Technical 1952 Chevy FastBack Rear Suspension Idea's
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 23, 2025.
  1. brigrat
    brigrat
    from Wa.St.
    Removed the torque tube, rear end & all hangers, looking for a simple way to install a trifive rear end. Posting pic's and suppliers is a plus. Thanks!
  2. brigrat
    brigrat
    from Wa.St.
    Not going big wheels and tires & your image didn't show up!
  3. ALLDONE
    ALLDONE
    just put it on the stock leafs....can't remember, but you might have to move the spring pads...
  4. brigrat
    brigrat
    from Wa.St.
    ALL '52 rear suspension related parts have been removed AND s****ped, starting with a clean slate...............
  5. oldolds
    oldolds
    The stock springs work fine for most applications. Not high horsepower engines. They used to make spring perches that had holes in them to move the rear forward to center it in the wheel wells. Lowering blocks to drop it down a bit.
    That is the simple way.
    49ratfink and Roothawg like this.
  6. Roothawg
    Roothawg
    55-64 Rear ends are a bolt in on top of the original leaves. You can have new leaves built if you need them. Mine were broken. The later years went to coils, but the housings are the same, just cut off the coil spring pads.
    anthony myrick likes this.
  7. brigrat
    brigrat
    from Wa.St.
    Again, It's wiped clean of any rear suspension parts, no springs, no shocks, no brackets, no hangers, NO NOTHING! I have a complete '57 Chevy rear end that will be installed. Just looking for info, pic's, supplier's that cater to this year & model. Not doing big weeny's out back and Triangular 4 bar & coils is 4th-5th choice. Was hoping someone made hangers/mounts that would bolt to bottom of frame or side of frame.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    man, too bad you cleaned everything off. tri five rear is a bolt in on the stock leaf springs with only a 1.5' movement of the ctr bolt alignment hole required
  9. guthriesmith
    guthriesmith
    I think I would put the spring mounts back on the frame and put some Posies springs on it and bolt the rearend in. Surely you could find the mounts off another salvage car. I don’t have any pics, but that’s basically what I did to my 52 I had several years ago.
  10. 49ratfink
    49ratfink
  11. oldolds
    oldolds
    This^^^^^^
    If you can't find those parts, get some s-10 springs and fab some brackets and hangers.
    it appears somebody made an easy project hard for you.
  12. If it’s all gone then something like this.
    or locate some donor parts
    Truckdoctor Andy likes this.
  13. 52HardTop
    52HardTop
    I triple the Posies springs.. If you could reinstall the original shackle mounts, Posies makes springs that would bolt right up with the correct centering of the tires.
  14. oldolds
    oldolds
    Where is that from?
  15. brigrat
    brigrat
    from Wa.St.
    PO, 20 years ago, not me!
  16. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
  17. ALLDONE
    ALLDONE
    to each his own,,,... but i've had a fat stack of 49-54 chevys... never once did I wish it didn't have Parrell leaf springs....in fact wish my 58 didn't have the X frame and coils.... bet the P O was gonna air bag it...thats what I wanna do to mine...
  18. Roothawg
    Roothawg
    Man, I dunno what to tell you. If you’re looking for a 4 bar coil over system, then you might as well go with an 8.8 since you will have to weld it all up anyway.
    The 55-62 rear is pretty weak, but does ok for a daily if you aren’t beating on it. Plus the axle bearings were about $100 ea, the last time I bought them.
