49-51 Mercury Disc Brake question?
Discussion in 'The Hokey Ass Message Board' started by sdimpala64, Jun 27, 2013.
  1. sdimpala64
    sdimpala64
    from SD CA
    Does anybody sell a front disc brake kit that can be used with fatman's
    dropped uprights? I contacted fatman and they told me to contact Master Power Brakes. I emailed MPB and was informed their technician that made that kit is no longer there, so they can not supply the kit. Thanks for the help.
  2. Finnrodder
    Finnrodder
    from Finland
    Maybe Extreme kustoms have them?
    They are specialized to 49-51' Merc and Ford suspension stuff.I bought a chrome-moly tie rod kit from them for my shoebox a while ago.
  3. slddnmatt
    slddnmatt
  4. sdimpala64
    sdimpala64
    from SD CA
    slddnmatt,
    This kit works with the fatman uprights....I emailed them and never got a response.
    But I'll take your word for it. Thanks again for the help.
  5. sdimpala64
    sdimpala64
    from SD CA
    slddnmatt,
    Does this kit push the wheels out?
  6. slddnmatt
    slddnmatt
    i forget how much, think its like 1/4" per side if i remember.. its the thickness of the inner bearing adapter..
  7. sdimpala64
    sdimpala64
    from SD CA
  8. EXK
    EXK
    from SO CAL
    Yepp i have them. 95% of the time they will bolt onto a Fatman upwright and if you have a set of my older 2.5" upwright's they will bolt on but not the older Jamco's but will work with there new ones as they are made by fatmans. Will increase track width 3/8" total or 3/16" per side. I have the kit in stock for $460.00 plus shipping 5.5 x 5 bp 10.75" rotor will fit with most 15" steel wheels
    Gb & Thank's, The Erickson's / Extreme Kustoms 951 678-3520
  9. Surfcityrocker
    Surfcityrocker
    from Austria
    Don't want to hijack this thread, but I have this setup on my 50 Mercury (was installed when I bought the car) and I have no idea what it is.
    Bolt pattern is different than original wheel (5 x 4 1/2 vs. 5 x 5 1/2).
    Any ideas?
  10. Finnrodder
    Finnrodder
    from Finland
    Do you have that same kit for 49-51' Fords?
    I need a disc brake kit that will work with Fatman's drop uprights..
  11. EXK
    EXK
    from SO CAL
    Yea we have them $450.00 plus shipping. On older Fatman uprights you will have to rotate the caliper by redrilling the mounting plate.
  12. EXK
    EXK
    from SO CAL
    Those are old MPB that required the spindle to be machined
  13. Surfcityrocker
    Surfcityrocker
    from Austria
    Thanks, great info! Good to know where this setup comes from.
  14. Finnrodder
    Finnrodder
    from Finland
    Email sent..
  15. 49dreamer
    49dreamer
    I'm also interested in disc brakes up front for my 1950 Mercury. Here is a picture of my current front set-up. My car is dropped in the front, not sure how (cut springs?). I am assuming I have stock A-arms and spindle. Can anyone please verify?
    If so, is all that I would need is the disc brake set up that EXK sells? I realize I would still need the updated master cylinder because I'm still running the original, but I'm not sure about the spindle. I would like to keep my current stance, so I just want to make sure I understand what I would need to change out. Thanks!!
  16. EXK
    EXK
    from SO CAL
    Yes our disc brake kit will bolt on and comes with everything you should need.
    Your merc has stock A-arms, uprights & spindles. Your springs appear to be cut and i am guessing about 2 full coils and your lower A-arm looks like they are angled slightly up and that will useally result in poor handling and some bump steer. If you are not happy how your merc handle and you want some suggestions on how to improve it let me know.
    Rick Erickson / Extreme Kustoms 951 678-3520
  17. t2dfyre
    t2dfyre
    Thank you all for this great information (11yrs later):cool:. I have a stock drum brake system and suspension on my 1950 Mercury Coupe. Looking to upgrade to discs. I appreciate all this information on the thread. Thank you kindly.
  18. t2dfyre
    t2dfyre
    Good morning everyone. I realize this thread is from decades ago however I have noticed there is relevant information here as to the route I’m trying to accomplish with a disc conversion kit on my 1950 Mercury and I’m hoping someone has been down this route with a POL kit or similar frame mount dual MC conversion for there Mercury. I currently have a POL kit and wondering where this bracket is supposed to go. I’m doing a frame dual MC install and would like to stay in the area of the OG MC. I prefer to not use the firewall after considering for sometime. Can anyone shed some light as to where this bracket goes? I can’t seem to mock it up in the area of the OG spot and looking for some assistance on where I may be missing something. At the moment I have attempted to contact POL and have not received a response as of yet. Thank you kindly in advance for any assistance you may have. Stay safe, blessed, and be well.
    https://www.performanceonline.com/1949-51-Mercury-MERC-Car-Complete-Disc-Brake-Conversion-Kit/
  19. 2devilles
    2devilles
    My '49 has a dual master cylinder kit on the frame, although I don't believe it's the POL kit, or else it's an older version (put on before I got the car). Here's a couple pics of it mounted, might give you an idea of where yours is supposed to go. I'll be swapping to the POL discs this spring with a proportioning valve (its -4 here as I type this and my garage isn't heated). Keep me posted how your disc swap goes, I've done them on many other non-Merc cars and it's been straight forward.
    t2dfyre likes this.
  20. t2dfyre
    t2dfyre
    @2devilles Thank you kindly. Yes, your photos have already given me some insight on possibly where it needs to be lined up to work. Wow, that’s chilly…we are sitting at about 67, still cold so probably wouldn’t survive where you are at :). I appreciate you getting out there to grab this pics. Thank you very much and I’ll surely keep you posted as I move through things. Stay safe out there.
    2devilles likes this.
  21. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    The bracket that you show= mounts between the frame, and catches the X. Also, the 4 holes are for a booster if desired.......Drilling to mount is required...... I just made my own from a post long ago, that used the factory holes for the MC. I have one of the first POL kits.......Pushing 20 years now. Stock uprights, and factory steering. Still solid to this day..........
    2devilles and t2dfyre like this.
  22. t2dfyre
    t2dfyre
    IMG_7864.jpeg Awesome @INVISIBLEKID. I appreciate it. Funny you say that…just mocked it up and welp I have an issue…dual exhaust, so I’ll be looking at reworking this driver side exhaust pipe. After @2devilles replied, I went back out underneath to see what’s going on here and it seems appropriate here (pic attached). Thanks again for the pics, grateful for the information and assurance on a solid brake kit. Stay safe and blessed.
    INVISIBLEKID and 2devilles like this.
  23. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Cool! Duals here also...... The factory had a hole in the X for the single pipe, which you are well aware of! Mine= Just blew a hole in the opposing side that matches, and you're good to go. Good luck with things, and if you need any tips, shoot me a PM.;)
    t2dfyre likes this.
  24. t2dfyre
    t2dfyre
    Sweet…thank you @INVISIBLEKID…definitely will. I appreciate the help and will keep all posted.
  25. t2dfyre
    t2dfyre
    Good morning Sirs @2devilles @INVISIBLEKID
    I apologize for the delay in my POL disc/drum conversion update. While at it, I started overhauling the rear drum brakes as well, why not?! I have been taking my time through this process (first time) and have definitely ran into a few challenges and the need for modifications and what not, however it is coming along. I am currently at the point to bleed the system (again). I will surely keep all updated once I can get through a couple more items such as bleed, hand brake equalizer (adjusting bolt broke), etc. I have a ton of pics and will get a link up with them as well. I appreciate your patience and grateful for such knowledgeable assistance. Stay safe, blessed, and be well.
  26. t2dfyre
    t2dfyre
    Good morning. This is a Performance Online (POL) kit. POL is not very responsive if assistance is required with their own kit as some things should be included, but are not. This is what I came up with. I hope this can assist anyone looking to swap from drums to discs. You may run into some other ideas, challenges, fixes, and now how’s, however this was my first and digging into such a project and it seems to have worked for me with a few additional parts, info/instruction searches, and help from some of you. Stops as required/necessary and at this time no leaks observed.
    https://share.icloud.com/photos/044y1SYCp_S8_GksYYvdWXpyQ
    ***I will be replacing the parking brake as it seems to be binding up near the handle and not going all the way in to release. This was after I overhauled the rear drums with all new hardware/shoes while doing the front disc conversion as well. Stay safe, blessed, and be well :cool:.
    bobss396 and INVISIBLEKID like this.
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Glad you got it handled...... I did have one issue, and that was a casting flaw in the stock spindle,which easily remedied. The caliper bracket fit flush with the kit/spacers....... Everything else went smoothly...... I did do all new brake lines=hard/rubber also instead of trying to make the factory one's work, I mean, you're changing everything on a 75 now year old car....... Hurdle out of the way! Continue on to the next!;)
    t2dfyre likes this.
  28. t2dfyre
    t2dfyre
    Wow, you did your fast. Must be the experience . I purchased my kit back in June 2024 and started at it in late December. Barely finished up this month for all sorts of reasons :). I appreciate all the assistance you provided at the start.
    You are definitely right, I did the same with all new lines and what not. I’m at the parking brake now. Noticed the binding up issue when doing a test drive. It would barely slow the car down but not keep it from stopped (test on driveway). It kept slowly rolling then when attempting to move forward it felt as if they were still engaged, could barely move, but moved. When trying to release by pushing handle in, it binds up causing visible cable showing from handle shaft. I got up underneath there and sure enough the cables were still tight so thus far I have loosed the cables near the rod/nut and haven’t drove it since. I have been trying to gain alittle insight and knowledge first before tearing into it if need be.
