Hot Rods 4 Post Failure
Discussion in 'The Hokey Ass Message Board' started by dart4forte, Jan 17, 2025.
  1. hotrodlane
    hotrodlane
    Just one! but for me that was enough, My parents did not raise a slow learner. Best of luck to you
    oldsmobum, 2OLD2FAST and SS327 like this.
  2. ratster
    ratster
    I have a four post lift, I did not have it bolted to the floor and raised my car almost all the way up. scared the heck out of me as it started to lean. my floor is very level. I now have it bolted down and have no issues with it. 458979677_1559106698319619_2618932775232179093_n.jpg
    Tow Truck Tom, alanp561 and skooch like this.
  3. seb fontana
    seb fontana
    from ct
    See post #48. My lift looks to be the same as yours, at least from picture. No issues.
  4. BJR
    BJR
    Why would it lean if the floor was level? The cables were not adjusted correctly is the only reason I can come up with. Bolting it to the floor only masked the issue.
  5. alanp561
    alanp561
    First, I want you to know that I don't mean to insult you by what I'm going to say. I've been in your garage. It's very well built, and your floor is just about perfect, but I'll bet that there is somewhere on that floor there is a low spot that water will pool, or it will run off. Either way, it won't be perfectly level.
    Seriously? Have you ever seen a concrete pour that was completely level? The answer is no. A sixteenth low here, an eighth high there and the floor is three sixteenths of an inch out of level. If you truly want a structure level, you start at the bottom and level the bases of all the columns. Then, and only then, do you worry about adjustments to whatever method of raising or lowering the lift that the manufacturer provides. Go back to my post #52 and study it. That is how steel structure is leveled and plumbed, and it's the same principle whether you're putting up a multi-story office building or a two post or four post lift.
  6. ratster
    ratster
    i should have said the lift was wobble until it was bolted down.
    all I know is that it works great now that it is bolted down,
    my other lift was the same way until it was bolted down.
    Tow Truck Tom and alanp561 like this.
  7. Budget36
    Budget36
    So, does anyone have information on how the failure occurred?
    49ratfink and ratster like this.
  8. ALLDONE
    ALLDONE
    the pads will walk....... like in trying to pry a stuck bolt loose... also using screw jacks to lift the weight of the car.. mine doesnt have bolts.. and I have the caser set.... but... guess what i'm gonna do next... i can see where the pads have moved....that means the locks are also getting pulled away from the posts...
    alanp561 likes this.
  9. ALLDONE
    ALLDONE
    I'm with you... i noticed mine woble while under the car...
    alanp561 and ratster like this.
  10. jimmy six
    jimmy six
    At the show the 55 was at the top of the lift by what is in the last photo.
  11. BendPak states this for their HD-9 Four Post Lift:
    Caster kit
    Ask us about the 4-piece caster kit that fits all our 9K four-post lifts. They turn your stationary lift into a mobile parking and service station. You can even leave a car on top while you move it! "
    Budget36 likes this.
  12. 1946caddy
    1946caddy
    from washington
    A friend of mine had a four post lift in his shop before he downsized and sold it.
    He always had a car on it and even used it to pull engines.
    One day when I went over to his shop, the lift was empty, in the full up position and he was standing on it to stack items on the selves along the side and back walls along the side of the lift. I climbed the ladder next to the lift and when I got on it, the whole lift swayed around like being in a little boat on a lake. Had to walk around like being on ice.
    ratster likes this.
  13. Ziggster
    Ziggster
    Haven’t read every post, but seems the true cause is still unknown to those here. Typically, as far as “failures” are concerned, there are usually multiple factors involved and not just a single mode of “failure”.
  14. K13
    K13
    The lift company has explained what happened and took full responsibility. The style of lift was meant to be bolted down. It wasn't. The floor gave way and it fell over.
  15. 1971BB427
    1971BB427
    from Oregon
    The higher up a vehicle is on a lift the less support there is from corner to corner. So any shift of one of the bases will be amplified and as mentioned above they can "walk". Once a leg begins to shift or walk the whole lift becomes unstable and can crash like this one did. All this is further enhanced by the flooring system that's slick and allows the bases to move easier than concrete would.
    Tow Truck Tom likes this.
  16. ALLDONE
    ALLDONE
    what I noticed on mine was the locks don't go in that far and it wouldn't take much of a movement to come loose... spooked now and gonna have them come back and bolt it down..
  17. 05snopro440
    05snopro440
    Unless you work in selling or repairing these lifts (or investigating their failure), or know some real unlucky folks, I wouldn't expect the average person would actually see more than 1 or 2 lift failures in their life with their own eyes, if that.
    leon bee and Budget36 like this.
  18. racecougar
    racecougar
    That is a screenshot of my conversation with Champion customer service this morning. I posted it at Garage Journal. upload_2025-1-24_11-0-51.png
    This was also posted on reddit: upload_2025-1-24_11-3-38.png
    53 effie and leon bee like this.
  19. 35 Dodge Hot Rod
    35 Dodge Hot Rod
    from Mecca
    The failure rate on the space shuttle was atrocious. Far worse than 4 post lift failures, no doubt. Out of 135 missions (that we know of) 2 missions resulted in total loss of crew and vehicle. A nearly 1.5% failure rate. (1.48%)
    Imagine loading up your entire family into your car and every 200 trips you took there was the chance of everyone being killed 3 times out of those 200 trips. I don't think I would take that kind of risk.
    leon bee and arse_sidewards like this.
  20. 1971BB427
    1971BB427
    from Oregon
    Sorry but I have to laugh at that comparison. I'd hardly relate sending astronauts into outer space with picking a car off the ground.
  21. hotrodlane
    hotrodlane
    You would be correct with your expectations. And I am only speaking from my personal experience with the Cheaply made offshore lifts like Champion. I have been around auto lifts for well over 30 years. I have owned Rotory, Benwil, Ben pak and Challenger. I almost bought one of these offshore lifts myself but luckily my friend did first. And I helped him install it and after seeing the quailty of that garbage that was enough for me to buy and rebuild a used one. What a lot of guys fail to understand is there is a reason why (ALI) the Automotive Lift Insitute will not certify any of these cheaply made lifts. And that is because they do not feel they are safe. If you own one and are happy with it and trust your life with it then good for you and I hope that all works out for you. But for me, I am not going to trust my life under one of them. One thing I know is even a good piece of equipment can fail sometimes, So knowing that, I for sure am not going to risk it with unsafe junk. Here is the thing, I realize there are lots of guys who bought and own these cheaply made lifts and lucky for them nothing bad has happened yet. But none of that changes the Quality or safety of it.
    BPK65, leon bee and 05snopro440 like this.
  22. swade41
    swade41
    from Buffalo,NY
    If you want to see a guy pushing his luck on a 4 post lift, fast forward to the 30 minute mark and watch this thing rock back and forth !
  23. rusty valley
    rusty valley
    WOW !! That looks just like the chinese thing that I have.
    swade41 and 49ratfink like this.
  24. WOW :eek:
    At one point in the video (27:51) I believe I am getting a glimpse of one leg base and although there does appear to be holes for fasteners in the base, there does not appear to be any fasteners in them. I do not think this unit is bolted down yet it appears it comes with holes that would allow it to be bolted down. I'd have ****ped me pantaloons if I was under that thing with it swaying like that .... YIKES :confused:
    swade41, 49ratfink and alanp561 like this.
  25. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    ;):p Well @K13 took ya long enough to to get here:D:rolleyes:
  26. alanp561
    alanp561
    Call me old-fashioned but while that cutesy plasma cutter would be great on clean metal, it would be so much easier using a flame wrench cutting a wider kerf and getting all the slag out of the way. As for the lift rocking, maybe the addition of a larger baseplate on each corner with gussets from plates to post.
    GuyW, SS327, swade41 and 1 other person like this.
  27. tubman
    tubman
    My '99 F150 just barely misses fitting under my 4 post lift. Since it is not bolted down, I was considering a 12" X 12" 2" thick plate bolted to each foot to gain a couple of inches clearance and maybe add a little more stability. Wood is out, steel is really heavy, and then I priced aluminum. I haven't given up on the idea and have recently come into the possession of a length of 2 X 4 X 3/8 steel "C" channel. I am considering how to position them; right now, I am considering one longitudinally and one laterally on each side to maximize support. Any comments?
  28. BJR
    BJR
    From Facebook:
  29. Mr48chev
    This would be the lift in question according to the way I read the FB comment in post 152. Screenshot (1944).png
  30. hotrodlane
    hotrodlane
    Check out this video (Click link 1961 Corvette Rescued from Failed Four-Post Lift ) of one of the cheap offshore lifts that has been sold by the hundreds and being branded under a bunch of names. (None of them are ALI certified) Does this look like the one that some of you may have in your shop? If so do you think that maybe you got lucky and the 7 year old chinese girl got her welds penetrated better on yours or her little sister used a better grade pulley bolt on yours? That lift does not look very old, Pretty Scary stuff! just saying.
