Technical Steering box options.
Discussion in 'Traditional Hot Rods' started by Bob Bagley, Jan 21, 2025.
  1. Bob Bagley
    Bob Bagley
    I was hoping to use block huggers headers on my 40 Foad coupe with a SBC on a stock frame but they don't clear the stock steering box, are there any options that will give me more clearance? Thanks
  2. woodiewagon46
    woodiewagon46
    from New York
    I would guess that a 1940 Ford is fairly similar to my 1946 Ford, so what I used was a header made by Sanderson Headers Model # CC-4. The drivers side exits forward of the steering box and you will need to fabricate your exhaust to go around the steering box. I use a Saginaw 605 box so it took a considerable amount of TIG welding to snake around the box. Sanderson advertises it for '35 to '40 Fords.
    lothiandon1940 and dana barlow like this.
  3. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Not headers but on my 40 with stock steering and later with a 525 box we used a 69-70 Chevy pickup right hand manifold that points back but when put on the left side it points forward and allows the pipe to be routed forward, down and around the box with no problems.
  4. Bob Bagley
    Bob Bagley
    Thanks, what is a 605 and 525 box? Is that used for better steering ratio?
  5. krylon32
    krylon32
    from Nebraska
    605 is a late GM power box and the 525 is a late GM manual box. 605 is a little large for s 40 IMO.
    lothiandon1940 likes this.
  6. treb11
    treb11
    If you change steering boxes, the replacement bracket (L) tucks the box further out as oppused to the adapter(R)
  7. Weedburner 40
    Weedburner 40
    Block hugger headers don't work well on 40's. We used to make an exhaust system for 35-40 Fords with SBC and we did have one for the block huggers but, as Gary stated, the GM pickup passenger side manifold works quite well, that's what is on my avatar.
  8. wheeltramp brian
    wheeltramp brian
    A stock 265 Chevy exhaust manifold will clear perfectly.
