Hydroboost brakes
Discussion in 'Off Topic Hot Rods & Customs' started by Roothawg, Jan 17, 2025.
  1. Roothawg
    Roothawg
    Back in the summer, I was at an NSRA event and there was a guy with a really nice 55 Chevy. Pretty much a traditional build, but I was noticing extra lines on his firewall brake booster. He xplained that he had pulled a hydroboost system out of a Tahoe. He was raving about it. Said it was the best invest he had ever done. I haven't thought much about it, but recently I have had to do some research on power steering and it popped up again in one of my google searches.
    Has anyone done this swap? I would think other than the extra lines, the benefits would far outweigh the negatives. It takes up less space than a vacuum booster and a car with a healthy cam would benefit from it. A guy could fab up some nice hard lines and hide them in the frame, just having a flexible joint at the pump.
    Thoughts? Real life experience?
    turboroadster and Ned Ludd like this.
  2. squirrel
    I've been toying with the idea, too. I had an 06 tahoe with it, the brakes felt just a little different than vacuum brakes, but worked fine. Sure helps with clearance between booster and valve cover, which will be an issue on the Checker when I put in the V8.
    Let us see how it works out for you, when you get around to it...
    Roothawg and 41 GMC K-18 like this.
  3. Roothawg
    Roothawg
    My 56 F100 has the C4 Power rack. It's not finished yet, but I was researching the pressures for the Corvette rack vs other PS pumps to make sure everything is sort of matched up. I have sent an email to Turn One, which specializes in PS pumps. Oddly enough, they are in Saginaw, MI. Probably a bunch of retired GM/Ford Engineers.
    squirrel likes this.
  4. Roothawg
    Roothawg
    This is an expensive setup, but there are folks out there selling versions for half this price. However, this one is the most compact I have seen so far. wilwood.png
  5. squirrel
    picture didn't come through? maybe post a link?
  6. TexasHardcore
    TexasHardcore
    from Austin-ish
    I had planned to use a '04 Mustang Cobra hydroboost system on my '56 F-100. I was going to use the Cobra pedal assembly, master cylinder,. hydroboost unit, etc. I eventually decided to skip the hydroboost altogether and use '04 Mustang V6 pedal assembly, master cylinder, and vacuum booster. Not exactly sure what changed my mind on not using the hydroboost, but it was probably a few factors such as additional cost, additional failure points, etc. I also felt that if there was a booster or master cylinder failure, I could easily get replacement parts at nearly any parts store for a V6 over a Cobra.
    Roothawg likes this.
  7. Roothawg
    Roothawg
  8. Roothawg
    Roothawg
  9. V8 Bob
    V8 Bob
    Bendix introduced the Hydro-Boost in the early '70s (I think '73) to provide good braking assist in larger vehicles and light trucks because of the low engine vacuum levels resulting from strict new emission standards, along with the new diesel options. H B was popular until the engines were able to provide ample vacuum, then started showing up in newer cars because of tight packaging issues. I worked on and tested many vehicles with Hydro-Boost over the years with no problems, as they were very well designed and built, but I have no performance or problem knowledge of the non-Bendix aftermarket units presently on the market.
    Main advantages are slender size, and very good performance.
    Disadvantages are cost, and necessary power steering pump and plumbing.
    Bob
  10. squirrel
    rockauto sells new units for the Tahoe for about 3 bills....
    The plumbing fitting might get interesting, but I expect there is decent aftermarket support.
    Notice that the accumulator is located differently in Root's two links, one has it up top, the other down low (near the valve cover). Looks like they just flip it over to move the accumulator out of the way. (that's the round part that sticks forward, it stores hydraulic pressure while the engine is not running, so you have brakes when you first fire up the engine). Normal OEM installation has the plumbing fittings on top
    bchctybob and Roothawg like this.
  11. miker98038
    miker98038
    I’ve got a hydroboost on my 55 bird, with 4 wheel disc. It’s been there close to 20 years, before they got popular. Originally a diesel Olds unit. Even with a shorter brake pedal arm it’s pretty sensitive. Reminds me of the old Plymouth’s from the early 60’s. There’s a Height’s pressure valve in the line to reduce boost too. Much lighter than my 05 Yukon.
    I did it for clearance problems (hood latch and battery). But it’s a lot of brake on a small car. Something heavier it would be better probably.
  12. Roothawg
    Roothawg
    IMG_4652.png Here’s a basic schematic.
    bchctybob and porkshop like this.
  13. I've done a couple. I'm a believer. I have used Mustang parts which have become unobtanium because of low production numbers. Because there are several producers of brand new parts, other than the cost, I think they are better than vacuum boosters. At the risk of getting tarred and feathered, I want to mention that the elect. units from various new cars have been used very successfully. There is a company that adapts the late model mustang elect. power rack and pinion to a crown vic swap. If the goal is to always improve, it might be wise to consider some options that are current. If you're tired of power steering pumps and the occasional leaks with hydraulics, it is something to consider. 3 of my last 4 projects have been hydroboost. :)
  14. oldolds
    oldolds
    Chevy 1/2 ton vans and trucks used this in the 90's. Basically a trouble system.
  15. squirrel
    Chevy used them from the 70s to the 2000s....long time to be in use, some of them gave trouble, some worked a long time
    SS327 and Roothawg like this.
  16. Okie Pete
    Okie Pete
    Diesel powered pickups use this system.
  17. Roothawg
    Roothawg
    Ned Ludd, ekimneirbo and Okie Pete like this.
  18. rockable
    rockable
    I have a friend who has built several rides with CPP hydroboost and won't use anything else.
  19. ekimneirbo
    ekimneirbo
    I'm putting some on my 99 S10 because of the valve cover clearance. Here is an old article on doing the change. On mine, which I've installed an LS3 in, I thought about the fact that the fluid reservoir was designed for Power Steering and was kinda small. I made a somewhat larger tank with 2 return lines because I felt larger capacity might be helpful. The old HAM shaped power steering pumps can be had with either 1 or 2 return lines. The newer pumps (as far as I know) only have one return. People "T" the return together. I didn't like that solution, so my tank has provisions for 2 returns. Just my personal choice....don't know if it helps or not.
    And a little more helpful(?) info
    Okie Pete, Ned Ludd, Roothawg and 2 others like this.
  20. Black_Sheep
    Black_Sheep
    I’m currently waiting on a hydro-boost kit for my ‘69, the cam in the 440 doesn’t make enough vacuum to run a conventional power brake booster. I asked a lot of questions of owners who had a hydro-boost on their cars, everyone I spoke to was happy with the upgrade. The manufacturer says that I will have 2000 psi at the wheel using their system. The car has 11.75 front disc with 4 piston Wilwoods and stock 11” rear drums so it should stop really well. I guess I will find out…
    Roothawg, ekimneirbo and SS327 like this.
  21. My 04 half ton 2wd suburban has one. Not sure how the factory decided who got vacuum brakes and who got a hydroboost.
    Mine is leaking PS fluid like a sieve currently, and this thread reminded me. I have a new Delco unit but it's pretty cold out so I'll just keep refilling it.
    That might be a negative, that it could leak when worn out, but I'm sure your hot rod won't have 200k+ miles like my old Burb.
  22. Roothawg
    Roothawg
    That's good to hear.
    This was the 1st install on the white 51. The truck had a 4.6 2 valve but the engine bay got full. I used factory lines on that one. The next unit I did had aftermarket plumbing and was way neater. More expensive but looked like it belonged on a rod. DSC02649.JPG
    Okie Pete, Dick Stevens and Roothawg like this.
  24. Roothawg
    Roothawg
    I think it's the way to go. I will just have to wrap my mind around how everything gets plumbed, so I can use as many hard lines as possible.
  25. If you do a little research, you will see that some of the cobra kit guys have run hard lines down to short flex lines on the engine. I got lazy and didn't do that. They polish the lines and it does look good. :) Did I mention lazy? LOL.
    Okie Pete and Roothawg like this.
  26. mustangsix
    mustangsix
    These days it might be easier to use an electric booster-master combo from a Tesla, Nissan, or Honda, esp if you don't have a pump already.
    Several different configurations that will easily fit in the same space. Looks like just three or four wires to hook up.
  27. Roothawg
    Roothawg
  28. mustangsix
    mustangsix
    Yikes! The junkyard Honda version costs about a tenth of that one!
  29. Ned Ludd
    Ned Ludd
    If like me you're prone to runaway research, the question arising out of making peace with an otherwise redundant power steering pump is, how about go full Citroën? Do everything hydraulically: power windows? air suspension compressor? heater fan? what else? Not one single electric motor in the entire car, because it's all hydraulic.
  30. squirrel
    then everything could leak! What could possibly go wrong? :)
    (we had a Citroën when I was a kid)
    Dick Stevens, Ned Ludd and Roothawg like this.
