Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. 327Eric
    327Eric
    They are 14 x 10s unfortunately, and it was a 59 Fords,not much market for either
  2. abe lugo
    abe lugo
    Windlace in the 57 wagon. Will get some finessing and clips soon.
  3. Too cold to work in the garage, but the dang daily driver's fuel pump went out over Christmas, parked outside in the trees along the driveway, so I dropped the tank and commenced to replace the pump. Unfortunately the fuel line coupling won't come apart, regardless of how I use the de-coupler tool. I'll have to cut the two lines, remove the tank, pull and replace the pump, then put it all back under the vehicle using fuel line hose and clamps. But that's going to have to wait a few weeks until the weather warms. Tonight it's supposed to get down to -5 degrees and we've got another week or so of really cold weather. Meanwhile, my '29 AA still needs another coat of paint on the body and fenders, then a round of wet or dry 1000 followed by light buffing to get the finish I want. That will then allow me to attach the body to the frame, including the fenders and splash aprons. Once that's done, I can wire it, start up and run in the engine and transmission. That's the goal for this spring. GET IT RUNNING!
  4. pila38
    pila38
    Long block accomplished
    chevy57dude, Okie Pete, enloe and 9 others like this.
  5. nochop
    nochop
    from norcal
  6. choptop40
    choptop40
    Firewall getting ready to weld up heater , wiring , etc holes...templates all made up..8 total..not sure if notching the distributor location , but most likely for a little more clearance.. Screenshot 2025-01-21 4.19.53 PM.png
    chevy57dude, Okie Pete, enloe and 7 others like this.
  7. saltflats
    saltflats
    from Missouri
    Ordered parts from speedway and spread some salt on the glacier driveway.
  8. fastcar1953
    fastcar1953
    I will be glad when the ice melts.
  9. saltflats
    saltflats
    from Missouri
    All part of living in the USA in certain parts of it.
  10. If I could give you 10 likes for your comment, I would! :D
    Sharpone, chevy57dude, enloe and 3 others like this.
  11. enloe
    enloe
    from east , tn.
    porkshop, Stock Racer, hrm2k and 21 others like this.
  12. DDDenny
  13. lumpy 63
    lumpy 63
    20250122_134319.jpg Came down with the crud Sunday:confused: finally felt ok enough to make the brake lines for the Tempest cradle. Now I can bolt it back in the car and haul it to the shop to start setting up the ladder bar rear suspension.
    porkshop, pila38, Sharpone and 8 others like this.
  14. enloe
    enloe
    from east , tn.
    World products heads with port work
    11 to 1 compression
    Hydraulic Roller cam
    It should be nice
    porkshop, pila38, loudbang and 8 others like this.
  15. DDDenny
    327?
    porkshop and Sharpone like this.
  16. Very nice! Now, get it installed! We only have 5 months until Bowling Green!!
  17. Hey Buddy! I’m glad you’re feeling better!!!
  18. Extra ground on this 235 dizzy?
    made a simple stand that bolted to the bell. Went to do similar on the front and found out there is no front provision for an engine mount. Looks like someone put the wrong plate on it.
    No side mounts on the block.
    Okie Pete, porkshop, Sharpone and 8 others like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
  20. saltflats
    saltflats
    from Missouri
  21. enloe
    enloe
    from east , tn.
    yes
    It was a 1965 365hp engine
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I have only been procrastinating about this since 2009, this is the rear body panel that I cut off the Car Craft Dream rod when I restored it. The rear of the car was completely changed when they modified it and called it the Tiger shark. I built a wall mount bracket, made the tail light work and built a couple of acrylic shelves to display hot wheels and models of the car. I finally painted it yesterday.
    IMG_2703.jpeg IMG_2702.jpeg IMG_2701.jpeg IMG_2570.jpeg IMG_2524.jpeg IMG_2522.jpeg
  23. lumpy 63
    lumpy 63
    you didn't get any overspray on my 40 did you?
  24. Lumpy's "brake" dancing? Yeah, that's it.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    hope not. I put a 3M plastic car cover sheet on it and taped it to the floor. I will take it off tomorrow and see. Be a shame to mess it up. It was last painted in 1965. I thank my lucky stars that it was done with Dulux enamel and not lacquer. Looks pretty good for 60 year old paint
    Okie Pete, porkshop, rod1 and 9 others like this.
  26. 427 sleeper
    427 sleeper
    LOL! The reason the Dulux still looks good is because it hasn't completely dried yet!!! :D:D:D
  27. Added a coil and a jumper wire.
    fired up on the first hit. But shuts off.
    Running on ether in a can
    Built up almost 30psi just on the starter.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    un covered the 40 and zero overspray. Also blacked out the back of my Tiger shark wall hanger project IMG_2714.jpeg IMG_2715.jpeg
    Okie Pete, porkshop, Oneball and 12 others like this.
  29. snoc653
    snoc653
    from Iowa
    Is that a 6 volt coil? I'm sure you had this all covered but, other than I don't see the positive wire nor the ballast resister powering it which it will need and then some being ran on 12 volts, I don't see anything wrong with it.
  30. 12 volt coil.
    No resistor ……..yet.
    Just wanted to hear it hit
    Positive jumper disconnected in the pic
