thought would be a great thing. Yeh, drag link and tie rod would require shortening and alignment redone, but this isn't a big deal.
    Chris
    ALLDONE likes this.
  14. ALLDONE
    ALLDONE
    not the car, I'm working on a 31 vicky... but, thats my car...where did that pic come from... not my garage????
    turboroadster likes this.
  15. ALLDONE
    ALLDONE
    00p's that me at the tire shop....
    turboroadster and dwollam like this.
  16. ALLDONE
    ALLDONE
    so as you can see, it needs to come down alittle in the front
    Just.dale and 40ragtopdown like this.
  17. rusty valley
    rusty valley
    You always use the king pin thats made for the spindle you are using. Is your hydraulic brake setup using the model A spindle yet? Have Sid drop an A axle, they are common, forget speedway
  18. DuraGlide
    DuraGlide
    You are going to want to narrow the kingpin width when you drop the axle. Otherwise, the tire is going to be against the fender as soon as you turn from straight ahead. Narrowing puts the tire more in the center part of the fender and gives some room when turning before the tire hits the fender.
  19. nobby
    nobby
    what is the perch distance on that? 2 1/4
  20. AccurateMike
    AccurateMike
    SS327, clem, WhyW8 and 1 other person like this.
  21. uncle buck
    uncle buck
    AccurateMike likes this.
  22. ALLDONE
    ALLDONE
    42-48 spindles
  23. ALLDONE
    ALLDONE
    tire is in already with a 50 1/2 axel...
  24. ALLDONE
    ALLDONE
    Oh, and I lowered the headlights on the vic and wifes 29 rpu..
  25. ALLDONE
    ALLDONE
    if i go with a stock 36 ford axel... i should be golden
  26. panhead_pete
    panhead_pete
    34 Axle, 32 Perch Pins, Round back spindles. Reverse eye spring. Couple spacers for the bones.
    But I prefer the look of an undropped axle.
  27. ALLDONE
    ALLDONE
    why do you need spacers on the wish bone????
  28. clem
    clem
    doesn’t that already have a dropped axle ?
    possibly 2” axle perch with a 2&1/4” wishbone boss, thus 1/4” spacer.
  29. ALLDONE
    ALLDONE
    so my idea here is to keep this car kinda pre war .... or close...need an inch or so more drop... And seems like a middle 30's axel would do just that with the only other mod heating the steering arms... or drop rod ends....????
  30. ALLDONE
    ALLDONE
    ok,... I was thinking the other end...
