Hot Rods Hello new member and purchase questions
Discussion in 'The Hokey Ass Message Board' started by AZ 32 Highboy, Jan 19, 2025.
  1. '29 Gizmo
    '29 Gizmo
    from UK
    Looks like an aftermarket box section frame so it's a in effect a kit built car. It's all down to how it's ***led. Nice looking though!
    alanp561, AZ 32 Highboy and Stogy like this.
  2. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    No money has been out anywhere. They are expecting $5k when the funds clear from Carvana Tuesday.
    Stogy likes this.
  3. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    I will check out the cl***ifieds, but I am always on Hemmings, have a subscription to the Bible lol that everything is over priced on. I am always looking at Craigslist and Facebook marketplace.
    Stogy likes this.
  4. Stogy
    Stogy
    Your in the land of Dry Tin so there's probably some real gennie rides for similar dollars...but steel 32's are pretty up there depending on the model.
    A lot of the rides on our cl***ified are listed by our membership maybe all, but you can see how long they've been here in the profiles...I excited for you...1940 Tudors are pretty sharp looking and many fall into your dollar range...Model A's are less pricey and can be pretty sharp looking rides and give every thrill a Deuce can...but I understand the allure of the Deuce...I've just been more open especially since hanging around here...
  5. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    It's on consignment, and while there is nothing special the engine is a new 383 blueprint, I got the dyno from BP and the exact engine. The guy put the new engine in and then blew out the trans, so it was rebuilt to handle the extra power.
    https://blueprintengines.com/produc...8318ctc1?_pos=1&_psq=BP38318CTC1&_ss=e&_v=1.0
    Stogy likes this.
  6. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    Yup, and I have $12k left for wheels, tires and the IRS.
    Stogy likes this.
  7. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    Yes, not looking to spend anymore, wife is already flipping out. I told her how much power there is and she is worried we will die lol...she did not want me to unload the Challenger....
    Stogy likes this.
  8. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    And a boxed frame should handle the 480 ish foot pounds...
    Stogy likes this.
  9. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    Receipt for the trans
    Stogy likes this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh my god, look at this picture? if you get a flat you will grind the bottom off the oil pan....Run away as fast as you can
  11. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    I have buddy that is a retired DPS Trooper that I messaged for help. ***uming the ***le transfered fine does not mean a trooper or another state would have issues if i ever had to sell.
  12. Stogy
    Stogy
    37-39 Chev Coupes have been popular nasty Hotrod material too...so just keep your eye out and by all means keep your budget and remember wheeling and dealing is part of purchasing so something at 25-26 may be in reach.
  13. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    So everything is too low, then the question is can it be raised without hitting the body. I don't mind having to modify things especially for the price. But again, I had not noticed that. And why I got here and asked questions. I knew there would be guys on here to stear me!!!
    Thank you...
    deadbeat and Stogy like this.
  14. DDDenny
    Welcome aboard.
    Just so you know, "kit car" is not part of our vocabulary here, a lot of people like to put labels on various genres' of cars, we just call them hot rods.
    2OLD2FAST likes this.
  15. MCjim
    MCjim
    from soCal
    If it is an ***igned VIN on a FL. ***le get a picture of that number/ tag on the vehicle. If so, you should be fine with that when transferring to AZ. I know in CA. it would not be a problem.
  16. F&J
    F&J
    I'm a bit unclear on what you meant. That is not a Ford number for a 1932. A 32 Ford didn't use a tag, it was stamped in several places on the frame.
    But Ford had certain number layouts in 32. A factory flathead-V8 serial number always starts with a 18, then a special star symbol, then more numbers, then ended with another star symbol. Ford never used letters on 1932.
    I don't recall what a factory 4 cylinder number starts with, but someone here will know, however, those never used letters either .
    Thank goodness you asked before sending 5k to this dealer. I can't imagine the nightmare of trying to get financially whole again if the car failed inspection and you had to get a lawyer to try to force them to refund, and who eats the transportation both ways if they did take it back. Life is too short and you have other bucket list cars, forget this one, please.
    Again, that is not an ***igned number from any of the 50 States. A State will ***ign a number but not something as silly as that. Not to say you couldn't get it registered in some State that doesn't have intelligent people doing the vin checks in person. If it went to a State that doesn't need a vin check if a current ***le is presented, then it could get by. But where are you down the road if you need to sell out of that same State.
  17. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    There is a 38 on Hemmings w a rebuildable 327 and 4 speed with the original straight axle so it could be raised to get the right height but it is in some rust belt state. Says it's solid in the add. And at $10k it would be a good project but I have a bad hip and back. So not in a position to get into a restoration. Which is why I sold my 71 Firebird. Had pulled the engine, 383 that I got some of the aluminum Dart 210 clone heads, roller rockers and a nice Schneider roller cam. .540 lift 230 ish and a 108 LSA. Got a 9 inch rebuilt w 3.50's and a Detroit true trac and mossier 31 spline axles....then got hurt in the middle of putting it back together.....
    oliver westlund and Stogy like this.
  18. Stogy
    Stogy
    Look for a running turnkey then...that is good coin your shelling out...its doable...
  19. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    I think one of the previous replies said it was a legit Ford VIN tag. Just on a car with nothing Ford on it....
    I have things better to do with my time than try to sue a dealer selling a car on consignment from a private party.
  20. deathrowdave
    deathrowdave
    from NKy
    I really there is lots of unforeseen consequences , making this purchase , just p*** on this one and look for another
    oliver westlund likes this.
  21. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    K I will dig into that more....
  22. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    This I thought was a running turnkey lol, for a good price other than all the red flags lol
    Stogy likes this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    I enlarged a few photo's and spotted the oil pan being below the scrub line like Jim pointed out, flat tire and you will damage the oil pan, the frame appears to be a Model A and shows some pitting when you enlarge the photo.
    It appears the body has been channeled over the frame, the body normally sits on top of the frame.
    I am a long time Deuce guy and knowing what I know if it were me I would keep looking, there are reasons why it's priced lower than most '32 roadsters. HRP
    Robdski and lurker mick like this.
  24. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    Copy that, I think I will investigate this further before I throw in the towell. Cause then wife gets involved and she found a Metropolitan that she thought would be better...
    https://www.facebook.com/share/14wGS4XLFu/
    I don't want to have anything to do with a metropolitan unless it's like the below.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    It is a terrible idea to buy a hot rod from half way across the country without seeing it in person. who ever built that did not know what they were doing.... you can tell by how low the engine is mounted...
    abe lugo, RMcCulley, teach'm and 4 others like this.
  26. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
  27. F&J
    F&J
    No, Ford never used a tag for serial number on a 32. Never happened.
    Some are also saying it could be an ***igned number and they can register it in their State, no it's not a legit ***igned number.
    Sometimes this place is a cluster f of misinformation . They might mean well, but you need to protect your own funds, rather than "picking an answer that makes you feel good" (about trusting the purchase.)
  28. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    Ok, now that's more of a red flag since you elaborated. I have seen that Australian guy on youtube that people bring in their beautiful new to them cl***ic that are just screwed all up underneath....
  29. Stogy
    Stogy
    deadbeat likes this.
  30. AZ 55 Riviera
    AZ 55 Riviera
    from Anthem, AZ
    With enough dissenting information my outlook changes rapidly. Unfortunately we are now there.
    Would have made a nice ride for Santa and Mrs Clause.
