Technical Questions about Rochester 2 jets for a 3x2 setup
Discussion in 'Traditional Hot Rods' started by Mudtrux, Jan 20, 2025.
  1. Mudtrux
    Mudtrux
    from Central Mn
    I have 8 total 55-58 carburetors all with small bases, two without idle jets.
    I'm looking for tech on these like do they all use powervalves?
    I believe I have enough parts to build them. Where can I get mechanical progressive linkage?
    I see speedway sells a complete base and linkage kit but those are for 60's- 70's carbs I believe. I have an edelbrock intake also for the small bases.
    These are going on a 30 ford coupe.
    I'm trying to run and maintain this car on a budget so cost is always a factor
    Thanks, Ken
  2. oldsmobum
    oldsmobum
    from SoCal
    Charlie price at vintagespeed.com sells everything that you would need. I have never had any issues with him, neither 10 years ago nor 6 months ago when I dealt with him last… but I know some other users have.
    bobkatrods and Mudtrux like this.
  3. Taboo56Chevy
    Taboo56Chevy
    well the 2 factory 3x2 set ups that come to mind for linkage/fuel line and other parts would be a 57 J2 Olds and 58 Chevy 348/315hp ran those earlier style 2 barrel carbs in a tri power setup. The swap to the side outlet 2GC was in 1959. Usually the aftermarket linkage setups have you swap the main shaft for a longer unit to put the progressive stuff on the p***enger side.
    Mudtrux likes this.
  4. Fordors
    Fordors
    Post photos of the two carbs that do not have the idle mixture screws so we can see what you have, they sure sound like factory tri-power carbs.
    Mudtrux likes this.
  5. BoxCar Tom
    BoxCar Tom
    factory fittings and hardware. Since we'er talking 3x2 set up whats the best jet size for the center carb 56? and the two end carbs 47s? Bone stock 67 283 thanks.
    Mudtrux likes this.
  6. RICH B
    RICH B
    Here's a 3x2 progressive linkage made out of stock linkage parts. The pedal rod hooks to the ball stud on the center carb.
    100_1361_640x426.jpg 100_1362_640x426.jpg 100_1363_640x426.jpg 100_1364_640x426.jpg
  7. Mudtrux
    Mudtrux
    from Central Mn
    These are the three I got with the olds intake. I'll post the others also. 58 olds 2.jpg 58 olds 3.jpg 58 olds1.jpg swaps1.2.jpg swaps2.jpg tonys1.2.jpg Tonys1.jpg Tonys2.jpg swaps1.2.jpg swaps2.jpg tonys1.2.jpg
  8. Mudtrux
    Mudtrux
    from Central Mn
    Thank you!
  9. Outer carbs need no idle circuits and the ****erflies need to seal when closed. You can make your own progressive linkage with some bar stock. Also make sure you have the proper amount of fuel pressure so it doesn't overflow the outer carbs when not it use.
    Mudtrux and Kevin Ardinger like this.
  10. WhyW8
    WhyW8
    from Sun City
    Mudtrux likes this.
  11. 1930 turbo
    1930 turbo
    from pa.
    I like your 30 coupe. My first hot rod back in the 60s was a 30 coupe with a 327 and tri-power. It ran very good with .057jets in the center carb and .076 jets in the two end carbs.
    Mudtrux likes this.
  12. Tickety Boo
    Tickety Boo
    from Wisconsin
    I used the Speedway base kit with good results, came with thicker fitted throttle blades, front and rear carbs need to have tight fitting "closed" blades, or they will be a vacuum leak.
    If your J-2 carbs are rebuildable they could save you the cost of the whole kit, they got the right bases.;)
    Pretty sure progressive linkage kits with the replacement shafts are available.
    Norb
    SPEC and Mudtrux like this.
  13. Mudtrux
    Mudtrux
    from Central Mn
  14. Blue Moon Garage
    Blue Moon Garage
    IMG_0144.JPG I just bought a set of those scoops. What are you using for filters, any screens?
    Mudtrux likes this.
  15. WhyW8
    WhyW8
    from Sun City
    Thanks
    I ran original bases for a while but had problems with them not closing all the way. Purchased new bases from Ron and that solved that problem.
    The old school Frog Scoops came with my tri-power set up when i bought it used, the scoops have SS screens surrounded by a rubber seal.
    I ordered some filter material and cut out circle shapes and wedged them in between the rubber seal and the SS screen (wedged around perimeter) NOTE: the filter material is wedged in on the top side of the scoops so it cannot get ****ed into the carb.
    I use K&N filter oil and clean and re-oil the filter material as needed - not as good as a premium quality air filter but better than no filter at all.
    SPEC likes this.
