Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Tim
    Tim
    from KCMO
    The painted spreader bar bolt heads are a nice touch.
    J.Ukrop, Stogy, Six Ball and 2 others like this.
  2. wheeltramp brian
    wheeltramp brian
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you! So the frame was a combo of old red oxide, bare metal and surface rust. I sanded down as much as I could, then applied two coats of Eastwood's Rust Encapsulator over the course of a weekend.
    Hahah thank you! I actually meant to paint those black but didn't get around to it.
    Thanks! We're getting there.
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    These things are all about the order of operations. Right now, I can't install the engine and transmission because I have to re-bush the pedals. IMG_7193.jpg
    Unfortunately, the Millworks bushing did not fit. I managed to find a complete replacement shaft from Third Gen, which is on its way.
    The larger issue, however, was the brake pedal. You'll see that it has worn through the bushing and into the body itself. I found an NOS bushing (also en route), and I may have a line on a replacement pedal. I can't wait to have this thing re-bushed, painted up, and back in the frame!
  5. 41 GMC K-18
    41 GMC K-18
    Perfection, cannot be rushed, however, it can be re-bushed!
  6. It does look a little worn but still round just off center, the bore in the pedal looks like it might have been done late on a Friday at the Ford plant. Would not be the first one I have seen like that.
  7. Tim
    Tim
    from KCMO
    Either way sounds like you have the problem
    Sorted. Keep it on the shelf who know when you’ll find a new use for it or an over sized bushing
  8. In university, I worked for a Union crew loading and unloading at The Aud (Auditorium) in Kitchener. We'd unload and do prep-setup for various bands/performers/sports, etc. Then reverse.
    When Bob Dylan performed, all non-Bob Dylan crew were locked (actually locked) in a storage room while he transitioned from the tour bus to the stage. His groupies were floating around back stage while he performed, and seemed like they'd been perpetually spaced out since the 70s.
    Six Ball, Stogy and Outback like this.
  9. Grumpy ole A
    Grumpy ole A
    Man your frame looks awesome, especially black and white.
  10. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Hey Joey, tracking says this unique mailing tube with the place-mats in it, will arrive at your place this coming Friday!
    So keep an eye open for it!
    Enjoy from Dennis.
    Ragged Edge, Outback, Stogy and 3 others like this.
  11. 41 GMC K-18
    41 GMC K-18
    Tracking says that the package was delivered to your mailbox today, 1/27/2025 at 5:44 PM,
    Enjoy!
    J.Ukrop likes this.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you, everyone! I’ve been away all week on a work trip, but I’ll be back in the garage tomorrow to make some more progress. Before I left, David and I had a great day in Petaluma working on the pedals.
    First, I removed the smoked bushings. I was very impressed with the sharpened chisel technique.
    R.I.P.
  13. Tim
    Tim
    from KCMO
    Hack saws are also surprisingly handy in the garage! Looking good Joey :)
    Stogy, Outback, 41 GMC K-18 and 2 others like this.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    With everything cleaned up, we installed the new bushings with this amazing old two-ton press.
    David’s shop is my favorite place around. Where else would you get a view like this while wrenching? This is Ted’s A-V8, which you’ll see on the road with my car in the coming years.
    Unfortunately, my clutch/brake pedal shaft was way too far gone. I thought there were reproductions available, but that’s not the case. These are one-year only and very hard to find. Without the pedals, there will be no engine and trans install. Simple as that.
    Well, looks like this project is on ice until I can find this hen’s tooth, right? On the drive home, I sifted through my options. Have it machined? Buy another set of pedals? I knew one thing—I’ve come too far to work with anything less than the best. I shot off a few texts. A minute or so later, a H.A.M.B.er (who has the best build thread on here) texted me back that he had one, and it’s NOS. More on that tomorrow.
  15. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    On Sunday, I made my way over to Yama’s to build a crate to ship his Panhead motor to the East Coast. Longtime readers know Yama—he’s helped me every step of the way on this car.
    Earlier in the month, he was in a horrible bicycle accident and was in the hospital for a week. He’s healing slowly, but is expected to make a full recovery. I’m helping with fundraising for his hospital bills—if you’d like to help get him back on his feet, shoot me a PM.
  16. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So that puts us up to speed. If all goes to plan, I’d like to have the pedals wrapped up this week and install the engine and trans next. I’m also finally getting the front tires mounted and balanced, so get ready for blue-walls on all four corners!
  17. Six Ball
    Six Ball
    from Nevada
    With a hacksaw, a chisel, and a big enough hammer you can remove anything. :eek:
    Weld it up and turn it down, almost free. :rolleyes:
    Stogy, 41 GMC K-18, warbird1 and 3 others like this.
  18. patsurf
    patsurf
    second that repair method--
  19. Tim
    Tim
    from KCMO
    I was thinking you could get an over sized bushing and reem to fit the worn down shaft. But that’s a good project for later since he’s found a replacement part
  20. Beanscoot
    Beanscoot
    During my apprenticeship I had a similar deal (a worn small engine crankshaft bearing surface). The company was nice enough turn it down smaller, nickel plate it and grind it back to standard.
    I wouldn't want to have to pay for such a repair though!
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It's been a busy week back in San Francisco, but I have been able to make a little bit of progress. Before I do, I have a handful of "thank you's" that are in order. I'll share them in the order in which they were received.
    First, I'd like to thank Justin (@kustomkat1950) for sending such a neat piece of original artwork all the way from Georgia. As you can see, it fits the roadster's timeframe very nicely. It's currently hanging next to the car.
    Next, we have a stellar package of original drawings/placemats from Dennis (@41 GMC K-18). Even the mailing tube is art!
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Remember when I said someone saved the day on the pedal ***embly? That someone was @NealinCA. While I was out of town last week, he sent me an NOS 1939 Ford pedal shaft. It's absolutely perfect. With David (@six5monster's) handiwork on the pedals and the new shaft, everything fits together exactly as it should with no slop.
    On this project, I've almost lost track of times that folks have come to my rescue. Without all of you, this car wouldn't be happening. Thank you. Thank you. Thank you.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Once the pedals are installed, I'll be dropping the engine and trans into position. The rest of February is looking super busy, so I'm thinking that'll be in March? In the meantime, I'm prepping as many of the smaller ***emblies as I can.
    After thinking about it for months, I finally replaced the front brake hose wrap with NOS wrap manufactured in Canada in the early-'60s. It certainly wasn't necessary, but I figured that this car is all about the details.
    This is the kind of thing I dream about. I first decided to have striped brake hoses after laying under the "Kookie Kar" at Brizio's back in the summer of 2019.
    Anyways, lots more to share but it's getting late. Additional updates hopefully happening soon.
  24. 41 GMC K-18
    41 GMC K-18
    Hey Joey.
    So cool that you now have the place-mats.
    I feel honored that my artwork is also in the company of the cool art piece from Justin @kustomkat1950 , Jackson Pollock would be proud of that piece!
    Lets see how skilled you are at deftly slicing that white butcher paper wrapper off of the mailing tube and saving it as art as well!
    I think its great that so many people have been following this build, and that they send you cool stuff from all over, to help you, and to participate!
    Below is one of the recent place-mats made from cut up Cheez-it boxes and various labels.
    The wacky fun never stops!
    Thanks from Dennis.
  25. BigJoeArt
    BigJoeArt
    first its the chrome washers, next thing you know its roll up windows and a heater ... #streetrodder
    Throw that in your backpack next time you come to my house. we can fix that.
    Cant wait to see the body mounted again.
    and in color!
    (for the record he HAS said what color it was going to be. but I'll let you guys go back through the thread for that. )
    Stogy, Ragged Edge, Six Ball and 6 others like this.
  26. Tim
    Tim
    from KCMO
    After riding shotgun in your roadster @BigJoeArt with the heater using the space were feet should go he’ll probably opt for heated seats lol
    Stogy, Six Ball and 41 GMC K-18 like this.
  27. RodStRace
    RodStRace
  28. BigJoeArt
    BigJoeArt
    I know heated seats are the hot thing (pun intended) but I need my feet to stay warm.
    Stogy, Six Ball, Outback and 3 others like this.
  29. RodStRace
    RodStRace
    Fully agree, especially when it's got a low seat bottom, forcing knees up! I'm considering ways to incorporate a tonneau to help trap any warmth and keep the gusts from swirling in the footwell.
    Grew up in the San Francisco bay area and know how useful they are there.
    https://www.jalopyjournal.com/forum/threads/tonneau-covers-for-roadsters.1220758/
    Plus gaining the aesthetic of looking like a Roth monster poking out! :D
  30. denis4x4
    denis4x4
    from Colorado
    My Zipper is in the thread RodStRace posted above. Tonneau covers work! Used them on the Zipper, MG Midget and an MGB. Heat seaters are great…used them in Jeeps with no doors.
    Stogy, J.Ukrop, OFT and 4 others like this.
