Hot Rods Cast Iron Heads
Discussion in 'The Hokey Ass Message Board' started by MUNCIE, Jan 6, 2025.
  1. mad mikey
    mad mikey
    Hum, that's funny, most drag and drive cars have cheese heads and blocks for that matter. They are put through grueling 1000 mile + drives on the street and running down the track for days.
  2. Cast iron easy - just saw a pair of 'freshly taken off' 462's for $100 on local listing.. Pics looked clean. I'd check ' em & bolt 'em on - no biggie - if they need machine work, etc, then on to the next $100 pair
    MUNCIE and Acres like this.
  3. Acres
    Acres
    from Sweden
    And they drive a stock sbc around 300hp? My point is when running little to moderate hp there is no point going for aluheads.
    A stock 350 and a boosted race engine are two different worlds.
    If you read my whole comment i mentioned that race and hunting weight = aluminium.
    And I got no problem confess i dislike aluminium, thats why I stick with old stuff, I like cast iron.
    I actually traded my Chevy aluheads for a pair of original cast iron
  4. Uncle Lee
    Uncle Lee
    Looks to me, the only engine that has visual characteristics that would be missing on aftermarket heads is the sbc, and there’s an option for that.
  5. Uncle Lee
    Uncle Lee
    Cost of reconditioning the early heads has been mentioned.
    Has anyone seen the “rebuilder’s” valves?
    $87.50 for a complete set, and they have oversized stems and heads. Run a reamer through the guides and the heads are just enough larger to set them back on top. So, if you’re not chasing horse power, this should be a cost effective option!
    MUNCIE likes this.
  6. Uncle Lee
    Uncle Lee
    Another thing that’s been mentioned, exhaust seats.
    Most of us don’t need hardened seats, and cutting for them can ruin some early heads.
  7. Ericnova72
    Ericnova72
    from Michigan
    General rule of thumb is .006" tighter cold for first start-up with aluminum heads.
    then get it running and up to temp, shut down and pull a valvecover and check a cylinder pair HOT and record the number.
    Once you have your initial cold setting and the actual hot measurement, you can determine what the actual growth is and that becomes your actual engines new cold setting.
    The Speedway Motors 461 Alum Hump head is made by the same company as Flo-Tek Cylinder Heads.
    MUNCIE likes this.
  8. Ericnova72
    Ericnova72
    from Michigan
  9. 327Eric
    327Eric
    Thank you
    Deuces and GlassThamesDoug like this.
  10. MUNCIE
    MUNCIE
    from Houston
    :eek::eek:
    GlassThamesDoug likes this.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    Other than the fact that most are cracked & the rest will be ..
  12. MCjim
    MCjim
    from soCal
    Yeah, I saw that movie...ruined a set of the "turbo" 292 castings, seeping water through the seats on four chambers.
    I now have aluminum heads.
    Tickety Boo and GlassThamesDoug like this.
  13. GlassThamesDoug
    GlassThamesDoug
    Went to a well known cyl head shop. Just to see what it costs, went thru pain one time, had em flowed, but when done - pure stupid. So, just buy new... new heads are way past the antiques in so many ways. $700 - new SS valves one piece, new springs. Compe***ion valve job. $1000 - port and flow, improve chambers, cc to 68cc.
    This was 13yr ago. I wouldn't even ask what it cost today.
    I think I was trying to duplicate one of my Dad's old race motors, some silly idea.
  14. GlassThamesDoug
    GlassThamesDoug
    FYI Last Summer, I priced a cyl head trick port work for a set of $100 cyl heads. This is to work pure stock heads, no porting, for my jr stocker, NHRA legal. $2500 was quote.
    mad mikey likes this.
  15. Tickety Boo
    Tickety Boo
    from Wisconsin
    Built a mostly swap meet parts sbc 434 engine for my O.T. 3200 lb. drag car in 2005, used the top-proline New Zealand 220 cast iron heads because they fit my budget and were advertised as flowing 272 cfm. @ .600 lift.
    Raced these heads until 2019 with a best E.T. of 10.81.
    In-between racing at the Meltdown drags 2018 visiting the Compe***on Products trailer and looking at their new stuff, I noticed a new brand of heads, "Power Products", aluminum 220s on the table with 2.080 valves and were advertised to flow 300+ cfm.
    Purchased them for less than $1500.00, that included the extra cost of a fluff job to get 308 cfm.
    I've been happy with them so far, with only changing to the new heads got a 00.48 quicker E.T. of 10.33
    I also painted them fast orange ;) Engines been waiting for its new Hamb friendly home about 3 years now, hoping to have it running this summer.
    Deuces, Chavezk21, MUNCIE and 3 others like this.
  16. DDDenny
    "My drinking team has a race problem".
    I'd say they are dyslexic too!:D
  17. GlassThamesDoug
    GlassThamesDoug
    Very Nice
    Deuces, mad mikey and Tickety Boo like this.
  18. MUNCIE
    MUNCIE
    from Houston
    :D
  19. MUNCIE
    MUNCIE
    from Houston
    Has anyone used this style of rocker on a SBF? I think they provide a little more clearance with the shorter valve covers...https://www.speedwaymotors.com/Smal...bwk2CvNex6LBFBH_HgzPDi0Tk2O6Z1dxoCaNUQAvD_BwE
    If so any suggestions on a good brand? Is there anything I should keep in mind when ordering like length of the valve stem? Went to the machine shop today, they did some minor bowl work and relief work where the valve sits to run 1.84/1.60 - milled a tad as well $700 out the door.
  20. 2OLD2FAST
    2OLD2FAST
    from illinois
    Roller tip rocker are a waste of good money , nobody " needs" them , they won't do anything for you except rattle , stock stamped rockers are more than sufficient
    427 sleeper, Fogger and MUNCIE like this.
  21. 1biggun
    1biggun
    I some what disagree .
    Unless you're running a cam that needs heavy valve springs , want to change the rocker ratio, running heads that require a off set rocker , want to run a bigger rocker arms stud say from 3/8 " to 7/16" , need more lift than the standard slot in a stamped rocker can allow , running larger retainers than a stock arm allows.
    I have broke three rockers on the Corvette over the years running a fairly mild cams and not really revving it hard . I broke stock rockers in the street stock a bunch also running a cam under .500 Lift . that with a SBC that's got about the most reliable valve train around for stamped rockers . Would a set of after market rollers have lasted 200,000 miles ? likely not .
    In my boats ( Jet and Vdrive with the BBC ) a stock rocker is not even a option running under load near full throttle all the time high Rpm and over reving when ever the prop or impller s out of the water . .
    Stock engines really don't gain any thing but start getting into high RPM and high lift heavy springs and they defiantly have there place.
    I know of two DZ 302 chevy blocks destroyed by valve train failure in z28's .
    one the rocker broke and got off the valve and hit the retainer and the keeper came out and that was it .
    Never heard any rattle on a hyd cam engine running a roller rocker that was stock or aftermarket . millions of newer cars running roller valve trains on a rocker or cam actuator.
    Deuces and MUNCIE like this.
  22. GlassThamesDoug
    GlassThamesDoug
    FYI: a pair of those 327 041X Super Stk Elim heads recently posted $3500 used, with the special porting, chamber work. Wow.....
    Alum heads now legal, expect these to be showing up. For vintage SS racers.
    Deuces and Tickety Boo like this.
  23. MUNCIE
    MUNCIE
    from Houston
    Guess I will stay with the stock type rocker then, could always use that extra money on something else. Need to get a higher stall and I will be upgrading my gears.
  24. MUNCIE
    MUNCIE
    from Houston
    Got some parts in yesterday for the heads...
  25. ekimneirbo
    ekimneirbo
    from Brooks Ky
    What it comes down to is the cost to refurbish an older and somewhat inferior (to those available today) flow vs an off the shelf new and lighter aluminum set. If you aren't doing your own work, labor costs will eat you up. I think @Mr48chev provided you with an excellent choice. Bang for the buck so to speak. :) Paint em red like @squirrel showed and enjoy them.
    I guess they have Ford heads too.............;)
  26. 1971BB427
    1971BB427
    from Oregon
    I set lash just as I would with cast iron heads and never had any issues. With the heads properly torqued I see no reason the lash cold or hot would change anymore than it would with cast iron?
  27. 1971BB427
    1971BB427
    from Oregon
    There are millions of engines driving daily with aluminum heads and no issues. Weight is only a small percentage of why aluminum heads are used for street or strip, and comparing aluminum to cheese is silly. If aluminum was so bad the manufacturers wouldn't have all gone to aluminum, and aluminum wheels wouldn't even have ever been used.
  28. 1971BB427
    1971BB427
    from Oregon
    Both of my SBC engines use roller tip stamped steel Crower rockers. Since both see thousands of street miles each year I didn't see fit to go to full roller needle bearing rockers, and the Crower roller tips have held up great. 14,000+ miles on my older build, and about 6,000 on my newer build. I like the tips being roller and not wearing rocker tips, or valve stems with non roller tip rockers.
  29. MUNCIE
    MUNCIE
    from Houston
    :eek::cool: Sounds like Crower makes a good quality roller tip....:)
  30. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I think in the long run that a roller type rocker pays for itself because it puts less sideways pressure on the valve stem and helps the guides to have a longer life.
    joel and MUNCIE like this.
