Technical Big Break ???
Discussion in 'Traditional Hot Rods' started by mark hogan, Jan 18, 2025.
  1. mark hogan
    mark hogan
    Running down the tarmac heard a thump pulled over? Gen-set hanging by wires. No belt no water flow towed home. Any ideas! IMG_5302.jpeg IMG_5304.jpeg
  2. Did you happen to initially install it without spacers to keep it above the fins? Am wondering if it was somehow cracked during initial installation?
    Also, how tight was the belt? Maybe you over-tightened the belt and it created a lot of stress/load on the bracket (that would be my best guess). You don't need a lot of tension on these wide belts - many folks tighten them way too much.
    You were fortunate that this didn't cause a big/major issue when it happened . . . the Hotrod Gods were on your side that day!
  3. Budget36
    Budget36
    Cast aluminum failure.
    Anderson, abe lugo, mad mikey and 3 others like this.
  4. In_The_Pink
    In_The_Pink
    Maybe just too much stress for a cast aluminum bracket, especially after belt tension is factored in. Steel might be a better, but less sexy, option?
  5. mark hogan
    mark hogan
    It was a (speedway) part. It has stand off’s in casting to clear finned head. Belt was tight. Has a long leg to left water pump. Just blew my mind.
    silent rick likes this.
  6. Mike VV
    Mike VV
    from SoCal
    Pretty simple...metal fatigue, equaling a broken part.
    Probably starting with a porous (full of air!) casting.
    Could have been exacerbated by a VERY tight belt, and or possibly an out of balance armature .
    Mike
    mark hogan likes this.
  7. Bandit Billy
    Bandit Billy
    And now you get to untorque three head bolts to replace that bracket. It is why I used studs, torqued down nuts (rocker stands) and then the bracket and the polished acorns. Just an idea for all of you contemplating the gen mount on the head.
    I used the Navarro bracket from H&H and I have not had an issue with it. Call Mike and have him send one out.
  8. lostone
    lostone
    from kansas
    I'd say, aluminum, heavy generator, engine vibration, road pot holes, stress constantly changing due to engine rpm's and fan belt, equals failure...
    And no other support to the rear of the generator.
    5window, Tow Truck Tom and mark hogan like this.
  9. chicken
    chicken
    from Kansas
    Weak cast aluminum bracket. Use steel or fabricated aluminum and it'll be good to go.
  10. Fordors
    Fordors
    Speedway sold the bracket, they had nothing to do with the design or manufacturing. It is an Offenhauser product.
    Tim, 5window, Big Al and 2 others like this.
  11. mark hogan
    mark hogan
    That I understand.
  12. 29Sleeper
    29Sleeper
    from SoCal
    Show photos of the crack faces. That will show if it was a bad casting to one the had been progressing for some time.
    mark hogan and mad mikey like this.
  13. Budget36
    Budget36
    Can you “glue” it together and fabricate out of steel?
  14. woodiewagon46
    woodiewagon46
    from New York
    If you know someone that can TIG weld aluminum, I would repair it and fab 1/4" aluminum gussets to strengthen it, where it broke sure looks like a weak point. Of course if you contact Offenhauser they will tell you that it's never happened before. Consider yourself lucky that the generator didn't take out your radiator or do any other damage.
    mark hogan and Fordors like this.
  15. 29Sleeper
    29Sleeper
    from SoCal
    Looks like a problem with the mold or design - the 1094 passenger side bracket has a clear path with no gusset. The drivers side 1093 shows a gusset that would prevent the break.
  16. mark hogan
    mark hogan
  17. mark hogan
    mark hogan
    Just wondering the brand of the 1093? Looks like way better design !
  18. 29Sleeper
    29Sleeper
    from SoCal
    They are both listed as Offy one is to mount the generator on the drivers side 1093 and the 1094 mounts it on the right. IMG_5307.jpeg
    mark hogan and Budget36 like this.
  19. The design could've have a raised rib edge and longer gussets. Maybe gussets off the bolts.
    Budget36 likes this.
  20. Ebbsspeed
    Ebbsspeed
  21. Looks like an alternator in your picture; did that require higher belt tension than the "loose" tension normally used on flatheads. Maybe add a rib to bottom of the new one.
    Stogy, Speccie and Budget36 like this.
  22. Rickybop
    Rickybop
    Bad design. Maximum force in exactly the worst direction on the weakest part of the bracket.
    5window and Unkl Ian like this.
  23. FiveNdime
    FiveNdime
    I have the same bracket, granted, I've only got about 500 miles on my setup. Curious on how many miles and time is on that bracket? Years, Months, Days? Did you hit anything large to jolt the car in a big way at that time? It would take bit to make that happen all at one time, so I'm thinking stress cracked before the final break, or a slow progressing crack.
    Stogy and mark hogan like this.
  24. HSF
    HSF
    from Lodi CA
    Made from 100% pure CHINESIUM.
    mark hogan and Unkl Ian like this.
  25. Unkl Ian
    Unkl Ian
    The design is one issue.
    And the alloy used, is a question mark.
    Was it made in USA ?
    Is it a real Offenhauser piece, or a cheapo imported knock off ?
    Not all Aluminum is the same.
    continentaljohn and mark hogan like this.
  26. mark hogan
    mark hogan
    I just finished the car. Been short 20 mile trips and home. About 300 miles on it I’d have to guess max.
  27. mark hogan
    mark hogan
    I kept it snug little play on long leg of belt.
  28. Fordors
    Fordors
    Offenhauser, cast and machined in California.
  29. mark hogan
    mark hogan
    Amazing the beef put into the driver side arm. Passenger side is a weak design I see.
    Unkl Ian likes this.
  30. twenty8
    twenty8
    A new product shouldn't fail like that if installation and operation was correct. Sounds to me like a fault with the bracket. Have you contacted Speedway and/or Offenhauser about the problem? That should maybe have been the first thing done, possibly before throwing it out here on the HAMB. You never know, a company that takes great pride in what they do might just look after the situation in a positive way for you. They should at least have that opportunity.
    5window likes this.
